dave@hennessey
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6)
Old 04-21-2011, 07:37 AM   #29
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
Originally Posted by mpiper View Post
I'm subscribed. One of my long term goals is to drop a posi 3.7/3.73 rear in. No rush, I want the warranty a bit longer on the stock drive-train so if anything breaks in the first year to 25k miles it's covered, but after that, the posi's going in. So as long as we have a solution, even if it's a custom drive-shaft or something similar, I'm game.
Last time I did this (with a 79 Grand Prix, so no comparison), I just took the stock drive-shaft, had the shop make measurements and a local shop did the cut&weld to give me a custom drive-shaft from the stock original. I'm hoping to do the same with this one.
I look forward to seeing it.
Apex Motorsports is offline   Reply With Quote
Old 04-21-2011, 12:51 PM   #30
Rich1
Rich1's Avatar
Drives: 2023 ZL1 Camaro Hot Red
Here is some additional info I found at:
http://www.differentials.com/faq.html
What gear ratio do I need?
Differential Gear Ratio determines the number of times the drive shaft (or pinion) will rotate for each turn of the wheels (or ring gear). So if you have a 3.73:1 gear ratio the drive shaft turns 3.73 times for every turn of the wheel.
Gear ratio is calculated by dividing the number of teeth on the ring gear by the number of teeth on the pinion gear. The higher the number, the lower the ratio: a 5.29 gear has a lower ratio than a 4.10 gear. With a lower gear ratio the drive shaft (and thus the engine) turns more for each revolution of the wheel, delivering more power and torque to the wheel for any given speed. Lower ratios are generally desirable when going off-road. Higher ratios are better for freeway driving since they run at lower RPM's and offer better fuel economy.
Changing tire size affects the final drive ratio. Switching from a 30" tire to a 35" tire changes the final drive ratio by about 17%. This may drop the engine out of its' "power band" and result in poor performance and fuel economy. To restore performance you must change the gear ratio to compensate for the change in tire size. If you originally had 3.07 gears you need a ratio that is approximately 17% lower, such as 3.55. If you want to increase off road performance you might want a 4.10 or lower ratio.
Rich1 is offline   Reply With Quote
Old 04-21-2011, 04:15 PM   #31
Maurdib
Maurdib's Avatar
Drives: 2010 Black Camaro 2LT/RS Auto
So for us A6 V6 guys, how much MPG's can we expect to lose on the highway vs how much could this improve the 0-60 times?
BackInBlack
Performance:Vararam cold air intake
Maurdib is offline   Reply With Quote
Old 10-15-2011, 10:41 PM   #32
Robbie1227
Robbie1227's Avatar
Drives: 2015 Camaro Z28/2016 Jeep Sahara
Chase,
I have a slightly modded and tuned 2010 SS and am considering doing my rear end.
It's my daily driver, but I take it to the road track a several times a year for some fun. I would really like some more low and mostly mid range power to accelerate me out of the turns quicker, so I can haul down the straights.
Do you think 3:73 or 4:11, I am putting down 400 rwhp and 389 rwtq right now.
Rob
2015 summit white Z28 #120 TRK DAY
-Sun-Tek PPF-C protection film on 2/3 of the car, Moreno Camber plates, American Racing 2" ceramic coated LT headers and X-pipes with No Cats, Taylor red performance wires, NGK plugs, BTR Stage III Cam, MSD Atomic intake, Nick Williams 102mm throttle body, Stage 2 CNC Ported Heads by WCCH, MGW short throw shifter, oil catch can, and a dyno tune to get me to 587 RWHP and 516 RWTQ
GONE:
2013 Summit White Camaro ZL1 M6
Roto-Fab CAI, Kooks headers and CAT delete, ATI damper and 10% pulley and balancer!
Results: 576 RWHP - 540 RWTQ
Robbie1227 is offline   Reply With Quote
Old 04-24-2017, 02:12 AM   #33
wsmith
wsmith's Avatar
Drives: 2011 LS
What's the difference between swapping the gear ratio and moving to a V8 differential in a V6? When is it beneficial to sway to a V8 one? If I swap to a V8 differential before putting down enough horsepower, will I LOSE performance or have any adverse effects? But if I lay down enough horsepower before swapping the differential, will I damage anything?
MRT V 1.0, Injen intake, ICE-olator, JVC Stereo, Alpine speakers, 600-w Amp, 10" Subs
wsmith is offline   Reply With Quote
3.73, 4.11, gears, rear differential, rear end gears
Richmond Gear Camaro gears RichmondGear V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 85 01-19-2015 10:43 AM
Tune, gears, warrantee, all that stuff again...but f5journal Tuning / Diagnostics -- engine and transmission 6 02-25-2011 10:13 AM
Why does Camaro have lower skidpad numbers than CTS-V? OldJedi Suspension / Brakes / Chassis 9 06-22-2010 06:00 PM
Fastlane Tune - Are these numbers good? Dangeruss Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 58 03-14-2010 11:38 PM
Thinking of Painting my Camaro. Scott@Bjorn3D Cosmetics and Lighting Modification Discussions 24 12-26-2008 04:59 PM
