12-19-2022, 12:48 PM | #1 |
Drives: 2018 Chevy Camaro 1LT Join Date: Jul 2021
Battery terminal engine bay question
OK here's a dumb question because I seem to be full of them according to people on here even though I'm just uniquely curious and want to learn.
I need a positive post to put my eye connector on for a project. I see that next to the fuse bank is a power terminal bank. Which one of those is OK to loosen and put the eye connector onto? Does anyone have a diagram or picture of it with the correct one to put a positive connection to? Thanks guys! |
12-20-2022, 10:22 AM | #2 |
Drives: 2020 Callaway Camaro SC630 Join Date: Feb 2020
Don't have a pic with me, but I used a large ring connector and slid it over the positive post under the cap. I then used a plastic sleeve from another connector and tapped it onto the post to hold the ring down.
I use it for my quick-disconnect battery maintainer. Not for the traditionalists, but effective.
2020 Callaway Camaro SC630 - MN6 1SS Satin Steel Gray
2019 Callaway Corvette SC757 - MN7 1LZ Elkhart Lake Blue |
12-20-2022, 01:29 PM | #3 |
Drives: 2018 Camaro SS vert Join Date: Oct 2020
I hooked up an eye terminal to one of the existing posts there, don't remember which one, just tested with a multimeter
If I get a chance will snap a picture
12-20-2022, 02:26 PM | #4 |
12-23-2022, 02:24 PM | #5 |
Here you go, if I remember right all terminals were live when I checked them with a meter, I just went with the most convenient one
12-23-2022, 05:09 PM | #6 |
What size nuts do we need for those terminals? I want to hook up my battery charger to it. I bought a charger but the clamps don't work that well - then I realized that the charger came with another set of wires with ring terminals & a cap for the other end - perfect setup!
RUXIFEY Smoked LED Side Marker Lights / Black SS emblem on rear bumper / Blue SS vinyl overlay on front bumper emblem / Wildhammer Rear Dark Reflectors / Trim Illusion Gloss Black Door Handle Covers / eBay Black Fuel Door / Screaming Chicken Fender Hash Marks / Color-Matched G2 Caliper Paint RE Audio RFX10D4 10" Sub / Hand-made sub enclosure / Hifonics Zeus ZRX1200.1D amp / JL Audio LoC-22 line output converter / Sub Thump Plug N Play T-Harness With ANC Defeat Harness Kit My Camaro Journal |
12-23-2022, 11:10 PM | #7 |
This helps immensely so thanks for that! Yeah it would make sense that they are all charged since it's like a rail for the engine bay.
12-24-2022, 11:19 AM | #8 | |
'20 ZL1 1LE A10,
12-24-2022, 04:28 PM | #9 |
I took one off and went to home depot to match up, remember it was a standard size but this was years ago so no clue what it was
12-26-2022, 06:06 PM | #10 | |
Drives: 2023 ZL1 A10 Join Date: Nov 2021
Ask away , and never make an excuse when learning. Happy Motoring
2023 ZL1 A10 Shadow Gray Metallic
12-27-2022, 01:08 AM | #11 | |
Drives: 2016 Camaro SS Vert. Join Date: Apr 2017
Tags |
battery, bay, engine, power, terminal |
