07-28-2022, 12:44 PM | #29 |
Recalled user
Drives: '12 Camaro SS, '18 Colorado Z71 Join Date: Mar 2009
This is really cool actually.
2012 2SS 45th AE LS3 M6 Borla ATAK Catback Kooks Stepped LT Headers CAI Intake Hexvents VMAX CNC Ported Throttle Body RX Catch Can Hurst Short Throw Shifter Pfadt ZL-Spec Stage 3 Suspension Forgestar F14 Tuned by Frost |
07-28-2022, 12:58 PM | #30 |
Drives: 2015 SS 1LE Red Hot, 1970 Chevelle Join Date: Apr 2012
Isn’t that what the Z71 was supposed to be? They should have made the Z71 the version with the factory lift and wider track.
07-28-2022, 01:02 PM | #31 | |
General Motors Aficionado
Drives: 2023 GMC Canyon, 2020 Colorado Join Date: Aug 2008
If they're following Silverado's lead the Trail Boss would be what gets the factory 2 inch lift. Z71 does have a 1 inch lift over the W/T and LT.
2023 GMC Canyon Elevation 2020 Chevrolet Colorado W/T Extended Cab (State-issued) |
07-28-2022, 01:13 PM | #32 |
Recalled user
It looks like halogens are still in use here as well except for Z71/ZR2 if I read that properly. It always annoyed me I "had" to buy expensive LED bulbs for my truck. The headlights especially left a lot to be desired otherwise.
07-28-2022, 01:25 PM | #33 |
Yep looks like it. I'm hoping there's a lighting package available on LT. I have no need for 4WD with Z71 but I do want the LED lighting.
07-28-2022, 01:34 PM | #34 |
Recalled user
I hear you, but in 2023, anything other than WT should be LED. Like I said, I see where they chose to cut costs here and there. I don't see any mention of power sliding rear window either which is a common complaint all over the forums as well.
07-28-2022, 01:50 PM | #35 | |
Drives: 2017 Camaro 1SS, 2023 Colorado Z71 Join Date: Sep 2017
https://www.chevrolet.com/upcoming-v.../2023-colorado
2017 1SS, Summit White, Black 2SS Interior, MRC, NPP
2023 Colorado Z71, Nitro Yellow |
07-28-2022, 01:58 PM | #36 |
Recalled user
I can't believe it. It's completely worthless. I don't ever think about opening it until i'm already driving, and if I do, I often want to close it without stopping. Oh well. It's a minor quibble. I just had hoped they were listening.
07-28-2022, 02:02 PM | #37 |
That entire rear window assembly looks carryover from the current model so I'm not surprised.
07-28-2022, 02:38 PM | #38 |
Recalled user
Hope this is true:
"Base WT (Work Trucks) and LT models will have 237 hp and 259 lb-ft of torque. A Plus version of this same engine with 310 hp and 390 lb-ft of torque will be standard in Z71 and Trail Boss models while available in the WT and LT trims. The enthusiast-oriented off-road ZR2 model returns and has 310 hp and 430 lb-ft of torque from a high-output version of the turbo-4, which will be available as an option on all trims with a confusing caveat: WT and LT buyers will have to option up to the Turbo Plus and then from there the High-Output engine when ordering their trucks." I guess it's just the tune varying outputs. Global B is going to make it hard on the aftermarket so I guess buy the tune you want up front?
07-28-2022, 02:45 PM | #39 | |
it states that the high output engine has max towing of 7700lb, but despite not stating that it is available for Z71 and below in the Availability column, states that ZR2 can only tow 6600. I wonder if it requires 4WD for WT and LT
07-28-2022, 04:05 PM | #40 |
That doesn’t make sense to me. I either get a lesser interior or lesser performance. Their thought process really needs to get adjusted. They get it like 90% right every time but always miss on the last 10%.
07-28-2022, 04:06 PM | #41 |
I do have a small gripe.
ZR2 appears to get a full instrument display. Every other trim gets an 8 inch display. That sounds fine in theory, but the execution looks a little lazy.
07-28-2022, 09:16 PM | #42 |
Drives: No Camaro :( Join Date: Apr 2013
They all look good to me, still a year out before showrooms see em.
