TireRack
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6)
Old 03-29-2013, 10:39 AM   #1
SERVED_USMC
SERVED_USMC's Avatar
Drives: Slow
TR6060 grinding into 2nd under high RPM. Common?
I have to baby it into second if Im getting on it. Clutch pedal in and slowly go into second. If I dont, it will grind all the way through until it catches.
Is this particular problem a common one with this trans, or do I have issues?
SERVED_USMC is offline   Reply With Quote
Old 03-29-2013, 11:26 AM   #2
JLE58
Drives: CGM,twin turbo, cam 2010 SS/RS
Very common most everyone has the problem. Do a search there are tons of threads and info on this subject.
JLE58 is offline   Reply With Quote
Old 03-29-2013, 12:04 PM   #3
BigMatt
2010 Camaro 2 SS/RS M6
BigMatt's Avatar
Drives: 2010 Camaro SS/RS
Send a message via AIM to BigMatt
tick braided clutch line and idealgarage's master cylinder work for a lot of people
Forged LS3, FED M311 heads, CAI Inc, ARH 1 7/8, Corsa Xtreme, Taylor Wires, MGW Shifter, Street slayer twin carbon clutch, Tick braided clutch line & speed bleeder, ZL1 Diff Swap, BMR Split drop, Sway Bars, Trailing Arms, Toe Rods, Pro bushing kit, Carslyle racing 15in conversion, Whipple, LPE dual fuel pumps, Rx catch can, Id1300x, Alky Control
BigMatt is offline   Reply With Quote
Old 03-29-2013, 12:36 PM   #4
SERVED_USMC
Drives: Slow
Thats what I thought. I remember cruising over a thread a while back before I joined the site and it was mentioned.
Old 03-29-2013, 02:31 PM   #5
ToddB
Drives: 2011 2SS Convertible Supercharged
Yep mine did it right from new. Under heavy acceleration it will grind going into second even when its warmed up.
ToddB is offline   Reply With Quote
Old 03-29-2013, 11:48 PM   #6
Medi0cr3
Untamed Performance EPT
Medi0cr3's Avatar
Drives: 2011 2SS
this....
Mine was 3rd gear grind though. Ideal G master cylinder fixed it tho. no probs now And I change out the clutch fluid very very regularly.
Night Fury Cam
Borla LT Headers and Borla Cat Back ATAK
9in. diff with 4.11's, DSS Axles, and Alum Shaft
Hurst Short-Shifter; Ideal Garage Master Cylinder
H-E Street Slayer Twin Billet Clutch
BMR: Adjustable; Trailing Arms, Toe Rods, Extreme Sway Bar. BMR Subframe Bushings.
Strange Rear Coilovers and mounts
Tuned by Rhino79
Medi0cr3 is offline   Reply With Quote
Old 03-29-2013, 11:53 PM   #7
CHMSC
ROAD COURSE JUNKIE
CHMSC's Avatar
Drives: 2012 SS/RS LS3
Tick high flow clutch line, ideal garage high flow master clutch cylinder, upgraded clutch return spring, separate your clutch from your brakes and use good fluid. Just got all my stuff along with new rotors and pads. Can't wait to install it all.
CHMSC is offline   Reply With Quote
Old 03-30-2013, 03:41 AM   #8
was619
Billy The Kid
was619's Avatar
Drives: Cyber Grey 2SS/RS
Agreed with everything from the above poster except for the return spring since I haven't found the need for it so I have not experience with it
Otherwise yes the IdealG master is a good swap although the price is rather high. Nothing you an really do about that.
Some people have gotten their dealer to replace the syncros to carbon instead and bronze fork pads Ect.look on tick performances website for more info on the 'upgrade' Others have had the entire transmission 100% replaced along with the clutch(all oe parts) and still had issues.
If you want a solid fix for now till you have good reason for a new clutch and slave the idealG master and separating the fluids is the way to go!
Good luck
CGM 2SS/RS[SIZE="1"]
Performance: LT Headers/Stainless Works cat-back, 225/233 Cam, 1LE 3.91 gears, Custom Tune, BMR suspension,
MGW Shifter, Stainless brake & clutch lines, Ideal G Master Cylinder, 275s on all 4 corners
Aesthetics: ZL1 Spoiler, DIY LED marker lights, AACPlasma DRL, Yellow Calipers, painted factory wheels
was619 is offline   Reply With Quote
Old 03-30-2013, 03:59 AM   #9
CHMSC
ROAD COURSE JUNKIE
CHMSC's Avatar
The clutch return spring helps when or if you have your clutch sticking. Granted the other stuff should fix this issue but I am tired of dealing with it so I got everything I could to make sure I covered all the bases to make the clutch work like it should of in the first place.
Old 03-30-2013, 05:25 AM   #10
MillerTime
Blowin the doors off!
MillerTime's Avatar
Drives: A 2013 SS RS 6M SR
Had this BAD on my 10 which is why i got rid of it. In a 13 with zero issues on this tranny.
2G1FS1EWXD9163847
MillerTime is offline   Reply With Quote
Old 03-30-2013, 12:52 PM   #11
MiSTER
Drives: 2010 2SS CGM Camaro, 1988 6.6L IROC
There are people with new 1LE's that have reported this issue so it seems to be more of a hit or miss, quality control issue with the TR6060. At least for the SS/1LE.
http://www.camaro5.com/forums/showthread.php?t=261882
MiSTER is offline   Reply With Quote
Old 03-30-2013, 01:03 PM   #12
SERVED_USMC
Drives: Slow
Its annoying. Sooner or later something is going to break. I need to get everthing ordered and get it fixed. Thanks for the help guys.
Old 03-30-2013, 03:29 PM   #13
MiSTER
FYI... a law firm is looking into claims regarding this issue.
http://www.girardgibbs.com/chevy-camaro-lawsuit/
Old 03-30-2013, 03:40 PM   #14
Gunny
Drives: 2013 1LE
Having the same issue with my 13 1LE
Gunny is offline   Reply With Quote
