04-29-2013, 06:23 AM | #1 |
Drives: 2010 Black 2SS/RS Join Date: Feb 2012
Tunnel brace?
Installed LG exhaust system, is it normal to have to lower the tunnel brace more than 1 1/2?. Just doesn't seem right, might just be me. Thanks
04-29-2013, 06:25 AM | #2 |
knows 2 facts about ducks
Drives: ...and they're both wrong Join Date: Aug 2009
Is it a 3" system?
04-29-2013, 06:37 AM | #3 |
V8 Lounge member #2
Drives: 2001 Ws6 Join Date: Sep 2009
Or you can just get rid of it. It's up to you.
2001 ws6, 40k miles, Ls3 416 stroker, short block built by PER the rest by me. LPE Ls3 heads milled to 12-1 comp, FAST 102, NW 102, kooks 2", dual DMH cutouts, Magnaflow C/B, BTR cam + springs. Full UMI suspension.
04-29-2013, 06:41 AM | #4 | |
Off topic - Did I ever mention to you we have a car club here in central SC ( Cola, Lex, Chapin, Irmo - etc.)? I handle membership if you are interested. We have a lot of modded Gen 5 Camaros in the club so we help each other out with info and ideas a lot. Let me know if you are interested.
04-29-2013, 06:43 AM | #5 |
Yes it's 3". I was going to get rid of it but I thought I seen it helps keep the floor boards or something from collapsing. Kind of seems like it helps structurally in some manner.
04-29-2013, 06:54 AM | #6 |
Sellin Chevy's since '06
How much bracing does the tunnel brace apply?
'19 Z06-7Speed and lowered on stock bolts
'02 Z28-Kooks true dual headers/TSP heads&cam/full suspension & Kmember sub40K orig miles. https://youtu.be/h6faSdcvNew TRADED!'17 ATS-V Coupe w/ Carbon Black pkg https://youtu.be/GH_t-R-TJV0 SOLD! '18 ZL1 Mosiac Blk SOLD!'16 SS Sedan-Forgestars/ARH/rotofab TRADED!2014 SS Sedan SOLD! 2013 Blue Ray1SS/1LE 1of20. TRADED! 2012 White 1SS/RS |
04-29-2013, 07:50 AM | #7 |
ʇuɐıʌǝp lɐıɔos
Drives: 2011 2SS/RS LS3/M6 Join Date: Feb 2011
I have 1 7/8" LTs, high flow cats and Flowmaster AT (3") and 1" clearance at tunnel brace. If it looks like there is room for pipes to go up more, I would jack car up then loosen all clamps. Use a wood block on floor jack to raise pipes then tighten clamps and let jack down. Just be careful when raising pipes not to force it and crush something.
04-29-2013, 08:17 AM | #8 | |
It supplies bracing to the driveshaft/exhaust tunnel in the event of a side-impact collision. Without it the tunnel would get crushed - possibly doing more damage to your drivetrain, etc. than what would have happened from just the accident. |
04-29-2013, 08:26 AM | #9 |
Look at the X-pipe. Does it have a bend or bow in it? Having this bend or bow and installing it upside down will cause you to have to space out your tunnel brace excessively. I have no experience with LG, but the ARH X-pipe has this bend.
ProCharger P1X, Vengeance Racing Kaotic Cam, ARH Headers and Exhaust with Borla ATAK mufflers, MGW Shifter, MTI Drop Springs, Forgeline RB3C Wheels, 3.91 gears, Night Owl LED Control System
04-29-2013, 10:14 AM | #10 | |
04-29-2013, 10:46 AM | #11 | |
Drives: 2010 SS L99 Inferno Orange Join Date: Apr 2012
04-29-2013, 11:10 AM | #12 |
Drives: 2010 Camaro 2SS M6 Join Date: Jan 2010
My tunnel brace would not clear without use of a spacer (in my case, a stack of washers). I started with at least an inch drop, but later the exhaust would contact the brace when going over bumps. I added at least another 1/2" drop to prevent contact.
2010 SS/RS LS3
LG Longtubes & Full Exhaust, CAI, Jannetty 470 cam & tune, Phadt Trailing Arms |
04-29-2013, 11:42 AM | #13 |
Drives: Chevys at the limit Join Date: Nov 2010
Sometimes you can get more clearance by loosening up the connections and jacking up the exhaust system and re-tightening. It will be close, but not that far off.
Best regards, Tyler 888-308-6007 |
04-29-2013, 11:47 AM | #14 |
Drives: 2010 camaro ss Join Date: Nov 2012
remove it.
