dave@hennessey
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro Z/28 Forum - Z/28 Specific Topics
Old 10-16-2013, 10:16 AM   #1
mkorgan
Drives: 1970-1/2 Z-28, 2017 ZL1
Z/28 Wheels / Tires on ZL1
If this is posted in the wrong place, please excuse me and/or move to where it belongs .
From my uneducated perspective, the wheel/tire combo on the Z/28 is one of the biggest advantages it has over the ZL1 based on the recent video. I understand weight, multi-matic suspension, and CCB also are huge in the equation as well. BUT, as a ZL1 owner, I don't want to strip my car of the creature comforts, remove the MRC, or put $15K+ into CBB so that leaves me with the wheels/tires which I absolutely love.
Which leads me to this...I know they may stick out a little bit beyond the fenders without the extensions that are on the Z/28, but will they work otherwise? Will they fit over the BREMBO calibers and will I have in well rub on tight turns?
mkorgan is offline   Reply With Quote
Old 10-16-2013, 10:35 AM   #2
Dropspeed
2013 Camaro SS1LECTSVZ28
Dropspeed's Avatar
Drives: 2013 AGM 1SS/1LE
They will stick out over 1 inch (20mm/23mm) at all 4 corners...Without the fender flares this will look odd, will mess with your aerodynamics (4 tires sticking out dragging in the wind) and the car will have less ground clearance.
Z/28
19 x 11 ET11
19 x 11.5 ET 26
ZL1
20 x 10 ET23
20 x 11 ET43
Your gearing will be off and your car will also sit lower.
305/30/19 = 26.2 OD
285/35/20 = 27.85 OD
305/35/20 = 28.40 OD
It will sit .825" lower in the front and 1.1" lower in the rear.
Will I be using this set-up for track events? YES!
-Matt
Dropspeed is offline   Reply With Quote
Old 10-16-2013, 11:44 AM   #3
mkorgan
thanks matt. I guess that answers that.
Old 10-21-2013, 06:41 PM   #4
tomster
RedLine
tomster's Avatar
Drives: 2022 ZL1 1LE
has anyone seen the fender flares on the z/28 for sale?
2018 GMC 2500 "Blue" (Sold)
2018 ZL1 1LE Hyper Blue" (Sold)
2018 CTS-V "Black" (Sold)
2022 GMC 2500 "Blue"
2022 ZL1 1LE 6spd "Rapid Blue"
2023 ZL1 1LE Auto Rapid Blue (ordered)
tomster is offline   Reply With Quote
Old 10-21-2013, 06:42 PM   #5
SSTG
Drives: 2014 Z51 Corvette
There will be Aftermarket wheels available I'm sure.
Fitment won't be an issue then.
SSTG is offline   Reply With Quote
Old 10-21-2013, 06:49 PM   #6
Great answer Matt..
Old 10-24-2013, 07:45 AM   #7
NinoSS
Drives: 2SS/RS CGM LS3
Originally Posted by Dropspeed View Post
They will stick out over 1 inch (25mm/23mm) at all 4 corners...Without the fender flares this will look odd, will mess with your aerodynamics (4 tires sticking out dragging in the wind) and the car will have less ground clearance.
Z/28
19 x 11 ET11
19 x 11.5 ET 26
ZL1
20 x 10 ET28
20 x 11 ET43
305/30/19 = 26.2 OD
-Matt
The ZL1 fronts are 20x10 +23, you are correct about the rears 20x11 +43.
There are pics of the inside barrel I took of mine in the link below.
http://www.camaro5.com/forums/showth...ghlight=offset
Current - 2018 NGM 1LE (LT4 conversion coming soon)
SOLD 2010 LS3 / Vengeance stage I cam / CAI intake w/ADM race scoop / Dynatech LT's / Eaton Posi LPE-JRE 3.91's / L99 Corsa / ZL1 wheels / NT05 275/315
NinoSS is offline   Reply With Quote
Old 10-24-2013, 09:58 AM   #8
woodside783
Casey Woodside
woodside783's Avatar
Drives: a very fun car
305 on all corners it dose not stick out as much but the camber in the front was messed with to help with that
Instagram @caseywoodside
http://youtu.be/CSc9aPh_X_w
woodside783 is offline   Reply With Quote
Old 10-28-2013, 12:10 AM   #9
j-rho
Drives: '67 Z28
Has anybody tried fitting a 305 width front tire on these cars? For the ZL1 or 1LE with the 10" wide front wheels, how much room remains inboard once you've maxed out negative camber?
j-rho is offline   Reply With Quote
Old 10-28-2013, 07:45 AM   #10
Norm Peterson
corner barstool sitter
Norm Peterson's Avatar
Drives: 08 Mustang GT, 19 WRX
Look around in JusticePete's posts - I think 305's are what the Pedders car was running in the Optima events before we heard that's what the Z/28 was going to be getting. I don't think the wheels were as narrow as 10.0 either.
Maybe try the Suspension/chassis/brakes and Camaro Motorsports sections.
Norm
Old 10-28-2013, 08:20 AM   #11
gen=5
gen=5's Avatar
Drives: 13 ZL1 vert blac fastlane/LPE 750
gearing wont be a big deal,that can be tuned for the speed-o, just have more low end,lol
http://www.camaro5.com/forums/showthread.php?t=346589 CHECK OUT THE BUILDING OF MY RANCH FOR DISABLED VETS, COMPLETE WITH A GUN RANGE .
gen=5 is offline   Reply With Quote
Old 11-04-2013, 10:45 AM   #12
Dropspeed
Dropspeed's Avatar
Corrected...Thanks!
Old 12-23-2013, 08:51 AM   #13
Kevlar382
Kevlar382's Avatar
Drives: '12 ZL1; '71 RS/Z28; '99 Vette Conv
I would think one of the biggest advantages of the Z/28 is it's brakes. The fresh air box is a plus also. Those two things done to a ZL1 would really help close the gap on a race track.
Kevlar382 is offline   Reply With Quote
Old 12-24-2013, 10:13 PM   #14
Mgizzle
Mgizzle's Avatar
Drives: 2013 Camaro 1LE 1SS
I am really thinking of getting a set for my 1LE. The drag is not that important at the low speeds we see at tracks for 95% of time. However the reduction in unsprung rotational mass is NUTS and outweighs the drag issue if you ask me. With 2deg of camber they will tuck in nice.
I will be honest though....., and probably get flamed..... I will still stay 285 or 295 on the tires. 305 is not necessary if you ask me, I rather take some more weight out and not destroy the steering feel in the street.
I work for General Motors and am not an official spokes person for General Motors. My views and opinions are my own and not those of General Motors.
Mgizzle is offline   Reply With Quote
