Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro Photos | Spyshots | Video | Media Gallery
Old 10-20-2012, 07:35 PM   #1
1Camaro2SS
1Camaro2SS's Avatar
Drives: 2010 2SS/RS L99
Started my L99 to LS3 conversion and new cam install today!...Photos and Videos
Featured on Camaro5 HOMEPAGE
So after nearly 3 years of owning my Camaro, I decided to start my valve train conversion and cam install in my garage. I am installing a new 3-bolt Comp cam 235/247 .617 .624 and a 3600 stall converter along with a trans cooler, trailing arms, oil catch can and possibly sway bars. This was suppose to be a winter project but I couldn't wait to start on it once I had all the parts on hand.
As others recommended, I decided to pull the heads out while the engine was still in the car. This not only made it easy to access the trans bolts but also helped me to see what was connected on the back side of the heads. I plan to install the heads back on the block while the engine is out on the stand, then drop that baby back in one piece.
I am thankful for my wife's full support and help. In the photo of her, she was removing the valley cover bolts for me while I was taking a break I will be updating this thread with new photos and info as i go along.
thanks for looking
432 RWHP 391 RWTQ 12.37 1/4 mile on stock tires
1Camaro2SS is offline   Reply With Quote
Old 10-20-2012, 08:22 PM   #2
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
OHHHHHH nice bud! I hate the stuff in that last pic lol.
Good work, now you see all the room you gotta play with? Lol now you can get at the Trans bolts.
2001 ws6, 40k miles, Ls3 416 stroker, short block built by PER the rest by me. LPE Ls3 heads milled to 12-1 comp, FAST 102, NW 102, kooks 2", dual DMH cutouts, Magnaflow C/B, BTR cam + springs. Full UMI suspension.
litle88 is offline   Reply With Quote
Old 10-20-2012, 08:24 PM   #3
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Still coming off the top? If so that hood is gonna have to come off bud.
Old 10-20-2012, 08:29 PM   #4
2010 SSRS
2010 SSRS's Avatar
Drives: 3 V8 Camaros
Nice , I'll be watching for the updated photos
Old 10-20-2012, 08:38 PM   #5
1Camaro2SS
1Camaro2SS's Avatar
Yes, I see what you meant about the room for the trans bolts. This will make it a ton easier to disconnect the trans. Would have been nice to take the heads off while the engine was out but it wasn't too bad.
Yes, still going to pull the block out from the top. The hood was suppose to come off first thing but it really wasn't in my way yet. I will take it off tomorrow.
The AFM lifters are pretty nasty! LOL. The ARP bolts would be really nice too but I will be using new stock bolts. This build is getting expensive if you know what I mean.
Old 10-20-2012, 08:43 PM   #6
1Camaro2SS
1Camaro2SS's Avatar
thanks man! I will def be adding new photos daily until done!
Old 10-20-2012, 10:17 PM   #7
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Please please please make sure all of the bolt holes are DRY!!! If there is water in them then your block will CRACK, cause you can't compress water lol. Use lots of compressed air and brake cleaner to clean them up.
I know what you mean about expensive. The only reason I got them is because if I ever need to take the heads off whether its for bad luck or good reason lol I can take them off again and reuse the bolts.
Old 10-20-2012, 10:26 PM   #8
1Camaro2SS
1Camaro2SS's Avatar
I agree 1000 percent with you on cleaning the holes out. I also plan to use a thread chaser to clean the threads and ensure my torque settings are accurate.
Old 10-20-2012, 11:32 PM   #9
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Awesome, didn't know if you knew.
Old 10-20-2012, 11:33 PM   #10
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Oh keep forgetting to ask. Who's tuning it?
Old 10-21-2012, 08:31 AM   #11
1Camaro2SS
1Camaro2SS's Avatar
Originally Posted by wilfredes View Post
I also have the same problem, thank you guys.
What problem do you have sir?
I am no mechanic but believe me, I've been researching this for months now. I read tons of material including books on building and modifying LS engines. With that said I'm still learning and open to good suggestions.
Old 10-21-2012, 08:33 AM   #12
1Camaro2SS
1Camaro2SS's Avatar
The tuning will be done by Fast Motorsports in Woodstock. They're 20 minutes from me.
Old 10-21-2012, 08:11 PM   #13
1Camaro2SS
1Camaro2SS's Avatar
Ok I added 3 new photos from today. I finished disconnecting all the cables and accessories from the other head and block and upgraded several rockers with the trunion bearings. Tomorrow the engine gets pulled out and the fun begins.
Old 10-21-2012, 08:18 PM   #14
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Ahh very nice! But you finished the hard part lol!
The fun stuff is adding all the cool parts to it!!
Will you be cleaning up the pistons and make then shiny again lol?
Cover up the bores if you haven't, sorry I know you know your stuff but just assuming you hadn't lol.
