Vararam
Old 03-18-2014, 12:04 PM   #1
Fresh
Fresh's Avatar
Drives: 2011 Victory Red
where to buy new halos
I own a 2011 RS. I love my current halos but they are just not bright enough.
Does anyone offer the headlight set for the RS model with brighter LEDs? I dont want to baked my headlights either. Is there a place where i can buy a new set of RS headlights already equipped with the brighter LEDs?
im sure this has been asked before but thanks!
would something like these even be worth it over the stock RS lights?
Fresh is offline   Reply With Quote
Old 03-18-2014, 12:35 PM   #2
sjmautoprod
sjmautoprod's Avatar
Drives: '16 2SS
Not if they are CCFL.
Our halos are about the same as stock. We also handle Nightowl, which is brighter. No baking.
sjmautoprod is offline   Reply With Quote
Old 03-18-2014, 01:20 PM   #3
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
Check out our JDP Color changing halo kit. It gives you the option to run many different colors at the touch of the button and does not require baking the headlights.
Feel free to call, PM or email me anytime with questions.
Best regards,
Tyler
888-308-6007
JDP Sales is offline   Reply With Quote
Old 03-18-2014, 01:57 PM   #4
CamaroI
Drives: 2010 IOM Camaro
Night owl is the way to go!! Pricey but you will not regret it. Ultimate control via your smart phone. Customer Service is the best around!!
CamaroI is offline   Reply With Quote
Old 03-18-2014, 02:15 PM   #5
Fresh
Fresh's Avatar
all of those kits require taking apart the headlights right?
Old 03-18-2014, 02:16 PM   #6
sjmautoprod
Drives: '16 2SS
Only the kits that use LED rings.
Old 03-18-2014, 03:02 PM   #7
jgray1978
jgray1978's Avatar
Drives: '12 2SS/RS 45th vert, '14 2SS/RS
The NightOwl kit involves removing the ballast (held by three screws) and the access cap (1/4 turn). Real easy to get in. Then you can get the inside screws to release the LED under the ring directly except for one that requires use of a swivel. The kit comes with an excellent video showing how to do it. No baking!
jgray1978 is offline   Reply With Quote
Old 03-19-2014, 12:27 PM   #8
Fresh
Fresh's Avatar
i had no idea! im going to look for the video to see how easy it is to install, if so i will be making a purchase very soon!
Old 03-19-2014, 12:29 PM   #9
Fresh
Fresh's Avatar
how much brighter are the night owl leds vs stock?
Old 03-19-2014, 12:53 PM   #10
spadz93
BUMBL Z
spadz93's Avatar
Drives: 2015 ZL1
^interested in this as well, in terms of brightness. install seems quite easy from the above directions, and the stock halos could definitely be brighter
Current: 2015 ZL1 M6, Rotofab Intake, LS3 throttle body, 2.55 Upper/9.17 Lower w/ Idler Relocation, DMS Reinforced Brick, ID1050X, 1 7/8" Headers, ProSpeed HX/Reservoir, DSX Aux Pump/Flex Fuel Sensor, E85, McLeod RXT, BMR 1" Drop, Tuned by Pat G
Past: 2010 2SS, some bolt ons, 415rwhp/400rwtq
spadz93 is offline   Reply With Quote
Old 03-19-2014, 02:43 PM   #11
Earnhardtfan77
Drives: Summit White 2012 1LT/RS
i noticed the 2014 camaro halos are extremely brighter then previous versions
Earnhardtfan77 is offline   Reply With Quote
Old 03-19-2014, 03:10 PM   #12
The Stig
knows 2 facts about ducks
The Stig's Avatar
Drives: ...and they're both wrong
This is due to a change in the headlight design. The 2010-2013 halos were lit by one LED mounted at the base of the halo ring. The 2014 halos are lit by six (IIRC) LEDs mounted behind the halo ring. So instead of using the ring to refract the light, the ring is being used to diffuse the individual LEDs.
Click to view my build thread
The Stig is offline   Reply With Quote
Old 03-19-2014, 04:02 PM   #13
sjmautoprod
Drives: '16 2SS
It's brighter, but, it's not as nice looking. I wish GM stuck with the light-pipe design like some other manufacturers have.
Old 03-20-2014, 02:59 PM   #14
Fresh
Fresh's Avatar
the 2014 halos or the night owls? lol
i wish i could get mine as bright as the 2014...could i swap 2014 headlights out with mine?
