05-13-2010, 03:48 AM | #1 |
Drives: Orange 2SS/RS LS3 Join Date: Apr 2010
Moisture in my headlights?!
so im at the gas station and walking back towards my car and i notice a foggy haze on the INSIDE of my headlight (halos) in a U shape maybe two inches in height that starts at the very bottom of the headlight... now the weather is cool and we've been getting alot of rain but is this a problem or is it just going to go away?
im assuming if there is moisture in there its not going to come out? anyone have this happen? does it stay? will it go away? im worried |
05-13-2010, 05:29 AM | #2 |
Drives: Camaro LS Join Date: Apr 2010
As long as you didnt do anything (mods) to the headlight....this should not be happening. Take it to the dealer.
05-13-2010, 05:35 AM | #3 |
havent touched a thing on my car yet (soon to change) except the addition of the hockey stripes....
i'll check it in the morning and see what it looks like... i hate bringing her back to the dealer |
05-13-2010, 09:55 PM | #4 |
Drives: Camaros................ Join Date: Oct 2006
should not happen - -suspect a bad seal. It's a warrantable item, so stop by your dealer - they will take care of you!
Our apologies - we don't ever want you to have to take a car back for something like this.
05-13-2010, 10:40 PM | #5 |
Drives: 2010 IOM 2SS/RS Join Date: Feb 2010
Mine is doing this too!
Just on the driver side. Guess I will take it in. |
05-13-2010, 10:40 PM | #6 |
Serious Sleeper
Drives: 2010 CGM 2SS/RS M6 Join Date: Nov 2008
Drive-by Fact of Life: After Monday and Tuesday even the calendar reads... W T F *************************************** |
08-30-2014, 03:09 PM | #7 |
Drives: 2010 2LT/RS 6A Join Date: Aug 2014
Anyone else have this problem ? Or know what the fix was ? Mine is doing the same thing, and I'm wondering if I can buy a new headlight assembly ? Also, that headlight is burnt out, and I'm wondering if it's burnt out because water is getting in there ? I'd hate to buy a new bulb and it burns out in a week from water ?
08-30-2014, 07:21 PM | #8 | |
Drives: 2010 CGM Camaro 2SS/LS3 Join Date: Oct 2013
The housing is leaking because it's the seal is broken or the bulb is backed out possibly and not sealing against the housing.
2010 2SS
BMR 1" Springs Koni Orange struts/shocks 1LE rear sway bar SRP Racing Pedals Hurst Billet short shifter Square tire/wheel setup Elite Engineering Catch Can Stainless Power longtubes/highflow cats K&N Typhoon CAI RPM Motorsports of Garner, NC dyno tune (421 RWHP) |
08-30-2014, 07:33 PM | #9 | |
Also, are there any other super common issues with the 2010's ? I know every car has it's small problems, and usually on a forum everyone is well aware and they are dealt with fairly easily.. Anything else to watch for on a 2010 ? Thanks ! And by the way I just joined and look forward to learning a lot here |
08-30-2014, 07:38 PM | #10 |
Best price I found is around $400 YIKES
http://www.ebay.com/itm/2010-2011-20...p2054897.l5659 Anyone know a cheaper place to order from ? |
08-30-2014, 07:44 PM | #11 |
I had moisture in my tail light took it to the dealer and replaced it with no questions. Definitely let them deal with it no reason to spend your own money
*Performance:
mrt v2.0 exhaust/CAI Intake *Cosmetic: Zl1 factory Reproduction wheels Bmr 1.2/1.4 springs/Oracle plasma drl lights, footwell ambient lighting, 45th Gobo lights *Audio: Memphis pr600 amp/Fosgate 12" t0 sub/******** stealth box |
08-30-2014, 08:40 PM | #12 |
Drives: 2010 Camaro 2LT Victory Red Join Date: Feb 2011
Thats actually a pretty good price Brand New at $394...
Just take the headlight out and try to locate the leak. Grab some crystal clear outdoor grade silicone and seal the lens again to the housing. check that the hid cover is on the back tightly and gasket is good. Same with turn signal bulb. thats alot of moisture inside so its probally the hid cover or turn signal cover. did you wash the car and it looked like that after. |
08-30-2014, 09:05 PM | #13 | |
So I'm assuming warranty is over ? and I bought it 3 hours away from a mom and pop dealer , doubt they will eat the cost of fixing it. |
08-30-2014, 09:08 PM | #14 | |
but on the drive home, I realized the headlight was burnt out , so that sucks. I'm worried about buying a new headlight, only to have it fry from water getting in. . I think I am going to just pull the headlight assembly out, and use clear caulk on it, and try to re-seal it, and buy a new bulb .. .. then later, if I have to buy a new one Do you know how to pull the headlight assembly, does the front fascia have to come off ? |
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
Has anyone bought Oracle Headlights?? I have questions!! | ihaveacamaro | Cosmetics and Lighting Modification Discussions | 22 | 06-09-2010 08:04 PM |
keeping headlights looking new | Darth_Emma | Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection | 19 | 03-03-2010 10:16 AM |
Do our headlights come on with our wipers? | wrek | 5th Gen Camaro SS LS LT General Discussions | 10 | 10-23-2009 04:30 PM |
Swap RS headlights with non RS headlights | rallyyellow | Cosmetics and Lighting Modification Discussions | 14 | 10-09-2009 04:49 PM |
Condensation in late 4th gen headlights? | MAC | 4th Generation Camaros | 27 | 06-30-2008 01:53 PM |
