Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Wheels and Tires Talk Sponsored by The Tire Rack
Old 10-12-2015, 07:35 PM   #1
Retro69
Retro69's Avatar
Drives: 2018 Camaro ZL1
Reprogram Low Tire Pressure Limit?
I have a 2011 SS with ZL1/1LE wheels and tires. On the street I run them at 32 psi which is what's recommended on a 1LE. My TPMS runs about 2 psi low so between that and 32 psi I get low pressure alerts until the tires warm up. On cooler days I may never get the pressures up.
Can the low pressure limit be reprogrammed for the lower tire pressures? Is this a BCM function?
Retro69 is offline   Reply With Quote
Old 10-12-2015, 08:23 PM   #2
X25
X25's Avatar
Drives: '16 C7 Z51
I don't think it's programmable, except perhaps by GM, itself? I'd love to learn, too. Hoosier R7s exceed 50 PSI, which might cause issues.
By the way, just in case you didn't know about this, I think your TPMS is measuring it right, if only you were at sea level. The sensors we have measure absolute pressure, while we get absolute - atmospheric pressure reported on TPMS screen. If you live in high altitude, your ambient pressure will drop, and your handheld pressure gauge will report higher numbers than TPMS, since it measures relative pressure, not absolute.
'16 Corvette C7 Z51 1LT (Build Thread)
'14 AGM 1SS 1LE [COTW 11/17/14] (Build Thread) (SOLD)
'13 Mazda MX-5 Club (Build Thread)
'17 RAM 1500 Crew Cab 4x4 Night Edition
'15 Nissan Rogue S AWD
X25 is offline   Reply With Quote
Old 10-12-2015, 08:48 PM   #3
JimE
JimE's Avatar
Drives: 2013 2SS/RS/1LE
I'm surprised you are getting an alert. My cold pressures are 28.
I'm also having a slow leak in the RR. When I first caught it, I didn't get an alert until it was down to 24 I believe. I don't see how you are getting alerts, or why an '11 and '13 would be that different. In other words, it sounds like a system fault, not a programming issue (unless it's programmed completely wrong).
JimE is offline   Reply With Quote
Old 10-12-2015, 09:05 PM   #4
Retro69
Retro69's Avatar
I am at approx 5200 ft. You would think they would compensate for that though.
Old 10-12-2015, 09:58 PM   #5
Retro69
Retro69's Avatar
Yeah I'm not sure what is going on. Its pretty predictable though.. I always set the pressure using a high quality gauge after the car has sat overnight in the garage. After driving approximately 15 minutes any tire that hasn't reached 31 psi as per the TMPS I get the low tire warning.
I could always just ignore the warnings but if I had a *real* tire problem I might miss it until it's too late.
Sent from my iPad using Tapatalk
Old 10-13-2015, 05:24 PM   #6
GVA 45TH 2SS
KNGTFALL
GVA 45TH 2SS's Avatar
Drives: 2012 2SS 45th edition
Sorry I only can tell you the best way to heat up the back tires
GVA 45TH 2SS is offline   Reply With Quote
Old 10-13-2015, 05:31 PM   #7
Retro69
Retro69's Avatar
ROFL I know that trick but my wife is already questioning my tire budget!
Old 10-13-2015, 05:56 PM   #8
Fish-man
Drives: too many to say!
perhaps the dealer can lower it.
Ask them if they can call for a calibration from the 1le...
Fish-man is offline   Reply With Quote
Old 10-13-2015, 06:23 PM   #9
Retro69
Retro69's Avatar
Worth a try I suppose. Thanks for the suggestion.
Old 10-13-2015, 07:15 PM   #10
JimE
JimE's Avatar
I would talk to them anyway. I don't see why you would get an alert for 31psi.
My tires yesterday were 28/28 fr and 28/26 rr No alerts. I would expect programming to be the same across all models. The recommended pressure is the same.
Old 01-31-2024, 01:02 PM   #11
brettstoner
brettstoner's Avatar
Drives: 2014 Chevy Caprice PPV L77
Yes you can program the TPMS PSI threshold or the dealer could do it for you if they wanted to. You need a VXDiag VCX Nano as a pass-through device so your laptop software can communicate with the car. You then use Tech2Win (2013 and older) or GDS2 (2014 and newer) software to program the front/rear pressures. You have to enter it as KPA instead of PSI. The software asks you what is the door placard so you would enter the KPA equivalent of what you want to run. Federal regulations require the low tire warning to come on when the pressure is 75% of what the vehicle is programmed for (which is the door placard if not changed).
2014 Caprice PPV, 6.0L, BTR Stage 2 LS3 N/A Cam, 2" ARH, 3" custom exhaust, 3.45, Circle D triple disc converter, Lloyd Elliot heads, Rotofab intake, Chris Henry tuned, future LSA....
brettstoner is offline   Reply With Quote
