03-07-2024, 08:21 PM | #43 | |
Drives: 23' 2SS 1LE M6;19' Sierra 1500 AT4 Join Date: May 2023
03-07-2024, 09:27 PM | #44 | |
Electrical Engineer
2023 1SS A10 Black NPP/C2U/H72 - Daily Driver
Historically an Accord and Camry owner with self-performed maintenance/repair. 1100: 5/3/22 . . . . . . . 2000: 6/25/22 . . . . . .4000: 8/17/22 . . . . . . . 6000: 9/10/22 Daily Driver mileage update: 22k mi. @ April 2024 New Engine @ 22,600 Build Log: https://www.camaro6.com/forums/showt...6#post11353116 |
03-07-2024, 09:43 PM | #45 | |
Electrical Engineer
If an OBD doesn't work, and we have a dozen different ways to make that happen, thieves will just move on and not risk being out there going through the list.
03-09-2024, 06:11 PM | #46 |
Drives: Camaro SS Join Date: Aug 2023
Steering lock bar is a good deterrent. They see that most peeps will move on to another car without the bar.
03-12-2024, 02:01 PM | #47 |
Drives: 2019 Camaro 2SS Join Date: Apr 2023
So I've been following this thread and want to do some things to prevent theft. I've ordered the OBD2 replacement plug, and going to reroute the real one some place inconvinient. Curious about the fuse for the data link connector. I'm not sure what all runs off that, is it just the OBD2 plug? I want to just pull it and then plug in the OBD2 tester and see if it is dead. I'm a little nervous as I don't want to damage anything. If this worked I would just plug in a blown fuse here. Any thoughts or advice welcome. TIA. Wanted to add I did get the faraday fob pouches that work great.
03-12-2024, 04:41 PM | #48 |
Drives: '22 LT1 Coupe Join Date: Nov 2021
It would be cool if someone produced a self-powered dummy OBD 2 port that would indicate connected status when a device was plugged in, but offer zero functionality. It would not be connected to any wiring from the car. Maybe it could be powered by a lithium ion battery. That battery would connect with a proper looking wire harness that passes cursory visual inspection. The original OBD would be relocated.
03-12-2024, 05:56 PM | #49 | |
I removed the fuse for the data link connector then checked at obd2 port. Was'nt any power to it. And no codes either. I just need to get some more fuses, fry one and use as a replacement. For me, I'll be happy with this set-up. |
03-12-2024, 06:02 PM | #50 |
According to the below post...they do make self-powered scan tools.
See this: https://www.camaro6.com/forums/showt...621494&page=19
03-12-2024, 07:18 PM | #51 | |
RUXIFEY Smoked LED Side Marker Lights / Black SS emblem on rear bumper / Blue SS vinyl overlay on front bumper emblem / Wildhammer Rear Dark Reflectors / Trim Illusion Gloss Black Door Handle Covers / eBay Black Fuel Door / Screaming Chicken Fender Hash Marks / Color-Matched G2 Caliper Paint RE Audio RFX10D4 10" Sub / Hand-made sub enclosure / Hifonics Zeus ZRX1200.1D amp / JL Audio LoC-22 line output converter / Sub Thump Plug N Play T-Harness With ANC Defeat Harness Kit My Camaro Journal |
03-12-2024, 08:03 PM | #52 | |
Drives: 2022 Vivid Orange Metallic LT1 Join Date: Mar 2020
03-12-2024, 10:01 PM | #53 | |
03-12-2024, 10:08 PM | #54 |
Thank you for posting this. I had trouble with the other pins as well. They would not plug together with obd2 connector. I'm still working on it. I'll get some of these pins. I appreciate your help.
03-13-2024, 06:45 PM | #55 |
Drives: 2019 LT1 Join Date: Feb 2024
What if you just ground the data bus?
03-15-2024, 01:10 PM | #56 |
Some great ideas in this thread. I have some questions…The vehicle will only allow eight RKE transmitters to be programmed to the vehicle. I am curious if the thieves process also overrides this? Can they make infinite keys or would they be stopped if the actual owner maxed out the RKE transmitters at 8?
