02-13-2017, 08:39 PM | #1 |
Drives: 2017 50th Anniversary 2SS Join Date: Sep 2016
Disable stock sound tube
Is there an easy way to essentially disable the sound tube without actually removing it? I know some of the aftermarket cold air intakes have versions that permit you to completely remove it but for now I'd just like a way to bypass it. I was thinking if you disconnect it from the firewall and put a plug or cap on the firewall side do you need to also cap the tube side as well?
Thanks! Sent from my iPad using Tapatalk
02-13-2017, 09:25 PM | #2 |
Drives: 17' 1LE BLK Join Date: Nov 2016
what is this sound tube you talk about?
02-13-2017, 09:27 PM | #3 |
Drives: 17 SS 1LE Join Date: Dec 2015
Do the 4-cyl Camaros and ZL1 have a plug in the firewall where the SS sound tube would go? We can use that if there is a part number.
02-13-2017, 11:50 PM | #4 | |
Lethal Camaro
Drives: 16 2SS, 71 Std, Suburban RTS Join Date: Jun 2013
02-14-2017, 04:33 AM | #5 |
Drives: 2016 Camaro 2SS Join Date: Nov 2016
Just curious why one would want to disable the sound tube in the stock or aftermarket intake?
Sent from my iPhone using Tapatalk |
02-14-2017, 06:34 AM | #6 |
Personally for me I think it ruins the true sound of the car. I run my NPP exhaust in track mode so I can hear my throttle just fine while rolling through the gears but then say I want to speed up even more when all of a sudden the sound tube kicks in unnaturally up front and just doesn't sound very good to me at all.
02-14-2017, 08:04 AM | #7 | |
Drives: 2019 Dodge Challenger Scat Pack Join Date: Jun 2016
Sent from my VS500 using Tapatalk
"Submariners are a bunch of intelligent misfits that somehow seem to get along, understand each other and work well together." - overheard from a surface officer explaining to another sailor about Submariners
02-14-2017, 08:24 AM | #8 |
Drives: 2017 2SS Join Date: Jun 2014
Jeremy Clarkson said something about this a few years ago on Top Gear. I forget what car it was, but he mentioned that it was so nice being able to hear the air intake and engine of a car for once, instead of just the exhaust.
When I put an OTR (Over The Radiator) intake box on my G8, I could all of a sudden hear both the engine AND exhaust. It sounds MUCH better. Kind of like when you are listening to a guitar solo, and then all of a sudden a bass guitar joins in. You liked the regular guitar, but the bass provides a great backdrop sound that only enhances what the guitarist is doing. |
02-14-2017, 08:28 AM | #9 | |
02-14-2017, 08:31 AM | #10 |
Drives: 2017 Camaro 2SS 6MT Join Date: Aug 2006
At least it's natural unlike the silly soundtrack other companies program into the stereo system.
02-14-2017, 09:30 AM | #11 |
It doesn't sound natural to me. It's like an intake gurgle pulsing sound that just suddenly comes on like a switch at heavy throttle conditions.
The natural engine/exhaust note comes in and grows in volume as one would expect based on speed/RPM, etc.
02-14-2017, 09:54 AM | #12 | ||
Drives: None Join Date: Nov 2016
Of course, internet youtube videos don't do this justice, but here is an example. The sound tube in this car doesn't really do much in my opinion.
-Brian
Hyper Blue 1SS / 1LE |
02-14-2017, 11:15 AM | #13 |
FMPG
Drives: 2016 2SS Join Date: Dec 2015
I use mine to run wiring for my front sensors to my control unit for my jammer. It was one of those things that I thought was pointless in the car until I noticed how it easy it made it to connect everything lol.
ARH 1 7/8" ceramic coated full sys w/NPP; Maggie 9.2psi (85mm); Jannetty rough idle cam(TSP), tune and LT4 fuel system; Forgeline VX1 Black PVD (20x10,11); R88R 315's; ALPriority; BMR rear arms, bushings, DS loop; RF intake (red); nGauge 93 octane: 712rwhp, 654rwtq / E85 (E66 mix): 734rwhp, 674rwtq (SuperFlow Dyno) |
02-14-2017, 12:22 PM | #14 |
Drives: '17 Red hot 2ss, 16 Focus RS Join Date: Aug 2015
