dave@hennessey
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Sponsors Classifieds Marketplace > Suspension / Chassis / Brakes
Old 05-25-2012, 09:35 AM   #1
Juiced1
Drives: 2012 2SS CAMARO 45th
STAGE 2 BMR SUSPENSION PACKAGE GET AMAIZNG DEALS FROM JUICED MOTORSPORTS
Improve overall handling in your 2010 Camaro with a Level 2 Handling Performance Package from BMR Suspension. This kit consists of a BMR Sway Bar Kit (SB030), 1” Lowering Springs (SP019), and Total Suspension Bushing Kit (BK023). BMR sway bars are cold formed from lightweight tubular DOM steel, feature 3 adjustment locations and integrated thrust washers to prevent horizontal movement. BMR springs are constructed from high tensile silicone chromium spring wire and come with a lifetime warranty against spring sag. Our polyurethane bushings are specifically formulated for optimal performance without sacrificing ride quality. The Level 2 Handling Package (HPP019) will minimize bushing deflection, lower the center of gravity, decrease body roll and dramatically increase the cornering capabilities of your 2010 Camaro. All components also sold separately. Sway Bars available in red powdercoat or black hammertone finishes, springs and bushings in red only.
NOTE: When using on 2012 models it is necesarry to purchase either BMR ELK006 Rear Sway Bar End Links or OE 2010/2011 Rear End Links.
http://www.juicedmotorsports.com/2010camaropowerpackage_hpp019.html
Juiced1 is offline   Reply With Quote
Old 05-26-2012, 05:51 PM   #2
Juiced1
Eliminate suspension flex and find out our your Camaro should really handle!
Old 05-28-2012, 02:58 PM   #3
Juiced1
Hook and book
Old 05-28-2012, 08:10 PM   #4
Juiced1
GMACHINE
Old 05-29-2012, 10:27 AM   #5
Juiced1
You won't need ZL1 shocks to handle like a dream
Old 05-29-2012, 07:30 PM   #6
Juiced1
Like your Camaro is on rails
Old 05-30-2012, 09:44 AM   #7
Juiced1
The kind of handling your Camaro should have from the factory lies in the package
Old 05-30-2012, 04:32 PM   #8
Juiced1
ORDER UP
Old 05-31-2012, 12:28 PM   #9
Juiced1
The bushing kits are worth their weight in gold. They will eliminate all the factory suspension flex while the new springs and sway bars just plant you to the ground. AWESOME SET UP
Old 05-31-2012, 08:24 PM   #10
Juiced1
See the kind of Gforces that Nasa talks about!!!
Old 06-01-2012, 10:03 AM   #11
Juiced1
awesome mod
Old 06-01-2012, 07:03 PM   #12
Juiced1
G MACHINE
Old 06-02-2012, 02:05 PM   #13
Juiced1
G-MACHINE
Old 06-04-2012, 12:42 PM   #14
Juiced1
CARVE CORNERS LIKE A FERRARI....SS
bmr, lowering springs, suspension, sway bars
