02-15-2016, 07:14 PM | #1 |
Drives: 2010 WHITE SS Join Date: Nov 2014
Alpine ine-s920hd no sound
Only sound that I can get out of this is my Nav. other than that nothing.
any thing I can check to see what the problem is? Thanks. |
02-15-2016, 09:37 PM | #2 |
Drives: 2015 2LT RS Camaro Join Date: Jan 2013
Checked the fuses?
02-17-2016, 10:17 PM | #3 |
BUMBL Z
can the radio be factory reset? firmware update? maybe the radio just died out?
Current: 2015 ZL1 M6, Rotofab Intake, LS3 throttle body, 2.55 Upper/9.17 Lower w/ Idler Relocation, DMS Reinforced Brick, ID1050X, 1 7/8" Headers, ProSpeed HX/Reservoir, DSX Aux Pump/Flex Fuel Sensor, E85, McLeod RXT, BMR 1" Drop, Tuned by Pat G
Past: 2010 2SS, some bolt ons, 415rwhp/400rwtq |
02-17-2016, 10:25 PM | #4 |
Thing is I can hear navigation lady coming thru the speakers like normal. My back up camera still works.
I didn't see any firmware update on Web site. Sent from my SAMSUNG-SM-N920A using Tapatalk |
02-18-2016, 06:04 PM | #5 |
Drives: 2014 2LT/RS Ashen Gray Metallic Join Date: Nov 2011
What head unit do you have? The factory radio in 2010 did not have navigation.
If it is an aftermarket head unit, maybe something changed the audio settings. |
02-18-2016, 06:07 PM | #6 |
Sorry, was not paying attention.
I had an Alpine 920, but never had the issue you do. Check to make sure that you did not change a setting in the unit that would cause you to loose all audio except the nav voice. |
02-18-2016, 09:13 PM | #7 |
just did a factory reset. WORKS!!!
02-18-2016, 09:19 PM | #8 |
Drives: 2014 SS1-1le Crystal red metallic Join Date: May 2015
Alpine's are not the most user friendly head units !! When it come to settings..
