TireRack
Old 02-16-2021, 02:28 PM   #1
chevy1234
chevy1234's Avatar
Drives: 2015 Chevy Camaro 2SS Green Flash
Magnuson 2650 hood clearance?
Hey all,
First off, I did run searched on here and online and couldn't find the exact answer I'm looking for, so apologies if this has been asked already.
Second and most important. I've been offered a Magnuson 2650 hot rod kit, from a friend who's getting a 3100, for my 2015 Camaro SS LS3 (eventually will be swapped for a built 427). I am wondering if anyone knows what kind of hood clearance modifications are required to make this work?
I know it doesn't clear factory hood, but more curious on how much of a cowl I would need.
I do know the COPO hood works which has a 3" cowl, but can it work with a 1" or a 2"?
I don't want to cut the the hood but I could be persuaded depending on what it would look like. Has anyone done this to their fifth gen? any pics?
Thanks in advance for any input you can provide.
chevy1234 is offline   Reply With Quote
Old 02-16-2021, 03:36 PM   #2
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Here is a vid of one on a 5th gen ZL1 and you can see the hood has been cutout, and see how tall the SC is.
1JEWLDSSRS is offline   Reply With Quote
Old 02-16-2021, 03:49 PM   #3
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
On this 5th gen you can get a good look of how tall it is, and that he had to also trim the cowl section behind the blower a bit for it to fit..
https://www.bing.com/videos/search?q...%26FORM%3DVDRE
Old 02-16-2021, 03:57 PM   #4
Scotty D
Drives: 2014 1le 1SS CRMT
Looks like you have to clearance the rear fire wall too
Looks very involved besides the hood
Scotty D is offline   Reply With Quote
Old 02-16-2021, 04:01 PM   #5
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
And here is his install vid.
https://www.bing.com/videos/search?q...6FORM%3DVDVVXX
Old 02-16-2021, 04:02 PM   #6
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Hopefully this is the SC he is referring to!! lol. Looks pretty involved to me too!!
Old 02-16-2021, 04:12 PM   #7
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
On a 6th gen.. This one is huge!! lol.
Old 02-17-2021, 08:48 AM   #8
chevy1234
chevy1234's Avatar
Thanks for all the videos JEWLD, i've looked at those countless times lol. I'm just not a fan of big cowls, so I was hoping that someone knew a 1" or 2" would fit. I read in the comments of the first video they cut up the hood and then eventually switched it out for a COPO hood which is a 3" cowl. Either way, thanks for the input!
and yes the cowl under the windshield needs to be cut for the jackshaft/rear of the blower can clear, this i don't mind modifying.
Old 02-17-2021, 09:25 AM   #9
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
You are welcome sir!! Hope you get it figured out and get it installed. Will be a monster for sure. Good luck..
Old 03-13-2021, 10:36 AM   #10
ss/rs/378
ss/rs/378's Avatar
Drives: 2012 ZL1 Camaro Victory Red
Magnusson told me 11.5" from the valley plate to the top of the 3100 the kicker was there drive unit was another 4K so 11K for that unit no thank you.
2.55 UPPER PULLEY,100MM IDLER PULLEY,160 STAT,PORTED TB,PORTED SNOUT,MSD PLUG WIRES,NKG PLUGS,KENNE BELL EXTERNAL FUEL PUMP,2"KOOKS HEADERS,HIGH FLOW CATS,3"CORSA 60LB DEKA INJECTORS TUNED BY FROST 580RWHP,571RWTQ.
ss/rs/378 is offline   Reply With Quote
2650, 5th gen, ls3, magnuson, supercharger
