08-29-2012, 07:21 PM | #1 |
Drives: 2023 ZLE Join Date: Jun 2009
Turning Off Traction Control and PTM
I'm sure this has been posted before. I tried a search and it brought back pages of threads...
I would like to know how to completely disable all traction control and PTM. When I press the T/C button one time I get the T/C off symbol on the dash. Is this all that is required? I know it is there to keep the car inline, which I can appreciate. Every once in a while I would like to be able to get into it without hearing the traction control. It sounds like I'm bouncing off the rev limiter at 4500 rpm. I'm pretty sure it is the T/C and would like to turn it off. I know, be careful... |
08-29-2012, 07:24 PM | #2 |
Drives: 2013 Triple Black ZL1 Vert M6 ECF Join Date: Mar 2011
I haven't tried it with the ZL1 yet, but with the SS, you held the T/C button in for about 7-10 seconds and it turned everything off.
08-29-2012, 07:24 PM | #3 | |
Drives: 2013 summit white zl1 Join Date: Aug 2012
08-29-2012, 07:24 PM | #4 |
hold down the traction control button for 5 secs...traction control and active handling will turn off and both icons illuminate
08-29-2012, 07:40 PM | #5 |
Drives: 2010 Duramax; 2012 CTS-V Coupe Join Date: Apr 2012
08-29-2012, 07:45 PM | #6 |
08-29-2012, 07:46 PM | #7 |
08-29-2012, 08:01 PM | #8 |
HDRDTD is correct. Hold it down for 7-10 seconds and everything is turned off. Press it twice and you enter PTM mode selection. Press it once and the traction control is by-passed but Stabilitrak is still active.
08-29-2012, 08:39 PM | #9 | |
To turn off both traction control and electronic stability control, press and hold the TCS/StabiliTrak button on the console in front of the shift lever. Press the TCS/StabiliTrak button again to turn on both systems. |
08-29-2012, 08:55 PM | #10 | |
08-29-2012, 09:37 PM | #11 | |
Drives: 2013 F-150 Limited Join Date: May 2008
This is all you have to do. Hold the button that is circled below for 5 sec. When you first press it the traction control light will come on, after the full 5 sec the stabilitrac light will come on.
There just might be a 2016 Camaro or Corvette in my future...
_____________________________________________ Previous Chevy's 2013 Camaro ZL1 A6|SIM 2010 Camaro 2SS/RS|M6|CGM Exterior|Gray Int 2000 Camaro SS|M6|SLP headers|SLP center mounted quad exhaust|Magnaflow muffler|Hypertech programmed 2001 Corvette|M6|LG Motorsports Headers|Corsa Touring Cat-back|Magnaflow X Pipe|Hurst short-throw|Dyno tuned |
08-29-2012, 09:50 PM | #12 |
YOOZ GOTA B FREKN KIDN ME
The Zeldabeast! A True Road Warrior!
2018 Dodge Challenger Hellcat WideBody 6MT 2013 ZL1 Camaro 6MT 2015 GMC Sierra 1500 SLT 6.2 L86 Crew Cab 2012 Aprilia RSV4 R 2015 Husqvarna FC450 Motomadness First Car: 1973 Dodge Charger 340 Magnum 4MT Factory Hurst Pistol Grip Shifter |
08-29-2012, 11:24 PM | #13 |
Drives: C6 Z06 Join Date: Jan 2010
To take off T/C just press the button once and you're good
08-30-2012, 06:35 AM | #14 |
Drives: Camaro ZL1 Join Date: May 2012
Anyone know (not guess, know) the difference between running in Sport ('M') mode with traction and stability turned off, and PTM5?
