07-07-2014, 09:52 AM | #1 |
Drives: 2013 Camaro 2SS Join Date: Feb 2014
Car Won't stall or do burnout!
I know your reading the title and thinking I am a fool....trust me I certainly feel the same way. I own a 2013 2SS L99. I've tried obviously shutting the traction control off and putting the stabilitrak in competitive. As soon as I hold the brake down and start to press on the gas the brakes disengage and the car takes off. I have tried multiple combinations of pressing the traction control button and holding it down (as others on here had explained to do) but nothing works.
Now can anybody help me out with this so that when I go to the track and try to stall it I don't fly through the lights. Has anyone had this same problem? |
07-07-2014, 01:26 PM | #2 |
Drives: 2011 RJT 2SS/RS Join Date: Apr 2009
I had very similar problems and had to have my BCM reflashed by a GM tech. The BCM is separate from the ECM and TCM and is located under the dash near the steering column (in case it needs to be replaced). They access the BCM through the OBDll connection. Good luck and let us know how it goes........................
07-07-2014, 10:19 PM | #3 | |
