Old 04-26-2021, 02:39 PM   #1
HollowedCamaro
Drives: 2014 Camaro 2LS
Cat removal help!
So I have some high flow cats for my 2014 v6. I can’t figure out how to get the passenger side cat off. There is no room at all I can’t fit any tools down there. Anyone gotten it off and if so how?
HollowedCamaro is offline   Reply With Quote
Old 04-26-2021, 02:58 PM   #2
KillboyPowerhead
Drives: 2015 Z/22
Easier to go from underneath. Can't provide any details as I had a shop do mine (was cheaper for them to buy and install than for me to buy myself ), but I've read from others that you'll need to access the passenger side from below.
Overkill/Self Tuned; Mace Camshafts; K&N Typhoon Cold Air Intake; Ported 80mm Throttle Body/Intake Manifolds/Manifold Spacer; Solo Performance High-Flow Cats, Cat-back Exhaust; Vitesse Motorsports Throttle Controller; Elite Engineering E2 Catch Can; BC Racing BR Coilovers; JPSS Delrin Radius Rod Bushing Inserts, Sway Bars; Pegasus Aluminum Rear Cradle Bushings, Camber/Caster Plates; Z/28 Toe Links, Trailing Arms, Upper Control Arm Bushings, Rear Shock Mounts
KillboyPowerhead is offline   Reply With Quote
Old 04-26-2021, 04:59 PM   #3
AlanRubin
Drives: 2010 LS
Yeah, easier to get at from underneath, even if you can run it up on ramps.
AlanRubin is offline   Reply With Quote
6cylinder, cats, engine, exhaust, loud
