06-14-2014, 02:09 AM | #1 |
Drives: 2015 1SS, 1LE, Recaro, NPP Join Date: Apr 2014
2015 1LE vs 2003 Silverado SS w/ Whipple
My friend has a 2003 Silverado SS, and is getting a Whipple by the end of the year. He thinks he'll be able to beat my 1LE. The truck stock does 0-60 ~6.8 seconds with a 1/4 mile close to 15 seconds. I highly doubt the Whipple will drop his 1/4 mile by 3 seconds. My 1LE will be mostly stock, just VMAX TB and CAI intake. We have a $500 bet on it. I think I have this no problem, but he thinks he'll walk me. What do you guys think?
2015 Summit White 1SS, 1LE, Recaros, NPP
498 RWHP 447 RWTQ (Motor) 647 RWHP 723 RWTQ (150 Shot) 12.1 @ 117 (Motor) 11.7 @ 129 (Nitrous) Nitrous Outlet Single Nozzle Kit | Stand Alone Fuel Cell w/ C16 | Custom Grind Cam | Stainless Power 1 7/8 LT Headers | CAI Intake | ATI Super Damper | BMR Trailing Arms & Toe Links | Prothane Polyurethane Sub-frame Bushings | JDP Upper Control Arm Bushings | MT Drag Radials | Tuned by SS Motorsports Youtube Channel: Click Here |
06-14-2014, 03:06 AM | #2 | |
Drives: 2013 SS Join Date: May 2013
06-14-2014, 07:37 PM | #3 |
Drives: 2011ShelbyGT500 Join Date: Jan 2014
Your going to destroy him unless he has major mods done at the same time.
Basic Whipple kit MIGHT put him in the high 13's. |
06-15-2014, 06:53 PM | #4 |
Most will see mid 12s
06-15-2014, 07:08 PM | #5 |
Drives: 2012 2SS 45TH Anniversary Join Date: Mar 2012
Trucks can be strange ducks. I've seen some that sound and look super fast only to disappoint and some that look total stock only to scream.
06-15-2014, 10:25 PM | #6 |
Drives: 2013 Camaro 2SS Join Date: Dec 2012
if hes that confident, hes probably getting other stuff done as well...might want to consider adding headers or something as insurance.
2013 L99
bolt ons, tune |
06-16-2014, 06:47 AM | #7 |
2013 Camaro SS1LECTSVZ28
Drives: 2013 AGM 1SS/1LE Join Date: Nov 2012
A now defunct company in MI called Wheel to Wheel had a Silverado SS that had a turbo or blower on it. (cant remember).....It went door to door with my Evo 8 that would run 11.3 @ 122.
Matt
06-17-2014, 02:41 AM | #8 |
His truck is completely stock, and all he is adding is the Whipple, no supporting mods at all. There's no way he's taking 3 seconds off his 1/4 mile time.
06-19-2014, 01:53 AM | #9 |
Drives: 2SS/RS L99 ABM Join Date: Aug 2009
Get a set of long tubes as stated before. You'll love them! Then once you win take that $500 and consider it a set of long tubes for practicality $200, considering most run around $700
Rotofab CAI, 2" LT Headers/non catted, 3" Straight Pipe w/ X-Pipe, Elite Catch Can, GPI SS3 VVT, 9" 4000 Triple Disc, Yella Terra Ultralite Rocker Arms, MSD Super Conductor wires
06-19-2014, 08:55 AM | #10 |
ace5.org (Atlanta Club)
Drives: 2010 Black/IOM 2SS LS3 Join Date: Sep 2013
That all wheel drive truck is going to launch and hold traction pretty well, regardless of the weight and they respond well to boost. The 1LE is a road course car and not a drag car, with most 1/4 mile stock times being slower than a regular SS. Should be a good race, but most people aren't running sub 13s in these cars without a driver mod. Not sure of your experience and how much track time you'll have in your car before the race, but should be a good one. Make sure to post videos of the results!
06-22-2014, 01:47 PM | #11 |
Well I'm going to get LT headers and a tune before the race. It shouldn't be a problem now.
06-22-2014, 02:37 PM | #12 |
If ALL he did was add a supercharger, you should have no problems, especially if you tune and add LHT.
He has 345 crank hp stock. If he is an auto, he'll weigh a few hundred pounds more than you. He will have 450 crank or more depending on the setup.. Adding your mods should put you around 430-440 whp (I have seen a few stock 1LE's put 390-400). Of course, your not built for drag racing but you should still do well. |
06-22-2014, 02:44 PM | #13 | |
Drives: 1/70 2013 BRM 2SS RS 1LE NPP NAV Join Date: Feb 2013
The Silverado SS would need more than a supercharger to keep up.
06-22-2014, 02:49 PM | #14 | |
Some trucks are absolute monsters at the strip. Some just sound really loud, which for some reason makes the owner add 300 more "simulated" hp. |
