03-31-2023, 10:10 AM | #15 | |
GPI Sales Consultant
GPI Max Package 2.0: Brodix BR7 heads/GPI porting, MAX3 cam, ST2116LSR, BSR Max Lift rockers, LS7 LSXR with 103mm TB, Vararam OTR, Mcleod RXT, G-Force/Strange 9" IRS setup with 4.63 gear. 551whp, 11.1@124mph.
Got a question about a GPI product? Feel free to shoot me a message! |
03-31-2023, 01:43 PM | #16 | |
Drives: 2010 2SS LS3 and 1978 STROKER 383 Join Date: Feb 2018
I like this. I already thought that I was at the end of the engine modifications (I don't want to open the OEM LS3 engine) and I see that there is also place for improvement here.
My life is a constant struggle with Camaro.
K&N CAI, Stainless Power longtubes, high flow cats, modified Ragazzon High Performance axle back, Soler Performance ported throttle body, Soler Performance throttle controller, RAM clutch adjuster, modified LS7 clutch kit, Tick Performance billet bearing support, Tick Performance remote bleeder, separate clutch reservoir, BMR trailing arms, BMR toe rods, Pedders Suspension cradle bushing inserts, Control Arm Bushings, Strut tower brace, oil catch can, Hurst T-handle shifter, 20mm wheel spacers, DBA brakes, QTP Cutouts, Dynosteve tune. |
04-01-2023, 03:21 AM | #17 | |
What values need to be recorded for the tuner from datalog to be able to adjust the fuel map correctly from this? I recorded the datalog for the ported throttle body, but I don't remember what values I selected. But I assume they will be the same. ..or not? Unfortunately, I don't have the dyno option, so I solve it via remote tune.
04-01-2023, 07:57 AM | #18 | |
04-03-2023, 02:59 PM | #19 | |
O.K. I thought there was a general template for this. Then I will discuss it with Dynosteve when it is up to date. Now I will finish the project with my 2nd gen. and then I would start tackling this next upgrade. Thank you
06-08-2023, 04:35 AM | #20 |
I guess it's time to move on again. I'm looking for a better intake. I have GPI ported with the Rod Mod in my cart.
But before I confirm the purchase, I want to make sure I'm on the right track. I basically have an OEM engine with light upgrades like most here. Headers, cats, exhaust, ported TB, tune... Is GPI worth the next step?
06-08-2023, 06:09 AM | #21 |
Drives: 2013 Camaro 2SS AGM Join Date: Apr 2020
George,
The 1st mods on my old L99 were a GPI ported tb/intake/headers & tune. It really woke the car up & Andrew is spot on with the seat of your pants feel @ 3500-5000 rpm. A lot of people questioned why I would want a 415 after those mods.
2013 2SS GPI built & tuned 415, spec'd by Andrew Cammer. GPI ported intake/tb/heads, Tooley springs, CHE trunnions, Callies rotating assembly, Diamond pistons, GPI SS3 VVT, ATI 10% ud damper, Circle D 3800, Kooks ceramic coated lt's with green cats, Mishimoto rad & oil cooler, Derale trans cooler, Holley efi rails.
06-08-2023, 07:12 AM | #22 |
Drives: 2014 2SS/RS 6SP Ashen Grey Join Date: Aug 2021
George, I noticed the change right away, its an easy install as well. I recommend it.
GM 3.91/TrueTrac OEM ZL1 Rims, Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,Remote Clutch reservoir
GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, Moroso Catch Can GC Aluminum DS Stainless Works Ceramic LTH/HiFlo Cats SCT X4 Dynosteve, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights AeroForce Dual gauge/Autometer pillar mount. |
06-08-2023, 09:26 AM | #23 |
acutron42 and Joe.G: Well, good gentleman's... You talked me into it. I'm going to order it
06-08-2023, 09:32 AM | #24 |
I also added the hear shield underneath, does it do anything I am not sure but figured while it was off I might as well.
06-08-2023, 09:44 AM | #25 |
Hey George, from all the posts I have read about happy people who got the GPI ported and rod modded intake on here, it is a sure way to go with a "lightly" modded Camaro such as yours. Heck even the cammed guys running them love it!! If I hadn't done the LOD, I would have gone that route! Just might still.. You can't go wrong.
06-08-2023, 10:40 AM | #26 |
Drives: 2012 Camaro SS Join Date: Dec 2019
I have it on mine with the heat shield because why not lol. Was a quick install and sent back my old one. Did a remote tune shortly after with DynoSteve and I must say there was a nice mid range improvement even before the tune. For the price it’s the best around dollar for dollar.
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
06-08-2023, 10:45 AM | #27 |
I went with the heat shield as well.
06-08-2023, 11:07 AM | #28 |
Bigdumogre did you have a tune prior to the one you did for the intake? Did Steve just update tune for intake? Just curious if there a noticable difference tuned for intake.
