11-28-2022, 07:21 AM | #1 |
Drives: 2019 RS Convertible 2.0T Join Date: Nov 2022
Question about ventilated seats?
Hello,
I’m new to the 6th gen platform but I previously owned a 5th gen and was an active member on camaro5 I just had a question on the heated/ventilated seats… Does the function just work on the seat backs or also on the cushions you sit on? I feel like I notice the air on moving through the back of the seat but can’t really feel it on the seat bottoms? |
11-28-2022, 07:31 AM | #2 |
PKG4U
Try using them when it’s cold outside. You will notice it more. The thicker the material you have on the way less likely you are to feel the ventilation. So theoretically if you go sit in your chair in your undies, you will feel the whole chair a lot better
2020 Camaro LT1. Bought 10/2020 | GM PERF. CAI | GM Muffler Delete (Performance Exhaust 4” tips). | SOLD 1/2022|
2018 ZL1 Summit White | Bought 1/2022 | PDR, Recaros, Carbon Dash, WeaponX Hx System, Apex SM-10 in ZLE fitment w/PS4S Mods after Warranty “Imma keep it stock” |
11-28-2022, 07:56 AM | #3 |
Drives: 2016 Camaro 2SS Hyper Blue Metallic Join Date: May 2020
Both the seat back and cushion.
11-28-2022, 08:09 AM | #4 |
Drives: 21 ZL1 Join Date: Feb 2022
Put the AC on full blast, and direct it to only the floor. The fans under the seat will suck up that cool air and shoot it up your butt and back. Thats the only real way they work well.
11-28-2022, 08:38 AM | #5 |
Yup, the seats have two fans, one unde the rear third of the seat cushion and one near the bottom of the seatback. They work well, but aren't super powerful and the A/C trick mentioned above helps if you want more cold airflow.
11-28-2022, 10:39 AM | #6 |
Old Gearhead
Drives: 2023 GMC Sierra Denali Ultimate Join Date: Nov 2018
The Camaro ventilated seats "blow" air? Most "suck"/pull air. On my Ram and F150 the seats pull air. With them on, they would hold a thin paper to the seat back, not blow it away.
2023 Camaro ZL1 convertible - black - SOLD
2023 GMC Sierra Denali Ultimate - black Last edited by Jus Cruisin; 11-28-2022 at 12:16 PM. |
11-28-2022, 11:16 AM | #7 |
Petro-sexual
I'm ghetto, and therefore have a wife beater covering the seat backs and a plain microfiber towel protecting the seat bottoms.
In the Summer, until the interior heats up, I can feel the ventilation through that stuff pretty easily. The longer I run it, though, without the AC on, the diminished cooling I sense. I agree that having the AC on, especially toward the floor, helps the cooling affect more. They are most effective when there is cool air in the cabin. I thought I read they pick air up off the floor from somewhere.
11-28-2022, 12:24 PM | #8 |
Thank you all for the info and tips, very helpful!
11-28-2022, 12:39 PM | #9 |
Drives: 2017 Blue Camaro 1SS 1LE with PDR Join Date: Sep 2018
Also block the cold air from escaping out the back of the front seat into the back seat area. I keep my sunshade behind the driver's seat for this reason but you could use cardboard or other materials.
11-28-2022, 12:48 PM | #10 |
Petro-sexual
That's interesting! I like that idea!
11-29-2022, 09:36 AM | #11 | |
Drives: 2020 Camaro 2SS A10 Join Date: Jun 2018
Heating noticed the seat being heated, but never really noticed if the back gets heated.
2020 Camaro 2SS A10 | Rebuilt by: CBI Street Cars | 2" SE LT Headers | 3" SE X-Pipe | 3" MBRP Axle-Back | Pri & Sec Cat Deletes | Roto-Fab CAI | LT2 Ported | 95mm ZR1 TB | LSA crankshaft conversion w/modified crank gear | LS1 thrust bearing | LS MSD Plug Wire Set | BTR Stage I Cam | ARP Rod Bolts | Delphi Lifter set | NGK LTR71X-11 spark plug set | DOD Delete | VVT Limiter | ECM, TCM & E85 | Retuned by: Justin L. | Dyno: 510 rwhp 472 rwtq | Best 1/4 Time: 11.639
11-29-2022, 08:03 PM | #12 |
Drives: Chevy camaro Join Date: Jan 2022
I was thinking because Ford & Ram suck.....
Glenn
2017 Camaro 2LT RS Convertible |
11-29-2022, 09:08 PM | #13 |
Drives: 2020 2SS Vert/M6/F250 SD Join Date: Jan 2021
Ours works very well on both the seat and seat back.
My wife hates it because she says it feels like she peed herself! I use it when its real hot. But I enjoy the heated seat more.
11-29-2022, 09:11 PM | #14 |
There are definitely 2 separate fans in the Recaro seats. One for the bottom of the seat and one for your back. The best way to feel the one for the bottom of the seat is to wear swim trunks but it still helps even when you can't feel the airflow through other types of clothing.
