09-03-2015, 12:05 AM | #1 | |
Drives: . Join Date: Jul 2015
Motor Trend's ATS-V Review Harbinger of 6th Gen?
The V beats the C63 AMG on the track, puts down 0-60 in 3.7 and 1/4 in 12.1@ 116.2, 60-0 in 99ft(with 4 piston calipers). MT praises the chassis as one of the best.
Thoughts? |
09-03-2015, 12:55 AM | #2 |
1st Civ. Div.
Drives: Camaroless for now...RIP "Big SexZ" Join Date: Dec 2007
ATS-V should have won and the '16 Camaro SS LT1 with A8 will be a real 12 seconds/low 11 seconds street performer.
Swift....Silent....Deadly
09-03-2015, 01:12 AM | #3 |
Drives: Not a Camaro at this time Join Date: Mar 2009
Awesome, The Camaro is going to Kick some expensive car ass
Order Status:
2000 8/27/15 3000 9/3/15 2000 9/22/15 (Order changed) 2016 2SS With Auto, NPP, MRC, Nav, Split 5 Spoke Bright Aluminum. |
09-03-2015, 01:54 AM | #4 |
Drives: Impala Join Date: May 2015
Isn't the new ATS-V a TTV-6? If so, why the comparison to the Camaro?
Motor Trend also just did a first drive of the Mustang GT-350 and GT-350R. The ATS-V is hitting GT-500/R numbers with the best guesstimate of Motor Trend. "Consulting our vast cache of vehicle and performance data and applying a test-driver seat-of-the-pants algorithm, we say the 3,750-pound GT350 will run to 60 mph in 4-seconds flat and the GT350R, lighter by about hundred pounds but benefitting from wider/grippier rear tires and less rotational wheel weight, will do the same in about 3.7-3.8 seconds. The quarter-mile passes should come in at around 12 seconds at 120 mph." Read more: http://www.motortrend.ca/en/car-revi...#ixzz3kejwSVQ1 |
09-03-2015, 02:03 AM | #5 |
Drives: 2015 SS 1LE Red Hot, 1970 Chevelle Join Date: Apr 2012
The ATS-V compares to the SS for a few reasons. They are on the same platform. They should be similar in weight. They make similar power. They also have the same transmission options. The ATS-V makes more horsepower but less torque. It also has better tires. I think the SS will be slightly slower due to the tires.
09-03-2015, 07:44 AM | #6 |
Drives: 1981 silver corvette,Hyper Blue 2SS Join Date: May 2015
how do those numbers stack up against the '15 ZL1s?
09-03-2015, 07:55 AM | #7 |
Just thinking out loud, but how many runs/tries do you think these car reviews do before they pick the number they publish?
Order Status:
09-03-2015, 08:01 AM | #8 |
Probably doesn't like you
Drives: 2022 WCT ZL1 M6 Join Date: Jun 2015
Several. I read a column about that by one of the hot shoes, talking about how they treat the cars (not very nicely) during the intstrumented tests.
كافر ΜΟΛΩΝ ΛΑΒΕ железобетонное очко Quod gratis asseritur, gratis negatur. There is an unequal amount of good and bad in most things, the trick is to work out the ratio and act accordingly. |
09-03-2015, 08:08 AM | #9 |
Drives: 2005 Cobalt Base - 5 speed Join Date: Apr 2015
Man, if the performance exhaust adds the standard 5 hp / 5 tq and the 6th gen SS is rocking 460 hp / 460 tq... that puts it 4 hp less than the ATS-V, with 15 more tq. While being lighter (if they hit the weight targets). Seems like the 6th gen is going to be one awesome camaro.
09-03-2015, 08:41 AM | #10 |
Drives: 2014 2SS/RS 1LE Join Date: May 2013
I think the best take away from this is that he 6th gen has the potential to match or exceed the ATS-V numbers. I believe that the Camaro will be limited by the factory tire selection (ATS-V has Pilot Super Sports I believe) and possibly gearing selection. However all of the early adopters are going to be very pleasantly surprised by what their cars are capable of especially with and upgrade to some drag radials for straight line performance or something similar to the PSS for handling. This does however leave some room for improvement. I can see a possible reappearance of the 1LE package with a square tire set up and more aggressive gearing. This will be VERY impressive if offered.
09-03-2015, 08:46 AM | #11 |
Drives: 2010 Camaro 2LT Join Date: Jul 2015
Everyone seems to very worried about the tires. I have some hope not a lot but some that GM in their extensive testing that, the tires that were made for the car will do fairly well.
09-03-2015, 08:54 AM | #12 |
Drives: 67 goat, 69 goat ram air III Join Date: Mar 2009
Camaro and Cad are from two separate car divisions. So different engineers etc...He mention on the track that the Vette folks could/should talk with the Cads folks as to putting power down. So the Camaro will be different and just have to wait to see.
09-03-2015, 09:27 AM | #13 |
And the C7 and ATS-V are completely different platforms. The Camaro and ATS share the same platform architecture, but the Camaro at the same time has been customized for its application. They maybe separate divisions but they are using the same R&D and components. To me the tires are the big difference. This will probably put the 1/4 times about a tenth or two behind for the 6th gen.
Past: '99 SS Camaro A4, '73 Camaro 383 A3 "Voices in your head are not considered insider information." 3800 Status - 6/16/16 (Built!) 6000 status - 6/29/16 (Delivered!) |
09-03-2015, 09:59 AM | #14 |
Drives: 16 Camaro SS, 15 Colorado Join Date: May 2009
To me, it all depends on how well the Camaro SS can hook compared to the ATS-V. With different tires, and a different suspension setup (even though the platform, weight, power, and transmissions are all very similar) could reduce the 0 - 60 and 1/4 mile times.
If the Camaro can launch well enough, I don't see why we couldn't have a 0 - 60 number around 4 seconds, (give or take a few tenths) and a low 12 second 1/4 mile.
2010 Camaro 1LT V6 (Sold. I will miss her!) |
