10-31-2017, 05:09 PM | #1 |
Black lightning
Broken strut tower brace bolt!!!!!!!!!!
How urgent is this do I need to worry about the car collapsing on me if I punch it?? It still seems very tight!
[ 2021 Camaro ZLE 10 speed
10-31-2017, 05:16 PM | #2 |
#becauseracecar
Drives: 2016 SS Sedan, 2016 Camaro SS Join Date: May 2015
I would replace it pretty quickly. That must have been a defective bolt since those are 10.9 bolts. Judging by the gouge in the strut tower brace though how high did you torque it down? Mine are only 30 lb/ft.
10-31-2017, 05:19 PM | #3 |
Black lightning
It stated 35
10-31-2017, 05:32 PM | #4 |
Drives: 2017 1SS/1LE Join Date: Sep 2016
Those bolts aren't providing much surface area on the brace... I would run washers underneath...
10-31-2017, 05:41 PM | #5 |
Black lightning
Washers are actually provided underneath the strutbar.
10-31-2017, 05:45 PM | #6 |
35 the factory ones are 16ftlbs
10-31-2017, 06:20 PM | #7 |
Black lightning
Yup, the guy that sold me the wrench said it would stop turning at the setting nope. It kept clicking.....my first time using one
10-31-2017, 06:28 PM | #8 |
Drives: 2017 2SS Manual Join Date: Apr 2017
it clicks when you reach the desired torque, if you kept going you over torqued
10-31-2017, 06:28 PM | #9 |
Yep stop when it clicks. You also have to set the torque wrench up. You set it at the middle of the range. Example 20 to 100 you would set it at 40. Put it on something that won't turn at that setting. The click it 3 times in both directions. Then set it to the torque you need
10-31-2017, 06:43 PM | #10 | |
Black lightning
10-31-2017, 07:03 PM | #11 |
Most people have no idea how to use a torque wrench. Even the profesionals. You might want to replace the bolts. If you over torqued them they may break under use.
10-31-2017, 07:08 PM | #12 |
Yes, replace the bolts. They'll likely break over time. I would suggest putting the washers under the head of the bolt... Those bolts do not provide enough surface area for the diameter of those holes...
10-31-2017, 07:58 PM | #13 |
Drives: '16 Garnet Red 1SS Join Date: Mar 2014
Prolly have to call up BMR, or whoever sold you the brace.
'16 Camaro 1SS
'18 Miata GT Gone: '01 Camaro, '14 Camaro, '90 Miata |
10-31-2017, 08:26 PM | #14 |
Black lightning
Phasetek performance
