11-25-2023, 03:08 AM | #1 |
Mcleod Twin Disc and Ram Clutch Slave
I had a question regarding the ram clutch slave. I am installing a mcleod twin disc clutch onto my Camaro 2011 SS w the Ram slave and do NOT wanna mess it up!!!
Looking at the instructions on how to measure for proper fitment. I just wanted to verify that I am doing my measurements correctly because I did not have to use any shims and I got a gap of .195 which is perfect. For the clutch, is it from the top of the clutch fingers to the bottom of the flywheel? Like the image below! For this measurement I got: 3.634 For the engine measurements, where exactly do I measure? Is it from the crankshaft flange to where that arrow is pointing to (The silver part) or where it is circled? (gray part) (not my engine) For this measurement I got: 0.178 and that’s from measurement from the silver part! For my last measurement which is the bell-house to the clutch slave pressed down, i got: 4.007 Which B - (A+C) = .195 ( i didn’t have to use any shims! And you should I also get the ram pedal adjuster?? |
11-25-2023, 12:08 PM | #2 |
You might want to ask in this section. There is no "Camaro team" anymore.
https://www.camaro5.com/forums/forumdisplay.php?f=76
11-25-2023, 02:47 PM | #3 |
thank you
11-25-2023, 04:39 PM | #4 |
Tags |
camaro, ram slave |
