03-14-2018, 02:06 PM | #463 |
Drives: 2014 1le 1SS CRMT Join Date: Apr 2014
I’m not sure if it’s posted already!! But is there a parts list of the whats needed to do the Z06’s ?? Very interested in doing it .. thanks guys
03-14-2018, 02:33 PM | #464 | |
Drives: 2015 Chevy Camaro 1SS Join Date: Jul 2017
but Z06 non carbon ceramic calipers with I believe V rotors and Zl1 backing plate and ZL1 line and Z06 PAds if I put this together correctly |
03-15-2018, 11:55 AM | #465 | |
slower than you
If you have a 1LE, you won't need a different backing plate. Very easy bolt up mod. You can use ZL1 or V rotors, your choice. You will also need a pin kit. Here's the list I referenced. Part numbers in bold because the text is wonky: Part Name - GM or Delco Part number corvette calipers LEFT - 23242497 corvette calipers RIGHT - 23242498 zl1 rotor left - 20795300 zl1 rotor right - 20795302 ZL1 brake lines goodridge (pair) - GOODRIDGE-CAMARO-12227 ACDelco 18K2108X (pin kit) - ACDelco 18K2108X ZL1 brake pad kit (front set) - ACDelco 171-1040 (or GM 25940447)
03-15-2018, 12:45 PM | #466 |
Awesome bud thanks
05-21-2018, 10:48 AM | #467 |
I made it about a quarter way through this thread that started off with brake information. Upgrading to the Corvette Z06 calipers with the ported pistons. Questions were asked if the p/n were known for the brake calipers (Which are easy to find these days) but more importantly the ported pistons (not so easy to locate and find). Then the thread goes out in left field with suspension sets ups, cambers and shims. Dudes........ start a new thread so we dont have to read 34 pages of rambling that is non-applicable to the original thread. Thanks
05-21-2018, 11:10 AM | #468 |
Part numbers for the ported pistons mentioned as a upgrade in the Corvette calipers (2015+), mentioned on page one of this thread. You can upgrade your CTSV and ZL calipers with these.
- ACDELCO 23242510 GM Original Equipment Front; Heavy Duty Antilock Brakes (J56) or - ACDELCO 19207043 GM Original Equipment Info Front; HD ABS brakes(J57) |
05-21-2018, 12:35 PM | #469 | |
Pistons
Orange Krush II
08-17-2018, 07:26 PM | #470 |
Drives: 02 Camaro B4C Join Date: Nov 2016
I just completed the upgrade and am looking forward to seeing how it drives.
An issue that I have seen discussed in many thread is the torque to yield (TTY) bolts. Not being a fan of TTY bolts I went to the local Fastenal store and purchased new 10.9 bolts. Fronts are M14-2.0X60, part number 11115761, and rears are M12-1.75X60 part number 11115752. These are zinc plated flange head bolts. They cost $5 or $6 bucks each but you can reuse them. I torqued the fronts to 125 ft lbs and the rears to 75 ft lbs and put a dab of Locktite Blue on them. Good luck Craig
A man's garage is his castle
1969 Camaro SS 1970 Camaro SS 2002 Camaro B4C 2014 Camaro SS Dedicated Track Car 2015 Camaro 1SS 1LE 2008 HHR SS 1996 Silverado Crew Cab Long Bed Dual Rear Wheel |
09-22-2019, 10:48 AM | #471 | |
Drives: 2014 Camaro 2SS 1LE NPP Join Date: Nov 2013
My thoughts on some things:
09-22-2019, 06:47 PM | #472 |
CTSV, ZL1, & ZO6 use the same calipers just painted different colors.
The ZO6 calipers have vented pistons.
09-22-2019, 08:51 PM | #473 |
Basically all the same but you use ZL1 rotors or swap the rings over to a set of Z06/GS rotor rings from a Gen6 1LE see over in the Gen6 brakes and suspension forum.
Orange Krush II
10-06-2019, 04:04 PM | #474 | |
slower than you
Long term update, still really dig this upgrade and feel it was worth every penny. i'll probably need new pads this coming season, but otherwise everything's been solid.
12-28-2019, 11:11 AM | #475 |
Just gonna revive this oldy but goody good up too see how everyone that has done this still have their cars and how they are liking it.
I still have mine an still think it’s worth the coin. I’m going to start doing the rotors and then re coat the calipers to match IOM.
Orange Krush II
12-28-2019, 04:19 PM | #476 | |
Drives: Black '13 2SS/RS/1LE w/NPP/NAV Join Date: Oct 2012
Sent from my SM-T837V using Tapatalk
My Build Thread... http://www.camaro5.com/forums/showthread.php?t=285054
