dave@hennessey
Old 11-03-2018, 12:02 PM   #1
Baggerjack
Baggerjack's Avatar
Drives: 2014 Camaro 2SS/RS/1LE
Brey-Krause Harness Bar Install and Sparco Harnesses
I'm installing a Brey-Krause harness bar and the Sparco Harnesses. My questions is where do you anchor the inside piece of the harness too. The outside one clearly connects to the down rod on the harness bar, but nothing for the inside harness to connect too.
Any help or suggestion is appreciated.
Crystal Red Tintcoat, NPP, Recaro Seats, Sunroof and SLP Skip Shift, ZL1 rockers, TSP Stage 4 "F35" cam, PRC 260cc heads, GPI radically ported LS3 Intake, K&N CAI and JDP Motorsports Stage 2 Clutch Reservoir Kit, TSP Longtubes, off road connectors and high flow cats, aFe POWER Solid Subframe mounts, Brembo 6 piston calipers and two piece rotors
Baggerjack is offline   Reply With Quote
Old 11-03-2018, 09:00 PM   #2
cornerspeed92
cornerspeed92's Avatar
Drives: 2013 1SS 1LE
Show me a pic.
cornerspeed92 is offline   Reply With Quote
Old 11-29-2018, 04:31 PM   #3
CrystalRedTintcoat
CrystalRedTintcoat's Avatar
Drives: 2013 2SS 1LE NPP GBE
You've seen mine, right?
2013 1LE NPP GBE
Mods
Track Days
CrystalRedTintcoat is offline   Reply With Quote
Old 11-30-2018, 09:50 AM   #4
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
you either have to buy a Tank Plate of use the BK side mount which sells for about 50-60 bucks for both seats. Its stainless steel really nice piece. Here is the link.
https://www.bkauto.com/R_9150_Inside...o_p/r-9150.htm
Orange Krush II
1LE Front sway bar, Splitter, shocks and struts, Z28 dual mode mufflers, Intake, UCA Bushings, and Toresen 3.91 Diff. 1 piece DSS Drive Shaft, ZL1/C7 Calipers, and 32mm JPSS Rear Bar. ASC race spec splitter and wicker. 6th Gen M017 Wheels. Stainless Works 1 7/8 LTs. DSE and PAFDT Suspension components.
olblue75 is offline   Reply With Quote
