Roto-Fab
Old 05-26-2022, 11:09 PM   #1
SSVictor
Drives: 2010 Camaro 2SS
Car bogging and stuttering around 2,200 Rpm
Just got Corsa Sport zl1 quad exhaust installed on a 2010 camaro ss automatic about 2 weeks ago and the car is starting to bog and stutter around 2,200 rpm and I can feel vibration under the floorboard when idling. The car has TSP 1-7/8” catless headers, JLT intake, BTR Stage 2 cam and a 3,200 converter Stall.
SSVictor is offline   Reply With Quote
Old 05-27-2022, 03:50 AM   #2
Wizard1183
Wizard1183's Avatar
Drives: ABM SS2/RS M6
Send a message via Yahoo to Wizard1183
Is it throwing codes? Check engine on?
Life is short, drive it like you stole it!
Wizard1183 is offline   Reply With Quote
Old 05-27-2022, 08:48 AM   #3
SSVictor
There’s not any codes or check engine light
Old 05-27-2022, 10:39 AM   #4
SSVictor
It’s idling a little rough and smells like gas
Old 05-27-2022, 11:19 AM   #5
Wizard1183
Wizard1183's Avatar
Might be a bad injector
Old 05-27-2022, 11:24 AM   #6
tartagliazl1
tartagliazl1's Avatar
Drives: 2013 zl1 vert
You sure your tuner didn’t turn off any of the mil lights in the tune. If you have hp tuners you should check it out.
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 850/ dsx aux kit/ 103mm throttle body/ RPM 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ brick mod/BMR toe and trailing arms/ 751hp 757 tq SAE @17.3lb on a loaded dyno.
tartagliazl1 is offline   Reply With Quote
Old 05-27-2022, 12:20 PM   #7
SSVictor
I don’t think the tuner turned off any lights I just recently had a couple for a bad alternator.
cam, engine, exhaust, help me, tune
