Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Wheels and Tires Talk Sponsored by The Tire Rack
Old 02-18-2012, 02:23 PM   #29
Sebastian
Drives: Camaro 2011, 6.2L 2SS
mine are on cold 36psi. i just follow whats written inside the car.
Sebastian is offline   Reply With Quote
Old 02-18-2012, 02:24 PM   #30
Sebastian
and whats the car monitor says is never correct, specially after 1 or 2 hours on the highway, always far too high.
Old 02-18-2012, 03:52 PM   #31
oldfriend
Drives: Fiat 500 E
Originally Posted by bradshaw View Post
36 is correct, always follow the cars recommendation for proper handling.
Yeah , at 36 psi , but on which gage , there will be at least a dozen or so different readings on one tire at anytime .
oldfriend is offline   Reply With Quote
Old 02-18-2012, 06:06 PM   #32
edgehead2000
2016 Camaro 1LT 2.0T
edgehead2000's Avatar
Drives: Nemesis
Originally Posted by Parag View Post
the max psi is for setting the bead. for stock size always go with the body tag. but if you put 22's on, you want to adjust accordingly
Just curious... what would 'accordingly' be? I always use 38, anything less and the car feels sluggish for some reason, like you're carrying a flat.
edgehead2000 is offline   Reply With Quote
Old 02-18-2012, 06:15 PM   #33
The Stig
knows 2 facts about ducks
The Stig's Avatar
Drives: ...and they're both wrong
an analog gauge. You should keep one in your glove box - though most people don't.
Click to view my build thread
The Stig is offline   Reply With Quote
Old 02-18-2012, 09:48 PM   #34
Earl
Drives: Camaro
36
Earl is offline   Reply With Quote
Old 02-19-2012, 10:54 AM   #35
mth35115
Drives: 2010 Camaro rs/ss inferno orange
Also, if you over inflate your tires your car will ride like a folk lift, (rough as hell). Your tire absorb a lot of the road's irregularities, like pot holes, railroad tracks, ect.
HOT ROD SS
MTH35115
mth35115 is offline   Reply With Quote
Old 02-19-2012, 11:16 AM   #36
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
Originally Posted by Comrando View Post
Only if they had the same boiling point, which they don't.
Another reason to use nitrogen is to reduce the amount of moisture in the tire. Moisture will lower the boiling point.
All gasses obey the gas law, PV=RT. The only benefit is that the Nitrogen will be free of water, which will turn to gas if the air in your tires reaches 100 deg C. That's not gonna happen, except on the racetrack, maybe.
But the gasses in the atmosphere all stay gaseous at any temperature you will ever encounter, and so will all see the same pressure increase.
Nitrogen in tires is BS.
Old 02-19-2012, 11:19 AM   #37
EMB135Driver
Jedi Master
EMB135Driver's Avatar
Drives: Boeing 757/767+2010 IBM 2SS
Originally Posted by Caspers2SSRS View Post
Unbeknownst to most is the correct formula used to determine the recommended cold tire air pressures of any passenger automobile. Its pretty simple
The gross vehicle weight divided by one hundred (GVW in lb/100) equals the recommended tire PSI when cold.
Do you have a source for this formula....I think it Unbeknownst to most because this is pure BS....(its very good BS though). I think I'll stick with going by what the engineers at the Manufacturers Research and Development Department came up for a recommended cold pressure as long as I have stock size tires.
EMB135Driver is offline   Reply With Quote
Old 02-19-2012, 11:22 AM   #38
90503
90503's Avatar
Drives: 2011 2SS/RS LS3
Originally Posted by Earl View Post
36
Is this for each tire?? or the cumulative total of all four...lol
Old 02-19-2012, 11:28 AM   #39
mikeyroche
Drives: 2011 VR Camaro 1SS/RS M6
Originally Posted by The_cartoonist_88 View Post
I keep mine at 36. Always go with the vehicle recommendations
This, it is on area where the door closes (Drivers side). It tells you how much pressure
2011 Camaro 1SS with RS - K&N Typhoon CAI, Borla Atak Exhaust, Hawk Performance Ceramic Pads, SLP 'SS' Front Grille Emblem, Blue LED interior lighting, Camaro Victory Red Seatbelt Harness pads NEXT - Corvette LS3 Victory Red Fuel Rail Covers(Awaiting Installation), Window Tinting, Custom Leather Interior.
mikeyroche is offline   Reply With Quote
Old 02-19-2012, 11:30 AM   #40
mikeyroche
Not really BS at all. We use it at work all the time on the Aircraft. Nitrogen is far more superior then air
Old 02-19-2012, 12:01 PM   #41
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
Nitrogen in aircraft and nitrogen in cars are to different monsters.
It has been proven that there are benefits to nitrogen in aircraft due to the pressure and temperature differences between ground level and cruising altitudes. However in automobile tires there haven't been any proven benefits over normal compressed air. Race cars and dragsters are the exceptions.
Mr_Draco is offline   Reply With Quote
Old 02-19-2012, 12:31 PM   #42
Pelirrojo80
Drives: 2011 2LT RS "One of the few blues"
Is the low pressure alarm suppose to go off at 32psi? I came back from a deployment and one of my tires was at 25psi and I didn't get any alarm.
Pelirrojo80 is offline   Reply With Quote
pirelli, pressure, psi, tire pressure, tires
What do all the abbreviations mean? CrzyGamr2 5th Gen Camaro SS LS LT General Discussions 77 12-07-2012 04:34 AM
Tire Pressure Questions nalinc23 Wheels and Tires Talk Sponsored by The Tire Rack 21 09-15-2010 01:18 PM
factory 20in wheels cold tire pressure? mike12345 Wheels and Tires Talk Sponsored by The Tire Rack 7 05-11-2010 12:58 AM
Tire pressure monitor CEL after tire change B.Buster Wheels and Tires Talk Sponsored by The Tire Rack 6 04-01-2010 08:45 PM
Tire Pressure Problems Matster Canada 14 10-03-2009 06:11 AM
