07-21-2015, 11:29 AM | #71 | |
Drives: 2018 ZL1 6M, Silverado High Country Join Date: Oct 2008
Yes GM has put is some serious thought into tracking the SS camaro. Gonna be an awesome Car on and off the track
Current Vehicles - 2018 ZL1 Red Hot 6 spd manual, Carbon Hood, Sunroof 2019 Silverado High Country, Daily Driver |
07-21-2015, 11:46 AM | #72 | |
Drives: 1SS, A8, MRC, NPP, Blade Spoiler Join Date: Jun 2010
Another reason is when you add an oil cooler that uses engine coolant, you are putting more heat into your coolant. If you put more heat in, you should take more heat out, unless you have extra capacity, or don't mind pulling timing. Another reason is so the main radiator can be narower, allowing for big brake cooing ducts to run from the front lower grille to the brakes. I am totally sure the auxilliary radiators are for engine coolant. Here is an excerpt from the online order guide: Y4QHeavy-Duty Cooling and Brake Package, includes (KC4) external engine oil cooler, (V03) extra capacity cooling system and (J55) Brembo 4-piston front performance, 4-wheel antilock, 4-wheel disc brakes; also includes (V18) auxiliary engine coolant cooler with (LTG) 2.0L Turbo engine 1 - Requires (WRS) RS Package.A1A1-- -- JL9Brakes, 4-wheel antilock, 4-wheel discS S -- -- J6GBrakes, Brembo 4-piston front and rear, performance, 4-wheel antilock, 4-wheel disc-- -- S S J55Brakes, Brembo 4-piston front, performance, 4-wheel antilock, 4-wheel disc 1 - Included and only available with (Y4Q) Heavy-Duty Cooling and Brake Package.A1A1-- -- KC4Cooling, external engine oil cooler 1 - Included and only available with (Y4Q) Heavy-Duty Cooling and Brake Package.A1A1S S V03Cooling system, extra capacity 1 - Included and only available with (Y4Q) Heavy-Duty Cooling and Brake Package.A1A1S S V18Cooler, engine coolant, auxiliary 1 - Included and only available with (Y4Q) Heavy-Duty Cooling and Brake Package when (LTG) 2.0L Turbo engine is ordered.A1A1S S KNRCooler, rear differential-- -- S S KD1Cooler, transmission oil-- -- S S If you will notice, you can get a "Heavy-Duty Cooling and Brake Package" on non-SS models. Take a look at reference only RPO code "V18". It is listed as "Cooler, engine coolant, auxiliary". Also note that on LT models, you can NOT get a rear differential or transmission cooler. All of which is standard on the SS. Also, if you look at the picture I posted above, you can see one of the oil cooler lines is connected, and it runs under the A/C compressor, and right to the engine coolant line from the water pump. |
07-21-2015, 07:31 PM | #73 | |
Dances With Mustangs
Blue Angel is here!! 1SS/RS LS3 M6 IBM |
07-21-2015, 07:32 PM | #74 | |
Sent from my SAMSUNG-SM-N900A using Tapatalk
Past: '99 SS Camaro A4, '73 Camaro 383 A3 "Voices in your head are not considered insider information." 3800 Status - 6/16/16 (Built!) 6000 status - 6/29/16 (Delivered!) |
07-21-2015, 09:05 PM | #75 | |
Drives: 2017 Camaro 1SS M6 Join Date: Apr 2015
07-21-2015, 09:38 PM | #76 | |
http://www.camaro6.com/forums/showthread.php?t=416538 Here is the part I was talking about, sorry about the formatting issues. Hope this is better. |
07-21-2015, 09:50 PM | #77 |
This is a tough one, but I am going to guess yes by the guide, but my gut reaction would have been no. Here is why I think the guide is suggesting yes. Take a look at GW6 and GT4. They have an S (for standard) with a superscript 1 with a note telling you that this RPO is only available for a certain transmission. BUT, if you look at KD1, there is no such notation. Seems to be with either transmission.
08-10-2015, 04:56 PM | #78 |
Drives: '01 Camaro SS 'Vert; '02 Camaro RS Join Date: Apr 2013
Ok, this thread needs some photos of said coolers! Did anyone snap some at Camarofest? All of them, not just the 3 radiators... TIA!
01-09-2016, 05:23 PM | #79 |
Drives: 2016 Camaro 2SS, Nightfall Grey Join Date: Nov 2012
I agree, I would like to see there location. I recently had to tow my 2016 2ss to the dealership due to loss of coolant. There excuse was a rock hole in the axilary radiator. I would like to see if this is even possible.
01-09-2016, 05:28 PM | #80 |
The Dogfather
Drives: #1 off the line for a customer. '16 Join Date: Oct 2015
There is 1 radiator that is actually right there on the under tray laying flat. Not sure if you can see it via looking through the grill but you DEFINITELY CAN see and even feel it when you just lay down in front of the car and put your hands on the undertray.
01-09-2016, 07:30 PM | #81 |
Drives: 2018 Camaro ZL1 1LE Hyper Blue Join Date: Dec 2015
I took my 2SS to the tire shop this morning to swap out the summer tires for a set of All Seasons. When they took the front wheels off, there is a radiator grille stuff in the front of both wheel wells. I should have take pictures and I apologize for missing that opportunity.
Howard
2018 ZL1 1LE Hyper Blue Metallic
2005 Silverado 2500HD Crew Cab 1987 Camaro IROC-Z White T-Tops Instagram @Gen6ZL1 |
01-09-2016, 08:44 PM | #82 | |
The horizontal one is the trans cooler. |
04-26-2023, 01:36 AM | #83 |
xxSIXINFANTRYxx
Drives: 2017 Camaro 2SS Join Date: Nov 2018
I know what your saying there. To answer your question, it still has all those other ones, in addition to the three for the engine coolant. So there's actually a total of more than three all together. There's three for the engine, then your trans and oil, then a heat exchanger for the differential. A little late to the show here, but just in case some comes across this still looking......
04-26-2023, 09:47 AM | #84 | |
Long hauler
