08-12-2016, 06:14 PM | #1 |
Drives: LSX FTW Join Date: Feb 2016
Sun roof rattle
Sun roof is rattling while going over slight bumps, listening to music not very loudly.. anyone else experience this? Still functions properly however.
08-12-2016, 08:05 PM | #2 |
Drives: 2015 Summit White SS Join Date: Aug 2014
Yes. I'm taking it to the dealership soon to see what they tell me. Hopefully it isn't an arm and a leg.
Full Bolt-Ons w/ Nightfury Cam (471rwhp)
08-12-2016, 08:20 PM | #3 |
keep me updated man, trying to figure this out..
08-12-2016, 09:14 PM | #4 |
Drives: 2010 1SS RS M6 Join Date: Jan 2015
You having a 15 it shouldn't cost you a penny, that's what warranty is for, anyways, mine rattles too, let us know what the fix is. I'm guessing some bushings or something like that
Vararam intake, gmpp exhaust, borla stainless long tubes, cat less, jannetty tune, bmr lowering springs, heritage grill , smoked lenses
08-13-2016, 01:23 AM | #5 |
Drives: 2014 BRM 1SS/RS Join Date: Sep 2011
Could be debris in or around the track.
2014 Blue Ray Metallic 1SS/RS A Road Warrior |
08-16-2017, 05:17 PM | #6 |
Barefoot Dave
Drives: 2015 ZL1, 2014 Z/28 Join Date: Dec 2015
I know this is an old thread but its the most relevant to what I just found in my 14 2SS. I took it to the dealer for a "tin foil crinkly" sound above the driver and a rattle behind the sunroof when I went over bumps. With the sunroof open it didn't happen.
They removed the headliner and found the brace across the roof behind the sunroof had come loose and was creating the noise! It's attached from the factory with adhesive so they used factory adhesive to reattach it and installed a new headliner. I should be getting it back tomorrow so I'll let you know if it fixed the issue! I'm 5 days and 1000 miles from warranty expiration so it won't cost me anything -hopefully if this helps someone else you are still under warranty because I'm sure it isn't a cheap fix. |
08-16-2017, 06:40 PM | #7 |
Drives: 2011 Camaro 2SS/RS Join Date: Oct 2013
I notice mine makes was sounds like a rattling sound when the weather strip gets dirty. I open the sunroof and thoroughly clean the perimeter of the weather strip with a wet rag. Then I lubricate it with silicone spray, sprayed onto a towel and wiped on
. Seems to drastically quiet it down.
08-17-2017, 11:32 PM | #8 |
Factory Correct
Drives: 2011 2SS/RS Join Date: Dec 2011
My mom had a similar issue , ended up being a couple of acorns in there.
08-18-2017, 12:56 AM | #9 | |
Drives: 2011 1SS RS Join Date: Aug 2016
Give her red wine. |
