09-19-2016, 06:58 PM | #1 |
Wheel assist for CC break rotors
We now have a wheel assist fixture for installing the wheels on the Z/28 front and rear. It will protect from hitting the top of the brake calipers or scaring the Carbon Ceramic break rotors. It will work both front and rear and it really helps installing a tire. You just remove the center cap install the fixture hang the wheel on the fixture and rotate to install!! just rotate the wheel to line up the lugs to the wheel.
www.zl1addons.com Last edited by Skylane765; 10-08-2016 at 07:20 PM. |
09-19-2016, 07:51 PM | #2 |
Drives: z28 Join Date: Jul 2016
Dude that's badass
09-19-2016, 07:59 PM | #3 |
Drives: 2015 Z/28; 1969 Camaro SS Join Date: Nov 2015
That is cool.
How many Pesos? Website says coming soon, no price I could see. |
09-19-2016, 08:03 PM | #4 |
Drives: 2015 Camaro Z/28 - Silver Join Date: Apr 2013
something else i need to put on the list..
Sent from my iPhone using Tapatalk |
09-19-2016, 08:36 PM | #5 |
Will this work on SS, Zl1, and 1LE??
Don't have the CCM brakes but will be installing big calipers that I don't want all beat up either.
Orange Krush II
09-19-2016, 10:07 PM | #6 |
Lover of Speed
Drives: 2018 ZLE Join Date: Feb 2016
yes please! I will order this asap.
09-20-2016, 09:50 AM | #7 |
Waiting for tap at this time. They will go out this week. front you will use the pin on one side of the fixture and in the rear it will screw on the hub. very simple. Its tough to install the wheels with out it. The Corvette comes with goofy foam things you put over the rotors and a tough thing to get in place.
09-20-2016, 09:55 AM | #8 |
09-20-2016, 02:41 PM | #9 |
You make a set and I'll try them out on mine willing to be the guinea pig!!!
Orange Krush II
09-20-2016, 03:45 PM | #10 |
Drives: Z/28 Join Date: Oct 2015
That's smart. I'm going to have to whip some up on my lathe.
09-20-2016, 06:58 PM | #11 | |
Drives: 2016 Ram Join Date: Dec 2013
This is the alternative you mentioned, and it's surprisingly easy to forget you left them on the rotor once you've reinstalled the wheels. |
09-21-2016, 07:02 PM | #12 |
YES!! that came with the Corvette so I wanted something better and faster. here is a look at the rear
09-22-2016, 07:08 AM | #13 |
Are you going to be selling these?
09-22-2016, 02:36 PM | #14 |
