dave@hennessey
Old 03-14-2014, 12:46 AM   #1
jake2212
jake2212's Avatar
Drives: none (yet)
need help, frustrated.
okay, so i have been trying to cram all this different information into my head about what i need vs. what i think i need to put a magnuson blower on my car. So i am turning to you guys here for help. what all do i need to have a maggie on my car running reliably and smoothly? I plan on staying at the 6psi stock boost level and this car is not a dedicated drag car. It is a street driven car.
current mods are as follows:
CAI
headers
ported TB(92mm)
Lingenfelter GT9 cam+ls3 conversion
1le sways
pfadt tie rods/trailing arms
zl1 wheels with michelin PSS(for everyone that will say "get better tires")
Now, I'm buying a magnuson and I want to know what else i should get so i dont end up on the side of the road pissed off at my broken down car. thank you for your help
jake2212 is offline   Reply With Quote
Old 03-14-2014, 01:03 AM   #2
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
You don't NEED any of the that, except maybe the CAI. Everything else falls under the "nice to have" category. All the PD blowers are made to be able to install and go. Changing over to the LS3 lifters is always a good idea since the AFM lifters are known to fail on stock cars. They aren't a "must have" though. Then it gets into, since you're already changing lifters, it isn't that much more to install a cam. Who makes a 92mm TB? BBK makes a 95 but I haven't heard of a 92
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
I once parallel parked a train.
axis is offline   Reply With Quote
Old 03-14-2014, 01:13 AM   #3
jake2212
jake2212's Avatar
Drives: none (yet)
those are my current mods. also my bad, i was under the impression the vmax TB was 92mm.
Old 03-14-2014, 02:19 AM   #4
axis
Search Ninja
axis's Avatar
Sorry, missed the line saying those were your current mods. Thought that's what you thought you needed.
Looks like you're good to go then. The LS3 conversion uses the LS3 lifters. What else could you possibly want? As long as you get a complete maggie set up and not a tuner version, you should be good to go. Who's going to tune it? That's probably one of the most important aspects.
Halltech CF 102 fed
Old 03-14-2014, 05:11 AM   #5
Jchaluja
Jchaluja's Avatar
Drives: ZL1 Camaro
You need a good tune and I would stay away from a converter in case you wanted one
Jchaluja is offline   Reply With Quote
Old 03-14-2014, 05:45 AM   #6
dan0617
dan0617's Avatar
Drives: 2011 Inferno Orange SS Convertible
ZL1/ADM combo and maybe a BAP, or a twin pump setup.
JRE 2800 stall converter. Nice and tight for normal driving.
Rear cradle bushings
Scrap the cats if you can
Wideband setup
Boost gauge setup
Drag radials and a rear drag alignment
2011 SS IOM Vert. ECS Vortech 13+ psi, Water/Meth, ID850’s, ZL1 pump with MSD Voltage Booster, 2800 stall, LT headers, Drag radials, Drag alignment, Cradle Bushings. A million other supporting mods. Tuned by Ted.
dan0617 is offline   Reply With Quote
Old 03-14-2014, 07:04 AM   #7
BooSSted
BooSSted's Avatar
Drives: 2017 Z06 / 2012 CTS
Wideband setup
Boost gauge setup
These things will finish off your current mods very nicely! Big emphasis on fuel!
SOLD - Maggie Powered 2011 2SS
Procharged Powered 2017 Z06
BooSSted is offline   Reply With Quote
Old 03-14-2014, 07:37 AM   #8
casper sc/1ss/rs
casper sc/1ss/rs's Avatar
Drives: 2011 camaro ss vortech supercharged
If he stays at 6psi the stock pump will handle that just fine.
casper sc/1ss/rs is offline   Reply With Quote
Old 03-14-2014, 08:50 AM   #9
BooSSted
BooSSted's Avatar
He's already cammed ..
Old 03-14-2014, 08:59 AM   #10
LS7 427
10.11 @ 136.32
LS7 427's Avatar
Drives: Black & Yellow 2SS/RS LPE LS7 427
With what you have already and considering your "need vs want" criteria for 6psi, this is my opinion...
NEED
- Maggie TVS2300 full kit (not tuner kit)
- A good dyno or email tune (motor and transmission)
WANT
- Wideband gauge
- Boost gauge
Three comments
- You won't need to address fuel at 6 psi boost (Your tune will confirm that or tell you otherwise)
- Should you experience wheel hop, your trailing arms will help but you might consider differential and cradle bushings. I would address that issue if it arises later.
- Your existing mods make an excellent platform for the addition of the Maggie. Good luck with your build, your going to love the additional power.
Bryan
My Build Journal
Built, Tuned and Maintained By........
LS7 427 is offline   Reply With Quote
Old 03-14-2014, 09:28 AM   #11
BooSSted
BooSSted's Avatar
IMO you'd be silly to add FI to an already 440-470 NA whp set up without addressing the stock fuel system.
The cost of a ZL1/ADM FPCM is worth the safety and room for expansion, injectors are always in the classifieds section for a low price as well.
Old 03-14-2014, 09:35 AM   #12
LS7 427
10.11 @ 136.32
LS7 427's Avatar
I don't necessarily disagree with you. Looking at fuel pressure and duty cycle on the injectors during tuning would give the definitive answer.
Bryan
My Build Journal
Old 03-14-2014, 10:48 AM   #13
jake2212
jake2212's Avatar
Drives: none (yet)
The person I am buying the Maggie off of is also giving me a zl1 fuel pump, but he doesn't have injectors
Old 03-14-2014, 04:23 PM   #14
jake2212
jake2212's Avatar
Drives: none (yet)
So IF this a complete kit(not the tuner version) all I should need is a zl1 pump and injectors?
