01-11-2018, 07:59 AM | #15 |
What's odd is there is lines on the smooth side (were the smooth idler rides)
Unless those are cut threw lines (very tight tension)
2016 Camaro 1SS, Red Hot, K&N Blackhawk intake, Whipple Supercharger, 3.125 pulley, Kooks 2" long tube headers, High flow cats, secondary cats delete, Mishimoto catch can, P3gauge, Lots of dress-up crap that don't make it go any faster.
Car Journal http://www.camaro6.com/forums/showthread.php?t=490975 SC build http://www.camaro6.com/forums/showthread.php?t=492656 Drive, Ride, Fly It Like You Stole It GO BIG OR GO HOME |
01-11-2018, 08:02 AM | #16 |
Drives: Summit white 1le ss Join Date: Feb 2017
01-11-2018, 08:16 AM | #17 |
LOL, if it's cutting the belt...I would agree. I put a mark in the center of travel of spring tensioner (loose/tight) marked it. Installed belt, rolled it threw, noted were adjustment was (center)
SIDE NOTE: Pic is new belt, belt looks the same right now. NO white (like cords) popping threw. Roll it over, pull in-between grooves. Is it cutting??
Car Journal http://www.camaro6.com/forums/showthread.php?t=490975 SC build http://www.camaro6.com/forums/showthread.php?t=492656 Drive, Ride, Fly It Like You Stole It GO BIG OR GO HOME Last edited by brettman; 01-11-2018 at 08:47 AM. |
01-11-2018, 08:15 PM | #18 |
Drives: Black 2017 Camaro SS 1LE Join Date: Dec 2016
Here is a video of one of my idlers needing replacement. It was the only one that had lateral movement. Not sure if was bearings but Whipple has shipped me a new one that is still sitting in NC with FedEx. Hopefully I'll have it tomorrow. I'm not sure about the belt so I'll take a look at mine tomorrow to see if there is any abnormal wear. My initial issue that I noticed was the sound.
https://drive.google.com/file/d/1Jpx...ew?usp=sharing
2017 1LE SS Black - Mods - Forged - lowered compression - BTR custom Cam - Whipple, 3.500 upper and 8.0 lower pulley, Roto-Fab, 1 7/8 Kooks headers, off road pipes, & 3" Kooks full exhaust. LT4 fuel system, with Alky single nozzle running 100% meth. (not installed yet) DSX Tuning flex fuel and DSX tuning Aux pump
01-11-2018, 08:32 PM | #19 | |
01-11-2018, 08:38 PM | #20 | |
Besides the belt how has it been? Don't believe I've seen a Dyno sheet yet.
01-11-2018, 08:42 PM | #21 | |
01-11-2018, 08:48 PM | #22 |
AHHH MAN... That's going to be fun to learn how to drive her all over again. And you did the drop in pistons for extra security. So Jealous. And to top it off you are in Florida where you can actually drive it in the winter. I would definitely do a half mile run with that setup.
01-19-2018, 08:05 AM | #23 |
WELL, what is end result??? INFO is good.
01-19-2018, 08:34 AM | #24 |
Looks the the crank pulley might have had bolt not completely tight possibly was vibrating causing the issue. All the other pulleys were lined up and checked out okay. Addressed the crank pulley and swapped to the green belt. All seems well but only time will tell as this isn’t my daily driver
01-19-2018, 08:40 AM | #25 |
Great, wobble under groove side. That would tear up a belt. Who installed the pulley? Blue locktighted?
01-19-2018, 08:59 AM | #26 |
Not sure of last shop had to remove it when they did the cam.
01-20-2018, 10:30 AM | #27 |
WELL?? what is the status?
I can't find what belt you are using? Did you post a PN#?
01-20-2018, 11:53 AM | #28 |
Everything has been put together and seems good the part number is same that whipple uses just put hd at the end nappa sells it
