Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Wheels and Tires Talk Sponsored by The Tire Rack
Old 05-25-2014, 12:52 PM   #15
scott53
scott53's Avatar
Drives: '19 Camaro 2SS, '12 GMC Yukon
The P-Zeros are of a fairly soft compound. Stop and go driving, short trips with a lot of stop signs and red lights accelerates wear. Another major contributing factor to tire wear is the road surfaces on which you drive. Here in SW PA our asphalt roads and tar and chip roads are like driving on 80-grit sandpaper. Grooved concrete is not helpful either. My ’10 6-cylinder Camaro has a little over 13,000 miles on it and the rears are about worn out. The fronts are fine. I don’t drive it aggressively at all and have never done a burnout. I’m debating whether to stay with the P-Zeros or switch to something else.
Even worse was my ’10 Corvette Grand Sport. It wore out the front tires at 5500 miles. And that was with me checking and adjusting the tire pressure every time the temperature changed 10 degrees. My dealer was able to get Goodyear to contribute to replacing those. The Michelins on my ’14 Stingray seem to be wearing far better than the Goodyears that were on the GS, and they are noticeably quieter too.
scott53 is offline   Reply With Quote
Old 05-25-2014, 03:00 PM   #16
ytown87
ytown87's Avatar
Drives: C6 Corvette
Got my car with 38k on it and im now at 47k. Tires were about 80% when I bought the car. Im now down near the wear bars. A few good burnouts on the street and I def burned them up at the drag strip. Will proly replace soon. Id imagine I burned and raced off about 5k that couldve been saved
2008 C6 m6. Carbon creations front/rear carbon fiber wodebody fenders. Carbon fiber hood carbon fiber roof hoop carbon fiber zr1 extreme spoiler. NW 102mm tb. Ported intake manifold. Cometic .040 head gaskets. LG motorsports G6x3 cam. DSX flex fuel sensor. AEM methanol kit. Z06 brakes. Ebiach sway bars. ZR1 rep wheels and Nitto Invo tires. Monster stage 3 twin disc clutch. MGW short shifter. Corbeau race seats. Gforce race harnesses. SLP loudmouth 2 mufflers. Carbon fiber exhaust tips. RPM stage 4 transmission and Stage 3 rear diff. 3.73 gears. Vararam cai. Kooks 1 7/8 headers and x-pipe.
ytown87 is offline   Reply With Quote
Old 05-25-2014, 03:15 PM   #17
LuSe4
LuSe4's Avatar
Drives: 2013 Camaro 2SS RS LS3
If you honestly have never done a burnout, maybe you should get your alignment checked.
-2013 Summit White over Inferno Orange 2SS RS-
-2014 White Diamond Silverado Z71 Crew Cab Short Box-
LuSe4 is offline   Reply With Quote
Old 05-25-2014, 03:41 PM   #18
45thAnniversary2SS
45thAnniversary2SS's Avatar
Drives: 2012 45th Anniversary 2SS LS3
Originally Posted by Childs Play View Post
Weird. I got 36k out of mine and beat the hell out of it.
+1. Got 30k out of mine and didn't baby it.
How much air pressure you keep in them?
45thAnniversary2SS is offline   Reply With Quote
Old 05-25-2014, 08:55 PM   #19
3rdgen3
10-bolt Destroyer
3rdgen3's Avatar
Drives: 2012 Camaro 2SS/RS - AGM, LS3/6M
I wonder who else has driven your car and burned the tires off FOR you
2012 Camaro 2SS/RS - LS3/TR6060: Cam, Headers, Exhaust, Intake, Gears, Twin Disk, Suspension, Tuned - 475rwhp, 443rwtq
3rdgen3 is offline   Reply With Quote
Old 05-25-2014, 09:03 PM   #20
VR Baron
SoCal Camaro5 Race Team
VR Baron's Avatar
Drives: 2021 Shadow Grey Camaro 2SS 1LE
I envy you guys. Mine only went 19000 and my Invos will go 9000. I guess 325 auto x laps and a dozen 1/4 miles runs and canyon carving may possibly have something to do with it..lol
VR Baron is online now   Reply With Quote
Old 05-25-2014, 09:14 PM   #21
3rdgen3
10-bolt Destroyer
3rdgen3's Avatar
Pffftt 19,000miles is weaksauce!
My stock rears lasted less then 3,000miles! More like 1,800
Old 05-25-2014, 11:54 PM   #22
brizenowu
Drives: bmw
I could probably squeeze another 500 to 100 miles out of them but wont.
brizenowu is offline   Reply With Quote
Old 05-26-2014, 12:08 AM   #23
VR Baron
VR Baron's Avatar
we have a winner!
Old 05-26-2014, 07:26 AM   #24
Bucci
Bucci
Bucci's Avatar
Drives: 2010 2SS M6
I'm at 28K with good tread left
Bucci
Bucci is offline   Reply With Quote
Old 05-26-2014, 09:38 AM   #25
SS4PK
SS4PK's Avatar
Drives: 2010SS
Tires are just the cost of doing business. Go get a 4 cylinder four door car and you can get tires to last 50,000 miles. I don't do burn outs and I replaced the rears at 20K, 33K, 45K and I'm due for new ones now at 55K. You can get harder tires to last longer.
Her Hot Rod.
SS4PK is offline   Reply With Quote
Old 05-26-2014, 09:49 AM   #26
Jackass
Doing what I like to do
Jackass's Avatar
Drives: 1963 Landrover
So your miles per set are continuing to decrease , something is not right
Either you , the car or most likely both , need to get something done
Jackass is offline   Reply With Quote
Old 05-26-2014, 12:34 PM   #27
K1SSRSS
Chief Many Camaros
K1SSRSS's Avatar
Drives: A paid off Camaro!!!
I got about 28k out of mine including trips to the dragstrip. Only the rears were down to the wear bars and the fronts had about half their life left.
504hp/478tq
Performance: Kooks LT, 3'' Exhaust, V-Max TB, Roto-Fab CAI, Custom Ported/Port Matched Heads and Intake
Suspension: BMR Adjustable LCA's, BMR Trailing Arms, Poly Bushings, BMR Toe Rods
Coming Soon (still in the box): Procharger F1R, G-Force Axles, 3:91 gears w/Eaton Truetrac
K1SSRSS is offline   Reply With Quote
Old 05-26-2014, 12:50 PM   #28
SGOS252382
SGOS252382's Avatar
Drives: 2010 Camaro 2SS/RS
There's no way you guys are getting 30K miles out of a set of P-Zeros and you do burn outs and have fun with your car. It's just not possible.
I went through two sets of P-Zeros and only got around 8k miles out of the rears.
I would have to drive extremely conservatively with pretty much no burn outs to get anywhere close to 30k miles. P-Zeros are soft tires and they do not last long if you drive aggressively.
I think Scott got about 5k miles out of his with a heavy right foot.
I'm sorry, but 30K+ miles on a set of P-Zero rear tires = hand over your keys to your daughter and let her show you how to have fun.
SGOS252382 is offline   Reply With Quote
