07-29-2013, 10:12 PM | #1 |
Drives: 2010 camaro 2ss Join Date: Feb 2011
underdrive pulley feedback
can anyone tell me how different the car drove after the under drive pulley install? noticeable improvement ?
2010 2ss L99
Mods: ADM race intake, ADM scoop w/ washer bottle, SLP long tube headers, SLP 25% UDP, SLP Loud Mouth 2 exhaust, Vmax TB, BER intake manifold,3.45 gears, MSD wires, SLP 160 t-stat, SLP Springs, EFI live tune by Redline Motorsports |
07-29-2013, 10:27 PM | #2 |
I consider a UDP one of those since I'm in here mods to do when you do a cam. I don't feel the return is worth the trouble unless you already have a reason to have the factory pully off. Car is not going to drive differently, but the butt Dyno might be able to feel it a little. Don't even waste your money on a 10% UDP, get a 25% one.
ProCharger P1X, Vengeance Racing Kaotic Cam, ARH Headers and Exhaust with Borla ATAK mufflers, MGW Shifter, MTI Drop Springs, Forgeline RB3C Wheels, 3.91 gears, Night Owl LED Control System
07-30-2013, 05:50 AM | #3 |
Drives: 2012 2SS/RS LS3 Join Date: May 2012
I agree with Mickey. Only bother with it if you are doing something else that requires the labor to pull the old one off. My car drives fine with it. Zero problems.
Victory Red 2012 2SS/RS LS3 Camaro
Pat G. Spec Cam from Cam Motion 228/236 .599/.599 112+2LSA Kooks 1-7/8" LTs w/ Cats Roto-Fab, Bo White TB, Borla Touring Catback 3.91 1LE Gears, MGW Tuned by Pat G |
07-30-2013, 10:52 AM | #4 |
Drives: Camaro Join Date: Apr 2009
We typically see 8 rwhp from a pulley install.
Hang tight, we are finishing up a run of TSP's new underdrive pullies & I promise the price will be nice! |
07-30-2013, 12:22 PM | #5 | |
Drives: 2010 RS/SS Join Date: Dec 2010
07-30-2013, 12:46 PM | #6 |
come find out;)
Drives: stockish 2012 camaro ss Join Date: Oct 2012
Do you got a projected time when it'll be out? I'm about to order my long block from you guys and would like an under drive pulley very much to go with it.
07-30-2013, 12:57 PM | #7 |
It will rev quicker, and yes pickup 7-8 hp/tq
07-30-2013, 01:02 PM | #8 |
Drives: 2SS/RS - Black - GFX Join Date: Nov 2008
but if you stall in parking lots when taking tight turns at low rpm (like I do because of having a big cam)... an underdrive pulley will make it worse (reduced power steering pump power).
Ordered: 10-13-08
Built: 3-30-09 (#1691) Recieved: 6-12-09 Blacked out, Cammed (Lunati Voodoo 233/245, .578/.598 @114°, +4°), ARH LTs, VR OTR CAI, Cutouts, and lots of other fun mods. |
07-30-2013, 01:38 PM | #9 |
Drives: 2011camaro SS Join Date: Nov 2012
On my car, I noticed that if I sit in the parking lot at work like I sometimes do at lunch, it will go into Battery Saver mode on the DIC and the AC will reduce power. But I'm a bit different, due to the fact that most of my driving is under 35 mph commute to and from work so rpms dont turn that high to charge the battery. Not to mention I have a BIG A$$ stereo system with 2 BIG AMPS.
07-30-2013, 02:17 PM | #10 |
Writer
Drives: 2010 SS / 1967 Camaro Join Date: May 2009
Your stereo is most likely the culprit, I commute today I never went above 30 mph. I have 9,000 miles on my 25% underdriven pulley, trouble lights or battery issues. I did 3 other mods at the same time so can't comment on the performance.
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II 13.15@106 1.95 | 100% Stock 12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune 12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune 11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts 10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800 |
07-30-2013, 02:51 PM | #11 |
Drives: 2010 2SS Join Date: Jan 2013
its about 8-12 hp and about .1 off the 1320' for 300$.. if u can justify that, then I say its well worth it.
07-30-2013, 04:04 PM | #12 |
Drives: '13 ZL1 725 rwhp / 700 ft lb tq Join Date: Jul 2009
Does the 8-12 hp numbers increase to a bigger number, if you have done heads and cammed already? Or is it a static number?
'13 Black Manual trans , Heads, Cam, Injectors, Ported Snout, Vmax throttle body, RotoFab, Headers, No Cats, 9.55 lower pulley, D3PE heat exchanger, - 725 rwhp/700 tq
07-30-2013, 05:25 PM | #13 | |
For those with cams and stalling and/or charging issues - might the idle be too low more so than impact from a UD pulley? OP - I did my UD pulley with the cam swap. As others have said I can't recommend it as a stand alone mod.
07-30-2013, 05:35 PM | #14 |
Drives: 2012 ZL1 & 2010 2SS/RS Join Date: Jul 2009
I would not do a pulley unless I was doing a cam. The install is a pain on it's own for the little bit of gain you get. Thanks!
