dave@hennessey
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Chevy Camaro vs...
Old 12-12-2013, 12:14 PM   #113
Angrybird 12
7 year Cancer Survivor!
Angrybird 12's Avatar
Originally Posted by WHAMMO View Post
The 2016 Camaro with the 450hp LT1 will beat the 5.0 15' Stang In every way.
You can hope that but at this time with so little known about both cars (especially the Camaro) that is really going out on a limb.
The Bird is the word!
Old 12-12-2013, 12:16 PM   #114
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
Originally Posted by Fraxum View Post
The weight reduction was what really grabbed me. I knew 400 was not possible, but I was ready to believe a 200 pound weight reduction. The more I read the more I think I will be surprised if like the C7 if the new Mustang does not gain weight.
Once we see the new Camaro and the Mustang in the flesh, I also might go C7. Base C7+Z51+Magnaride+NPP looks like the best performance car on the planet for under $100K. And already I see at least 1 dealer discounting.
The Mustang will be lighter in the ecoboost in it, not the 5.0. IRS is heavy. The Camaro in the ATS frame will be lighter and will have the LT1. If not GM is up for a big fail And I will gladly switch to Ford then.
A LT1 2015 Camaro would be a great thing for Camaro fans!! Keep the faith!!
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE
Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me.
WHAMMO is offline   Reply With Quote
Old 12-12-2013, 12:19 PM   #115
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
True, but you can easily imagine what an LT1 would do in a ATS. It has to be good!!
13' 1LE
Old 12-12-2013, 12:27 PM   #116
Deki
Deki's Avatar
Drives: 2018 Mustang GT
The problem is that the ATS won't be as light as it is now, as it's made for a 4 cylinder power plant. With the heavier duty components to support a V8 in it, it will gain some weight. I think it's still a better platform then a polished up S197.
2018 Mustang GT
Deki is offline   Reply With Quote
Old 12-12-2013, 12:40 PM   #117
KMPrenger
KMPrenger's Avatar
With the base ATS in the mid to upper 3,300 lb range, and the V6 version in the mid 3,400 range, I'm guessing a V8 with the beefier components could come in around 3,550 to 3,600ish range. Thats not exactly light, but a good 300 or so lbs lighter than the current SS. Lighter than the current S197 Mustang, and might be just as light or lighter than the new S550 Mustang. It would be a nice improvement for sure.
Keep an eye on the ATS-V (might be revealed in Detroit?)....I'd say that should give us an idea of what a car with V8-like power and powertrain will weigh on the Alpha SWB chassis. Not sure if the LF3 TTV6 weighs more or less than the LT1 V8, but by the time you remove some of the creature comforts, and the mag ride the Cadillac would have, the Camaro V8 could end up weighing less.
Old 12-12-2013, 01:35 PM   #118
Deki
Deki's Avatar
The current S197 Mustang tops out at 3600 in premium trim. A base GT is just over 3500. I'm interested in the weight of the S550 with the V8. I honestly don't think it's going to be any lighter then the S197.
2018 Mustang GT
Old 12-12-2013, 01:46 PM   #119
crysalis_01
Iron fist, lead foot
crysalis_01's Avatar
Drives: 2003 Mustang Cobra
I can imagine that it'll be like the C7. Yeah maybe over the whole line they cut 300-400lbs...BEFORE they added in better, higher quality, and stronger materials. Plus new gadgets and whatnot that today's consumer demands. After all that, I can imagine only the slightest of weight loss...if any. But overall it should be a better performer and be much nicer overall than S197.
crysalis_01 is offline   Reply With Quote
Old 12-12-2013, 07:22 PM   #120
KMPrenger
KMPrenger's Avatar
Well I don't know what trims they used to get these numbers for the 2014 model, but the Ford website says this:
GT manual: 3,618
GT auto: 3,675
Convertibles are over 3,700
http://www.ford.com/cars/mustang/spe...ions/view-all/
I believe the next gen Camaro SS could get right at or under that weight.
Old 12-12-2013, 07:26 PM   #121
Fraxum
Fraxum's Avatar
Ford says the goal of the 2015 GT with the Performance Pack is to be faster then the Boss 302. Probably very doable with better brakes, suspension, comparable power and if they can hold the line on weight. I think the 1LE was the track target.
I also think when the next gen Camaro comes out both the Camaro and Mustang will be very close in all areas of performance, weight, and price. So all we have to do is pick the one with the best taillights.
Old 12-12-2013, 07:31 PM   #122
Deki
Deki's Avatar
GT manual: 3,618
GT auto: 3,675
My buddy had a base 2012 GT and I have a 2011 Premium. We both weighed our cars with 1/4 tank of gas and my came out to 3640, and his was just over 3550. I don't know if the 2014s are heavier (doubt it). I think your numbers make sense as well, I'm just going off what I've seen. You are correct though. Which also brings me to this point...why do people say the Camaro is a pig? It's barely heavier then the Mustang as it sits.
2018 Mustang GT
Old 12-12-2013, 07:40 PM   #123
eymang
eymang's Avatar
Drives: 2011 2SS/RS & 1991 Vert
Originally Posted by Firefighter View Post
Not just no, but HELL NO!
to HELL no
eymang is offline   Reply With Quote
Old 12-13-2013, 08:50 PM   #124
Fraxum
Fraxum's Avatar
SS Camaros are 200-300 pounds heavier than those two numbers. 3,750-3,875 depending on the 2SS, sunroof, and gas.
Once we actually understand gravity, we could maybe fix things with a little black box.
Old 12-13-2013, 09:46 PM   #125
Rockey33
Rockey33's Avatar
Drives: 2012 IOM Camaro SS
I traded a Mustang for my Camaro. No way I am going back!
Rockey33 is offline   Reply With Quote
Old 12-13-2013, 09:47 PM   #126
Q'smuscle
Drives: 2011 Camaro VR 2SS/RS & Impala
I never understood why ppl said either! crazy ppl I guess ..
Q'smuscle is offline   Reply With Quote
