TireRack
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Camaro DIY & HOW-TO instructions & discussions
Old 09-04-2009, 08:28 AM   #1
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: 2014 Z/28 #82+#192, 18ZLE 66Nova
Lightbulb DIY part # for ABL (Pictures of Installation included!!!)
To do the ABL on your dash this is what you need to Buy.
1 From gm you need to buy 3 lights in the color you need.
The part # for the blue lighting is 92238395
The part # for the orange lighting is #92228416 (it is red)
And the light tube is from Me.
And one last part GM removed the connectors on all cars, 2010up past the VIN 9160000 so if you have that number you will need to t-tap or get a harness that is plug and play
2SSRS@Gen5diy is offline   Reply With Quote
Old 09-04-2009, 08:28 AM   #2
2SSRS@Gen5diy
This is It
Ok "Tag", You know i need sleep at 12:14 PM i was dreaming of LSX 454 and a cam making 650 RWHP in my Camaro. LOL
So This is the hard part The work Go to your car and pull the side cover over on the drivers side see pics
And pull it out gently you will fell it pop out it is held in by some snap clips (all the parts are held in that way ) More pics
Next you will see the connector on the drivers side, In this pic i have the connector in red and the outer end on, See pic.
Next you remove the speedometer off so lats do that, More snap clips to remove from the top pop off Gently and first move the wheel out and down Pics.
And more
And now pull up on the trim, If i can do it with my fat hands you can do it.
This is the back side for you to see.
Now there is 4 screws that you will remove to get the speedometer out the way, And as you can see there is 2 alignment pins over the 2 bottom screws so you can not do it wrong.
And this side.
Now to remove the speedometer, First you do NOT need to remove the wires on the speedometer, In this pic you will see that i put a red line on the pic that is where you need to pull up on the dash so you can tilt the speedometer forwarder to get it out see pics.
And this pic.
And this so you can see i did not remove the wires on the Speedometer.
Old 09-04-2009, 08:29 AM   #3
2SSRS@Gen5diy
More pics for you
And to keep going i needed some time.
Now that we removed the speedometer from the dash it all there for us to do.
Next we need to find the 2nd connector and it is in front of you in the center of the wires behind the speedometer look at this 2 pics.
And this.
One more for fun.
Now that we know that wear the two connector are we need to pull the dash trim off, As before be gentle More snap clips see pics, Start at the ends of the dash.
And pull, Ups my fat hand in the pics.
This is the long side so lots of clips on the drivers side there is only 2 clips.
Next is the hard part to drill in your dash, Do not worry if you do it right you will not see it, So do it right.
If you are not happy and do not get it P.M. me, And we can see if i can help, Now i do have a job so give me some time to help you, And if I do help you out, See if you can help some one who needs it.
You can see that there is a small triangle spot at the end of the dash on the 2 sides of the dash that is wear you drill, at the top and out as far as you can go, see pics.
And now we start to put it together This is the way i did my car.
More info soon.
Last edited by 2SSRS@Gen5diy; 09-09-2009 at 12:46 PM. Reason: Need some time this is hard work.
Old 09-04-2009, 01:00 PM   #4
Camaro-Teskey
BlackonBlack
Camaro-Teskey's Avatar
Drives: 2010 Blk Camaro 1LT
Think you could list the parts that would be needed for 1lt/1ss, because we also need the door setup right? Sorry I dont have the car yet; just wondering. Thanks
-Teskey
Camaro-Teskey is offline   Reply With Quote
Old 09-04-2009, 01:07 PM   #5
2SSRS@Gen5diy
Can you help me out on that as i have not had a look at a 1 lt/1ss in the door do you have the same plastic panel in the door and dash ?, Post some pics for me.
Old 09-04-2009, 02:41 PM   #6
Primus
2G1FF1EV0A9113319
Primus's Avatar
Drives: 2010 1LT/RS 6MT
we do not have plastic panels. Ours are a kind of cloth. We would need to buy replacement panels for the doors and dash.
2010 Camaro 1LT/RS M6 Black
1100: 10/13/2008
2000: 4/02/2009
3000: 4/08/2009
3300: 5/14/2009
3400: 5/21/2009
3800: 5/28/2009 VIN: 2G1FF1EV0A9113319
4000: 5/28/2009
4150: 5/28/2009
4B00: 5/28/2009
Delivered: 6/10/2009
Primus is offline   Reply With Quote
Old 09-04-2009, 04:30 PM   #7
Tecca
Tecca's Avatar
Drives: ...
As Primus said the 1LT and 1LS guys will have to buy the whole new door panel. They run $250 each side plus s/h. Then you will also have to run the wiring as it isn't included either.
Tecca is offline   Reply With Quote
Old 09-05-2009, 01:27 AM   #8
TAG UR IT
www.Camaro5store.com
TAG UR IT's Avatar
Drives: 2014 ZL1 #705
I just ordered the parts and will do a complete write up with pictures and detailed instructions when the parts come in. Looking forward to getting this done the way I think it should have been done for ALL the Camaros!
TAG UR IT is offline   Reply With Quote
Old 09-05-2009, 06:05 PM   #9
R6P
R6P's Avatar
Drives: 2010 Camaro
There are trim kits that are in the works for you 1LT & 1SS guys (and anyone looking to change color with a 2LT or 2 SS) that include both acrylic door panel inserts and both dash inserts, however you will need to add light tubes to the doors also to your 1 LT or 1SS. They are shown on gmparts direct for $327 for the kit, but not yet available
92221433 for Yellow
92221438 for Orange
92233738 for White
92233739 for Silver
Keep the faith
R6P is offline   Reply With Quote
Old 09-05-2009, 08:05 PM   #10
2SSRS@Gen5diy
Hay you got a full time job ( Keeping us in line On Camaro5 and the Law )
Have fun.
Old 09-05-2009, 10:51 PM   #11
Camaro-Teskey
BlackonBlack
92221433 for Yellow
92221438 for Orange
92233738 for White
92233739 for Silver
Keep the faith
Awesome, great news man thanks. That just made my day.
-Teskey
Old 09-06-2009, 12:07 AM   #12
TAG UR IT
TAG UR IT's Avatar
Have fun.
Dude...I got 3 full time jobs!!!
Kids and family
Work
This SITE!!!
Old 09-06-2009, 12:14 AM   #13
TAG UR IT
TAG UR IT's Avatar
Reserved for some pics on sunday
It's Sunday....
WHERE's MAH PIX!
Old 09-06-2009, 08:22 AM   #14
2SSRS@Gen5diy
Good news and bad Good is the good dyno # with the Vararm, wow what power, Now the bad i did go to Frys elec to buy a camera buy the one that was what i want was not in i am goint to take some now for all to see.
V8 Camaro Performance Upgrades List Milk 1027 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 93 08-30-2021 05:56 PM
EXHAUST Milk 1027 Wiki 2 03-07-2010 09:20 PM
IMPORTANT Part 1 Warranty Disputes Zeus Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 11 08-25-2009 11:37 AM
got my new Camaro today pictures included !! yesno20102ssblack Camaro Photos | Spyshots | Video | Media Gallery 33 05-02-2009 10:05 AM
First Camaro Impressions (Pictures Included) --- Red Jewel Tintcoat! dect Camaro Photos | Spyshots | Video | Media Gallery 80 01-27-2009 06:45 PM
