07-16-2013, 12:45 PM | #1 |
Drives: 2018 GT350 Join Date: Nov 2011
Motor Mounts Advice
I have a question in regards to motor mounts.
I recently installed a set of headers and due to the flex of the motor (or weakness of the motor mounts) and the weight of the car in a turn, i get contact between the frame and the header (when the car is off, there is only about 1/2" clearance between the two). To solve this, I'd like to put in a more rigid motor mount to stop the torquing of the motor and minimize the impact the momentum of the car has and try to eliminate this contact. I've seen several threads for motor mounts, but I was wondering if I could get some advice on WHICH I should be looking for. Car is a car that does not see the track, but can be driven spiritedly, so super rigid for track wise is not needed. I appreciate the advice. Thank you!
Off to the Dark Side
07-16-2013, 12:51 PM | #2 |
Drives: pleather and Chiclets Join Date: Mar 2012
i am cammed and have headers and the shake and rumble does not create any fitment issues with my kooks.
some people have moved their engine slightly but i wouldnt recommend that unless they are not squared on the mounts. another fix people have used is to dimple the headers...again wouldnt recommend that. what size headers and what brand? there are brands out there that wouldnt stand for improper fitment and will make it right or tell you how to.
07-16-2013, 01:03 PM | #3 |
Drives: 2SS/RS - Black - GFX Join Date: Nov 2008
^^ this
Don't change engine mounts to compensate for poorly made headers... However, I have thought about changing my mounts because of engine rock caused by my cam. What mounts did you go with?
Ordered: 10-13-08
Built: 3-30-09 (#1691) Recieved: 6-12-09 Blacked out, Cammed (Lunati Voodoo 233/245, .578/.598 @114°, +4°), ARH LTs, VR OTR CAI, Cutouts, and lots of other fun mods. |
07-16-2013, 05:55 PM | #4 |
PHAT B33
Drives: 2012 TF3 Camaro 2SS/RS M6 Join Date: Jun 2012
Pfadt.
Another 1 of 371 '12 T3 LS3 M6's built.
07-16-2013, 10:36 PM | #5 |
Search Ninja
Drives: 2010 Black 2SS/RS A6 Join Date: Oct 2009
If you look up rigid motor mounts in the dictionary, a picture of the Pfadt MM's are next to it.
Halltech CF 102 fed GPI modded intake manifold Bo (knows) White ported TB Kooks LT's/ Dynomax VT Pfadted (springs/sways) Dyno tuned by Rhino and GPI I once parallel parked a train. |
07-17-2013, 11:12 AM | #6 |
V8 lounge member #5
Drives: 12 2SS Synergy Camaro, 05 PontiacG6 Join Date: Dec 2011
I thought pfadt switched over to welding the engine to the frame directly..
07-17-2013, 12:11 PM | #7 |
PHAT B33
Nawwwww, that's Torque Solutions clone mount on Ebay.
07-17-2013, 12:26 PM | #8 |
Drives: 2010 camaro ss Join Date: Nov 2012
07-17-2013, 01:50 PM | #9 |
PHAT B33
I was just kidding about the Torque Solutions, I know they are a Pfadt clone.
07-17-2013, 02:46 PM | #10 |
Drives: 2010 rs/ss black # 10,308 Join Date: Mar 2009
I was producing over 600whp with my twin turbo setup. And it got to the point where my motor was twisting so much it was hitting the firewall.
I personally went with ZL1 Motor mounts (which are for sale btw) because i figured if it is put into a camaro pushing over 580hp... it should be good for my car. I use to daily drive my car and i could feel that it was much tighter.. but it was not harsh by any means. So for the money it was nice.
07-17-2013, 05:40 PM | #11 | |
Got Boost?
Drives: 2010 1SS RS Join Date: Aug 2011
Sent from my iPhone using Tapatalk. If it is spelllled wrong, deal with it. |
07-17-2013, 05:56 PM | #12 |
He's Going Bigger and Better!
07-17-2013, 06:27 PM | #13 |
Haha yup, blew the motor 3 weeks ago and now will be going to a more solid mount. There is honestly probably 150 miles on the ZL1 mounts.
sent from my galaxy s3. that would explain the errors.
07-17-2013, 06:36 PM | #14 | |
Got Boost?
