Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing
Old 01-21-2016, 11:08 PM   #1
C-redfly
C-redfly's Avatar
Drives: 2013 VR vert ZL1
Is my weak start up linked to my battery
In the morning or after a 12 hour day at work, my camaro has a weak start up. It starts perfectly after I drive it and stop for something and get back in it. I'm thinking it could be time for a new batter. Car was built May of 2012.
Sent from my Nexus 5 using Tapatalk
C-redfly is offline   Reply With Quote
Old 01-22-2016, 07:47 AM   #2
clashley1976
clashley1976's Avatar
Drives: 2011 Camaro 2LT RS M6
Seems likely. Auto zone will test the battery for you.
Sent from my SM-N920V using Tapatalk
-Cameron Lashley
Albany, GA
2011 Camaro 2LT/RS 3.6L M6 Summit White w/silver rally stripes
CAI intake, VTC, VMax PTB, VMax Iceolator, Apex intake scoop, Roto-Fab washer bottle relocate
Build Journal: http://www.camaro5.com/forums/showthread.php?t=419992
clashley1976 is offline   Reply With Quote
Old 01-22-2016, 04:23 PM   #3
C-redfly
C-redfly's Avatar
OK thanks. Should I go with the original ac delco battery?
Old 01-22-2016, 06:15 PM   #4
Olddudesrule
Resident nomad
Olddudesrule's Avatar
Drives: 2014 Summit White 1SS/1LE
Agree that your battery is probably getting on in years, and likely needs replacement. You can have it tested, but 3-5 years, even when using a battery tender religiously, is sometimes stretching it. I think the OEM Delco is fine, and if it lasted you 5-6 years, then I guess that's further proof. As with many items for our cars and others, there are many good choices out there. Do a little internet and forum searching, and you'll read many recommendations.
Whatever you choose, make sure to check the date sticker on the battery to make sure you're getting the freshest battery they have. The ones at the front of the display are often up to a year old.....no bueno. I never buy a battery that is older than 2-3 months or less.
Sold:
2007 Z06
2002 Viper GTS/ACR
2003 Z06
1965 FFR Cobra
2012 Nissan 370Z
ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing.
Olddudesrule is offline   Reply With Quote
Old 01-22-2016, 06:56 PM   #5
Dimitrim
Dimitri
Drives: 68 GTO 455 Ram Air; 2014 Camaro ZL1
http://batteryuniversity.com/learn/a..._glass_mat_agm
I would look into getting a AGM type battery. It stands for
ABSORBENT GLASS MATT
It is a lead acid battery, but you never have to add water to it.
Also make sure to charge the new battery till it is completely charged before starting it for the first time.
Dimitrim is offline   Reply With Quote
Old 01-22-2016, 07:30 PM   #6
witenite
witenite's Avatar
Drives: 2010 2SS non RS
Iam still on the original battery, I know Iam stretching it but still starts nice all the time. No weak starts at all. Been sitting since Tuesday, so we will see how it starts after this snow storm.
Old 01-22-2016, 10:35 PM   #7
Lil' Nasty
[COTW 4/13/15]
Lil' Nasty's Avatar
Drives: Supercharged LLT
It's a good battery. Mine gave out after six years. Build date Sept '09 + however old the battery was.
I went with a Braille battery and works great.
Lil' Nasty is offline   Reply With Quote
Old 01-22-2016, 10:37 PM   #8
C-redfly
C-redfly's Avatar
Thanks for the tip. Isn't the braille battery light? Does it bolt up in the original battery allotted spot?
Old 01-23-2016, 08:48 AM   #9
Lil' Nasty
[COTW 4/13/15]
Lil' Nasty's Avatar
Yeah they're much lighter than stock. I went with the 21 pound (OEM is like 44lb).
You have to put some soft foam to raise it up and on its sides to make it work. Not hard At all but you just don't want it moving around and such.
Old 01-23-2016, 08:50 AM   #10
Lil' Nasty
[COTW 4/13/15]
Lil' Nasty's Avatar
Stock vs Braille
Old 01-23-2016, 12:22 PM   #11
Mr. Nasty
Emerald Coast Camaros
Mr. Nasty's Avatar
Drives: 2010 RS/SS Rally Yellow & 68 SS
Lil' Nasty how does it do after setting for a while?
Best @ 586/525 =10.41 @ 133
AS OF 12/13/14>633 RWHP =10.22@135
AS OF 1/31/15 @ 633 RWHP=10.16@135
AS OF 1/29/16 @ 633 RWHP=10.10@136
TOPED 700 PASSES AFTER F.I. AND STILL ON THE ORIGIANAL STOCK AXLE & DIFF
Mr. Nasty is offline   Reply With Quote
Old 01-23-2016, 04:33 PM   #12
Lil' Nasty
[COTW 4/13/15]
Lil' Nasty's Avatar
Cranks fine. Drive it once or twice a week and no problems. No trickle charger either. I wouldn't go below the 17 or 21 pound Braille battery. As it may require a trickle charger.
Old 01-23-2016, 11:29 PM   #13
Nessal
Drives: Exige, Miata, Ghia
Keep in the mind that the smaller batteries have lower reserve charge as well. So don't think that you can sit in a drive-in theater and watch two shows without worrying.
Nessal is offline   Reply With Quote
Old 01-25-2016, 01:37 PM   #14
Mr. Nasty
Mr. Nasty's Avatar
LOL drive-in theater. Not many of them left. It would be a 3 hour drive for me. So no worry their.
