01-07-2013, 12:04 AM | #1 |
Normal or NOT ??
So after i installed (X-Force 3" 1 7/8 LT Headers, Borla ATAK and Roto-fab CAI) i got my car
tuned and the car came up pretty good except for one thing and it's driving me crazy , when i race another car (rolling from 40 or 80 km) almost every time i get to take the lead in first through fourth gear and once i shift into fifth the the RPM goes to nearly 4500 which will give the other car a pretty good chance in coming back and start pulling me, so my problem is in fifth gear why it's the only gear that goes below 5000 RPM do i need another tranny tune ? I posted this in the tuning section a couple of days ago and i got 0 response from almost 90 views so i figured it was the wrong section
X-Force 1.7/8 3" LT Headers, Borla ATAK 2.5" Cat-Back, Roto-Fab CAI 365 RWHP SAE Corrected |
01-07-2013, 12:14 AM | #2 |
V8 Lounge member #2
Drives: 2001 Ws6 Join Date: Sep 2009
Just use the lambo instead. Then you'll be ok.
2001 ws6, 40k miles, Ls3 416 stroker, short block built by PER the rest by me. LPE Ls3 heads milled to 12-1 comp, FAST 102, NW 102, kooks 2", dual DMH cutouts, Magnaflow C/B, BTR cam + springs. Full UMI suspension.
01-07-2013, 01:10 AM | #3 |
Drives: ETMC built 700+hp Twin Turbo LS3 Join Date: Apr 2010
01-07-2013, 01:24 AM | #4 |
MM.CC
Drives: 2010 Camaro 2SS LS3 Join Date: Jan 2011
yeah most likely you might need to tune your tranny. get the shift points to engage higher.
01-07-2013, 02:03 AM | #5 |
haha
i'm just a little short on cash
01-07-2013, 02:05 AM | #6 |
i've already talked to the guy who tuned it first and i told him about my issue i'm going back to his shop next weekend to see what he could do
01-07-2013, 07:19 AM | #7 |
Drives: 2015 Summit White 2SS 1LE Join Date: Feb 2012
Gear swap.
Retired wanna be cylinder head porter
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter Totalled: 2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X |
01-07-2013, 09:15 AM | #8 |
Drives: 2011 Inferno Orange SS Convertible Join Date: Apr 2012
It is the step from 4th to 5th. 2 main options......
Set the 4-5 shift point quite a bit higher, which isn't safe on the engine if it is stock, or, Put in a higher stall converter. You will love it all around, and it will keep your rpms from falling way down after a shift. Keeps you in the powerband. I just ordered one from Jannetty for my car. I have ran 2800 to 3200 stalls in many street cars and it is the best bang for the buck mod IMO, short of nitrous. |
01-07-2013, 09:59 AM | #9 |
Drives: 2016 2SS coupe 2015 3LT Stingray Join Date: Aug 2012
the tecu is inside the valvebody of the trans your tuner should have tune it along with the ecu they uasually adjust shiftpoints and remove some torquecontrol
Ported intake manifold and throttle body kooks 2" headers no cats
01-11-2013, 10:21 AM | #10 |
I should add...5th is an overdrive gear, which is why you notice the big drop. You must be FLYING to get a 4-5 shift at wot.
There are other options but none are real good or real cheap..... Add more power by supercharging or whatever. Lots of power and a 4-5 WOT shift might end the trans life though. Install a real tall gear so you don't hit 5th until a higher mph, one that you won't get to. You would lose low end grunt though, and you would need to know what mph you plan on racing to, which is usually a variable. Install a real low gear so you go into 5th much sooner, but that will be hard on the trans since you will be 4-5 WOT shifting more often, and traction will be tough. I think a higher stall converter is your best option. One thing to have your tuner check.....see when the torque converter is commanded to lock at WOT in the tune. It is possible that it is locking up before or during the 4-5 shift. Even with the stock converter, keeping it unlocked until a much higher mph at WOT will help solve your problem, if it really is locked up before the 4-5 shift. Make sure you mention this to the tuner because it may be a cheap easy fix for you.
2011 SS IOM Vert. ECS Vortech 13+ psi, Water/Meth, ID850’s, ZL1 pump with MSD Voltage Booster, 2800 stall, LT headers, Drag radials, Drag alignment, Cradle Bushings. A million other supporting mods. Tuned by Ted.
01-11-2013, 11:15 AM | #11 |
I'm a lucky dude
Drives: 2010 SIM 2SS/RS #1226 Join Date: May 2012
Didn't think anyone from saudi was short on cash.
Best of luck.
KB supercharged, Meth injected, Kooks sig series, Corsa cat back, Eibach pro kit, engine mods by me, Tuned by Next Level Performance, 2 tons of fun.
