09-28-2016, 06:27 PM | #1 |
Drives: 1994 1LE / 2006 Z51 Corvette Join Date: Jul 2009
50 rwhp GAINS with LG Motorsports Super Pro Headers and tune
2013 A6 ZL1 arrived at the shop this morning with a few dress up upgrades and a RotoFab cold air intake, we installed our full 1 7/8 LG Super Pro Long Tubes finished in Black Jet Hot coating, high flow cats and full 3" mid section into his stock muffler system. Tuning on the dyno and a solid 488 rwhp through the auto. Nice gains for a days work! Thanks for bringing the car by Chuck! |
09-28-2016, 06:43 PM | #2 |
488 - 50 = 438 WHP? Lowest stock number I've ever seen, and I'm factoring for the Auto. And 488 is the lowest number I've seen with full exhaust + CAI + Tune as well, albeit that 50 WHP is a great gain.
09-28-2016, 07:45 PM | #3 |
"BEASTM*DE"
Well I can't believe this is about to happen, but I agree with you 438rwhp is extremely low...With the CAI and exhaust/tune at car should have dyno'ed closer to 520-530, just guessing on the number...Something is amidst here...
Vengeance Racing Stage 1 Kit 575rwhp, 569 rwtq...
Rims powder coated gloss black...BFG'S Comp 2 A/S... Dual 10" Kicker Comp S Subs 1200w... |
09-28-2016, 08:09 PM | #4 |
Drives: 02 Z06, 95 Trans Am, 2012 ZL1 Join Date: Mar 2012
I agree. Bone stock mine was 516 rwhp on a dynojet.
Bryan 2018 ZL1 M6
09-28-2016, 08:17 PM | #5 |
09-29-2016, 09:21 AM | #6 |
Our 2013 manual car put down 490 rwhp stock. Now this was an auto car which historically they seem to put down 440-450 rwhp stock on OUR dynojet here. This one did seem a bit lower than normal but showed no signs of knock during the baseline pulls. We have seen in the past with some cold airs, the cars making less power than with a stock air box. Best we could tell that was the only thing changed.
The car had been mod'd prior to this customer buying the car and returned to stock in some form. All runs were done at full operating temp, there was not a cold pull done before or after which can skew numbers too of course. On this day, that is what the car came in at, and how it left. |
09-29-2016, 09:44 AM | #7 |
Drives: 2006 Z06 Join Date: Oct 2010
LG used the dyno exactly how it should be used, solid before/after gains. Anything else has so much error it is almost useless to compare. Same car could go on a different dyno and lay down 550rwhp, but it would have baselined higher.
Props to LG and keep up the good work.
Nick
Corvette Z06 -1200ish rwhp |
09-29-2016, 08:50 PM | #8 | ||
"BEASTM*DE"
09-29-2016, 09:15 PM | #9 |
Car should be at 515-530 no problem for sure... So the 50 WHP gain is good, but the car is a dud I'd guess. Sometimes it has to do with boost leaks and stupid crap like that...I would say that it's a possibility that it was "unmodified" incorrectly (Since it was modded but returned to stock to sell), but that doesn't work because the tune and LG's work should have reversed it and brought those numbers back up to ~520 WHP.
09-29-2016, 09:15 PM | #10 |
I wish I worked for LG. If Anthony or Lou want to offer me a job I'll take it.
Dynos are tools to tune and show gains, not end all numbers. It gained 50+hp before/after. That is all that matters, not the end numbers.
Nick
09-29-2016, 09:42 PM | #11 | |
Drives: 2015 ZL1 Join Date: Dec 2015
There is a lot of smart people on this forum. But dyno numbers that are too good to be true... Usually are that, pretty much an ego stroke in exchange for your money. Take your car to at least 2-3 dyno's... Somebody that didn't work on your car and you will see this for yourself. LG is an accomplished road racer/builder, hence the +50 result. |
09-29-2016, 10:36 PM | #12 |
"BEASTM*DE"
Not trying to bash "LG" but any reputable tuner/shop should have been extremely concerned with the "overall" failed performance of the vehicle and at least attempted to diagnose the problem...Maybe the previous owner used bad fuel and the car is in limp mode..."LG" should have the owner bring the car back in source the potential problem and put it back on the dyno or work out a deal with another tuner to be dyno'd elsewhere and if the numbers are the same then the owner has a real issue with the car...
09-30-2016, 11:03 AM | #13 |
Drives: 2017 Red Hot ZL1 Join Date: May 2015
Isn't the best "real" world test before and after slips from the 1/4?
09-30-2016, 12:03 PM | #14 |
"BEASTM*DE"
No because there are to many variables, driver, car, track, weather, etc...
