Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Camaro Issues / Problems | Warranty Discussions | TSB and Recalls
Old 06-03-2016, 09:57 PM   #1
havelegs
havelegs's Avatar
Drives: '23 LT1 A10
Normal headlight noise when switching to high beams?
Hmm..I never noticed it before but I did tonight. You can hear a bit of a groan when I flicked the switch. HID headlights. Normal, yeah?
havelegs is offline   Reply With Quote
Old 06-03-2016, 10:15 PM   #2
BostiPB
BostiPB's Avatar
Drives: 2014 Camaro 2SS/RS
Mine does it as well. I believe it is because of the HIDs. IIRC my previous cars have made a similar sound with the HIDs and turning on the high beams.
2014 2SS/RS - Red Rock Metallic - Kooks Headers, Corsa Extreme, Factory Reproductions Z28 Rims, Pedders Coilovers, JDP Clutch Reservoir, Summit Racing Line Lock, GM Strut Brace, GM low profile splash guards, Roto-fab CAI, Oracle Ghosted Sidemarker Lights & Concept Mirrors, ZL1 Side Skirts, MGW Flat Stick Shifter, BMR Subframe Connectors, Eaton Truetrac, Yukon 4.11s, GForce Renegade Axles, Speedmaster79 Diff Cover, Offset Diff Bushings, Every Suspension Bushing Front & Rear Replaced with BMR Poly Bushings - 421HP 412TQ
BostiPB is offline   Reply With Quote
Old 06-03-2016, 10:15 PM   #3
deweyg63
deweyg63's Avatar
Drives: 2011 2SS/RS 500+ h.p. monster
My 2011 does it
deweyg63 is offline   Reply With Quote
Old 06-03-2016, 10:17 PM   #4
havelegs
havelegs's Avatar
Drives: '23 LT1 A10
Ok then. I just never noticed it till some taxi stopped infront of me and I started flashing my lights. Heard the sound but never noticed it before lol.
24 LT1 M6 Sharkskin Metallic
Old 06-03-2016, 10:22 PM   #5
drew peacock
Drives: 2012 2SS INFERNO ORANGE
sort of click mine does..euro model camaros have self leveling headlights..
drew peacock is offline   Reply With Quote
Old 06-04-2016, 12:02 AM   #6
Dizzy82
Dizzy82's Avatar
Drives: 2011 1LT/RS A6 RJT SuperCharged
Normal.
Power is worthless without control. The 2nd protects the 1st.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ
Dizzy82 is offline   Reply With Quote
Old 06-04-2016, 12:12 AM   #7
MrChrisLS3
Drives: 2018 1SS M6
Headlamp bearings need replaced. Might as well have them change the blinker fluid while they're at it.
MrChrisLS3 is offline   Reply With Quote
Old 06-04-2016, 01:07 AM   #8
Crowmag
Crowmag's Avatar
Drives: 2015 2SS/RS L99
High beams are achieved mechanically. I believe a shield is moved to allow full light output i.e. high beams.
Crowmag is offline   Reply With Quote
Old 06-04-2016, 01:48 AM   #9
Ledzepx
Ledzepx's Avatar
Drives: 2010 2SS Camaro 6sp.
Its a normal. Click
Ledzepx is offline   Reply With Quote
Old 06-04-2016, 10:23 AM   #10
camaro2ss/rs
Drives: 2ss/rs
how about when you sit in the car with it off and just press on the brake you will also here a click sound.. sounds like it is coming from under the console
camaro2ss/rs is offline   Reply With Quote
Old 06-04-2016, 11:16 AM   #11
Ledzepx
Ledzepx's Avatar
Its a normal. Thats the relay.
Old 06-04-2016, 01:33 PM   #12
camaro2ss/rs
Drives: 2ss/rs
now was that cool....guys looking for help
Old 06-04-2016, 01:38 PM   #13
Moto-Mojo
Fast Cars and Old Guitars
Moto-Mojo's Avatar
Drives: 2015 2SS RS (L99, baby!)
This. Your 'high beams' are on ALL THE TIME but a baffle or cover mechanically closes and opens over the top of the headlights making the sound.
“I don’t want to belong to any club that would have me as a member.” - Groucho Marx
Moto-Mojo is offline   Reply With Quote
Old 06-05-2016, 12:15 AM   #14
amz
Factory Correct
amz's Avatar
Drives: 2011 2SS/RS
Yup!
amz is offline   Reply With Quote
