dave@hennessey
Old 02-29-2016, 08:05 PM   #15
TheBonfiggy
Drives: 2013 Camaro 1LE
battery isnt that old as my car is a 2013, I just find it weird because I literally have never had an issue with the car starting, even started yesterday just fine. It has to be something to do with the installation of the new harness as that is the only thing that is different. The harness that I installed was the exact same as the one that I replaced it with.
Originally Posted by Welker2 View Post
Even though the battery fully charged, it may still be bad. If you haven't already done so, take it to your local auto parts store & have it checked. If it checks out & you're sure you've got everything connected up right (which it sounds like you have), unfortunately, the next step may be to have it towed to a shop & checked out. Good luck.
TheBonfiggy is offline   Reply With Quote
Old 02-29-2016, 08:16 PM   #16
sbubbaklein
sbubbaklein's Avatar
Drives: early 2011 Camaro convertible
using a GM compatible scan tool, you need to go into each ecu and clear the codes. There are two different types of codes, current and history. Clear all codes then try to restart
Early 2011 LT Convertible, ZL1 bumper, hood, side skirts, belly pan and wheels, Truecarbon ECF hood extractor, K&N CAI, Elite catch can, Big Worm Bow Tie emblems, Jacfab bracket, Vitesse TC, BMR strut brace, BMR tunnel brace, NPP exhaust
sbubbaklein is offline   Reply With Quote
Old 02-29-2016, 08:43 PM   #17
two_wheel_mayhem
Would rather be riding
two_wheel_mayhem's Avatar
Drives: No car no more
Check all the fuses, inside and under the hood.
No dog in this fight anymore.
5th Gen owner 2009-2016.
two_wheel_mayhem is offline   Reply With Quote
Old 02-29-2016, 10:08 PM   #18
spadz93
BUMBL Z
spadz93's Avatar
Drives: 2015 ZL1
If he disconnected his ECU during the engine harness replacement, what are the chances he could need a case/crank relearn?
This could also work as well, check out www.scantool.net for some adapters. Some even work with iphones and androids. I have their LX model connected to the "Torque Pro" app on an android tablet in my car via bluetooth, and the code reading/clearing works great.
Current: 2015 ZL1 M6, Rotofab Intake, LS3 throttle body, 2.55 Upper/9.17 Lower w/ Idler Relocation, DMS Reinforced Brick, ID1050X, 1 7/8" Headers, ProSpeed HX/Reservoir, DSX Aux Pump/Flex Fuel Sensor, E85, McLeod RXT, BMR 1" Drop, Tuned by Pat G
Past: 2010 2SS, some bolt ons, 415rwhp/400rwtq
spadz93 is offline   Reply With Quote
Old 03-08-2016, 01:35 PM   #19
xnuyokr
xnuyokr's Avatar
Drives: 2012 1LT Drop Top
xnuyokr is offline   Reply With Quote
Old 11-29-2021, 10:12 PM   #20
Dont Quit Noob
Drives: 2013 1SS
So what was the problem?
Dont Quit Noob is offline   Reply With Quote
Old 07-11-2023, 02:57 PM   #21
Valdez19
Drives: Chevrolet Camaro SS
Did you ever have this problem and or get it fixed?
Valdez19 is offline   Reply With Quote
Old 07-14-2023, 03:08 AM   #22
morepowerjoe
morepowerjoe's Avatar
Drives: 2012 Chevrolet Camaro l99
I'm wondering if when the wiring harness got burnt on what ever sensor it went to got fried as well or maybe the ecu?
He never said what sensor it was did he?
DSS FX Forged Pistons, Eagle ESP L19 Forged Rods, ARP Head and Main Studs, TSP PRC 260 CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnions , Molly Pushrods, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP 1 7/8" Longtubes with 3" TSP Exhaust, ZL1 Fuel Pump, Mishimoto Radiator, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter, Fluid Dynamics Balancer
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817
morepowerjoe is offline   Reply With Quote
Old 07-15-2023, 06:54 PM   #23
Valdez19
Hey did you ever find/fix the problem?
Old 07-15-2023, 07:08 PM   #24
2013ZL1FUN
2013ZL1FUN's Avatar
Drives: 2013 ZL1 Convertible A6 BRM
His account is listed as being suspended so............
2013 ZL1 CONVERTIBLE BRM A6
OHIO
2013ZL1FUN is offline   Reply With Quote
Old 07-17-2023, 09:01 PM   #25
oldman14ss
Drives: 2014 1ss camaro
unplug you connectors and look down in each one to see if there is a bent pin inside connector. push each wire into each connector. add some dialectric grease to you connectors. i had that happen to me with my cobalt bent pin did just what you are experiencing
oldman14ss is offline   Reply With Quote
camaro, engine, harness, wiring
