02-03-2023, 09:41 PM | #1 |
Drives: 2015 Summit White 2SS 1LE Join Date: Feb 2012
CFD xmember flanges
CFD xmember flanges are installed finally!
Oil pan drops will be cake now 😉 Took it back apart to prime and paint. Let the primer cure overnight and paint tomorrow. They take 7/16 bolts 1.5" long.
Retired wanna be cylinder head porter
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter Totalled: 2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X |
02-04-2023, 09:16 AM | #2 |
Very nice work sir!!
02-04-2023, 07:48 PM | #3 |
Drives: Chevrolet Camaro SS Join Date: Jul 2021
Thinking of doing this. Would also need to find someone local to do a good job on the cut and weld.
02-04-2023, 08:16 PM | #4 |
2&THEHIT
Drives: 5th Gen Camaro; 5th Gen Ram 3500 Join Date: Mar 2018
Oh man, sooo much easier now
02-04-2023, 10:30 PM | #5 |
Local muffler shop should be able to.
02-05-2023, 05:14 AM | #6 |
nice Bo!
2014 Camaro SS L99, Ashen Grey w/Black Leather - Build thread - http://www.camaro5.com/forums/showthread.php?t=491561
Mods - GPI 416 w/Custom Grind Cam, Ported Heads & Tuned by Ben, Holley Dominator ECU, Mag Heartbeat, ZL1 Fuel Pump & DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Circle D 3600 Triple Disc, Kooks Headers, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Gulfcoast Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP |
02-05-2023, 06:25 PM | #7 |
Drives: ABM #93 Join Date: Oct 2018
Nice, I’m gonna do this to mine when I put the cam in it.
ABM #2399 2SS/RS:SOLD
ABM #93 2SS/RS Black Rally stripes, Titanium Interior 4,000 miles: GM GFX side skirts and diffuser waiting on paint, GM dovetail, GM heritage, RPI ZL1 style splitter. ‘87 IROC-Z Iroc blue. all original unmolested with 50K miles. |
02-10-2023, 02:07 AM | #8 |
Drives: 15 Camaro 2SS M6 Join Date: Jan 2020
are these flanges still available? that is a great idea and something I could definitely use!
02-10-2023, 04:05 AM | #9 |
Drives: 2012 Chevrolet Camaro l99 Join Date: Aug 2020
It's still not as easy as you would think. Trying to get the oil cooler off the side of the pan is a task, getting the wiring harness under the pan off and back on is a pita, and you have to unbolt your rack and pinion from the subframe and push it forward on the 2010 to 2013 models (I'm not sure about the electric power steering models 14-15). And you'll more than likely to have to have it realigned after unless you have a good method for marking the rack and pinion but sometimes you get lucky. But it still beats the alternative. lol
DSS FX Forged Pistons, Eagle ESP L19 Forged Rods, ARP Head and Main Studs, TSP PRC 260 CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnions , Molly Pushrods, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP 1 7/8" Longtubes with 3" TSP Exhaust, ZL1 Fuel Pump, Mishimoto Radiator, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter, Fluid Dynamics Balancer
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817 |
02-10-2023, 09:08 PM | #10 |
02-11-2023, 09:49 AM | #11 |
Drives: 2013 ZL1 Join Date: Sep 2021
The rack and pinion has nothing to do with alignment..
02-11-2023, 09:56 AM | #12 |
The hell it doesn't. When you unbolt it, it will move around on the subframe. Since the bolt holes are bigger then the bolts there self it's very hard to get it lined back up in the same place when you bolt back in. I know from experience because I've unbolted it to take the pan off 4 times and only got lucky once putting it back to where it was.
02-11-2023, 04:07 PM | #13 | |
Drives: 2010 camaro ss Join Date: Aug 2021
Didn’t have to touch my steering rack. Bought one of these from harbor freight unbolted the motor mounts and lifted the motor as high as I could. I got the oil pan out no problem after I cut the cross member. Sent from my iPhone using Tapatalk |
02-11-2023, 04:24 PM | #14 |
Well good for you. There's apparently more then one way to do it.
