Old 12-16-2018, 06:04 PM   #1
18ss376
Drives: Camaro
Cats Question
If I gut all the cats I know I will get a CEL, but can I use my code reader just to erase the codes? Will the CEL come back after erasing the codes? I will still connect O2's back up after gutting them, just wondering if this will work.
Or is it better to buy the straight pipes to replace the cats?
18ss376 is offline   Reply With Quote
Old 12-16-2018, 06:57 PM   #2
metros11
Drives: 2018 SS 1LE
If you remove or replace the catalytic converter your CO2 sensors will cause your car to throw the codes. Clearing the codes won't work.
metros11 is offline   Reply With Quote
Old 12-16-2018, 07:21 PM   #3
18ss376
Drives: Camaro
So what do I have to do to not get any CEL's?
Old 12-16-2018, 07:41 PM   #4
Gasoline_Farts
Drives: 19 SS 1LE
Not remove your cats. It stinks up the road for everyone else.
I believe if you remove the secondary cats you can avoid a CEL with a plug Fowler adapter. But to be 100% sure of no CEL, with all cats removed, you’d need your ECU retuned via aftermarket.
Gasoline_Farts is offline   Reply With Quote
Old 12-16-2018, 10:50 PM   #5
Puddin
You wont get a CEL until you delete the primary cats then at that point you'll need your tuner to turn the codes off or use HP tuners.
Old 12-17-2018, 06:09 AM   #6
18ss376
Drives: Camaro
Once the Whipple gets installed I don't want any cats, to much back pressure for a supercharger IMO. HPtuners comes with my Whipple so that will be great.
Old 12-17-2018, 06:26 AM   #7
Jhunsberger
Jhunsberger's Avatar
Drives: 2017 Camaro 1SS M6 (SOLD)
Yup, just tune them out.
Stock: 416hp/427tq, 12.21 @ 116.80
Modified 02/2019: Whipple SC w/ 3.500 pulley, LT4 fueling, NW 103 TB, Roto-Fab Big Gulp, Kooks 2" jet coated, full Borla ATAK exhaust, DSS axles, Gforce driveshaft.
Tuned by EFX Tuning 688hp/632tq
Best 1/4 to date: 10.705 @ 131.92
Jhunsberger is offline   Reply With Quote
Old 12-17-2018, 07:23 AM   #8
Jeb114
Jeb114's Avatar
Drives: 2021 300
Removing Cats on a Street car is a $10,000 federal crime.......
Jeb114 is offline   Reply With Quote
Old 12-17-2018, 07:30 AM   #9
crosive
Drives: 18 zl1
removing the converter is illegal. getting caught without one isn't.
you are right about the "up to" fine for removing it, but getting caught without it will usually just get you a smog ticket or the like, which even then can be overthrown if you reinstall one.
crosive is offline   Reply With Quote
Old 12-17-2018, 07:31 AM   #10
18ss376
Drives: Camaro
Been doing it since 1979 & Oklahoma has no emission inspections anymore.
Old 12-17-2018, 07:35 AM   #11
Goldfish
Drives: 18 2SS 1LE
What part of OK?
I do like the lack of emission testing, but I do wish there was a bit more vehicle inspection required. The number of people without working tail lights here is obscene.
Goldfish is offline   Reply With Quote
Old 12-17-2018, 07:37 AM   #12
crosive
Drives: 18 zl1
Originally Posted by Goldfish View Post
What part of OK?
no working taillights huh. I think my cars are the only ones here that have blinkers that work.
Old 12-17-2018, 07:43 AM   #13
18ss376
Drives: Camaro
What part of OK?
The whole state. This is straight from the OK DMV.com website
Oklahoma is one of the few states that do not require emissions checks for motor vehicles. An emissions inspection is not needed to register a vehicle in Oklahoma, irrespective of the age of the vehicle.
Old 12-17-2018, 08:54 AM   #14
lokitwitch04
Drives: 2017 Camaro SS 2SS
I'm also gutting both sets of factory cats and reinstalling. It is very easy to kill the trouble codes with HPtuners.
lokitwitch04 is offline   Reply With Quote
