01-01-2018, 10:14 PM | #15 |
Drives: 2SS 1LE Join Date: Oct 2011
Must be all those damn intercoolers.
01-02-2018, 02:12 AM | #16 |
Drives: 2017 Camaro 2SS, Bright Yellow Join Date: Sep 2017
I had this happen to me last week (I’m in the North Country region of NY). I pushed on the left side until it crunched all the way down, then I wrapped an old work ID from my wallet in a microfiber cloth and went around it gently prying/breaking the ice. It popped open about half way around. Once I got it open I proceeded to remove the built up ice that was on the inside.
01-02-2018, 05:40 AM | #17 |
Drives: 2018 Summit White ZL1 1LE Join Date: Jun 2017
portable battery operated heat gun great for anything winter and frozen!
01-02-2018, 09:33 AM | #18 | |
Drives: 17 SS 1LE | 07 S2K Join Date: Sep 2017
Curious, though... would you risk scratching other colors? Summit White? Mosaic Black? |
01-02-2018, 06:47 PM | #19 |
Drives: 2017 1SS camaro ,2SS a 68 + 08 C6 Join Date: Dec 2017
NO !!!!!
Water freezes , pour warm antifreeze on it Or a blow dryer Do not use a torch or heat gun ( at close range ) |
01-02-2018, 07:12 PM | #20 |
Drives: 2018 2SS Camaro Hot Wheels Edition Join Date: Sep 2015
Zack46
2018 Camaro 2SS Orange Crush Hot Wheels Limited Edition Power Sunroof, 8 Speed Auto/Remote Start, NPP Exhaust Production Sequence Number 98 NEOCC Camaro Club Member Former Ride: 2016 Camaro 2LT RS V6 Hyper Blue Metallic |
01-02-2018, 07:31 PM | #21 | ||
Drives: 2011 2SS/RS LS3 Join Date: Nov 2011
Zack.....anti-freeze is not good for the paint..(google it)...As I suggested earlier, window washer fluid is probably safer....It doesn't freeze in it's reservoir, does it?...If it hurt the paint, they wouldn't have it squirting onto the windshield and roof of the car....
Found this also...good luck... Another one... |
01-02-2018, 09:02 PM | #22 |
You can use warm water as a quick solution while at the gas station, but then when you get home, do a more preventive measure to remove water/ice completely.
01-03-2018, 07:11 AM | #23 |
Drives: 2016 Ram 1500 Outdoorsman Join Date: Oct 2016
Me too... The current title is clickbait...
Past - 2002 Camaro Z28
Present - 2016 Ram 1500 Outdoorsman Future - 6th Gen Camaro SS |
01-03-2018, 07:17 AM | #24 |
Drives: '17 Camaro 2SS & '99 Camaro Z28 Join Date: Feb 2014
I'm actually kind of in awe that -5 is enough to freeze our gas caps shut. It's been down to the 20's here in GA and I haven't had any problems accessing my fuel tank.
01-03-2018, 08:10 AM | #25 |
Drives: 2016 Camaro SS M6 Join Date: Oct 2016
Just pee on it.
01-03-2018, 08:16 AM | #26 |
Drives: '17 1LT RS V6 6M NPP Join Date: Apr 2016
01-03-2018, 05:41 PM | #27 |
Drives: '16 Z51 C7 Corvette Join Date: Jul 2017
Ouch.
-Josh |
01-03-2018, 09:52 PM | #28 |
I would try alcohol. Commercial deicing solutions contain methanol, but isopropyl (i.e. "rubbing") alcohol should do the trick. Also 95% or better ethanol. The mechanism is freezing point depression. Any small amount that mixes with the gas will not be a problem. Small quantities will not attack the paint.
