07-11-2014, 04:22 PM | #1 |
Drives: 2013 ZL1 M6 Join Date: Apr 2013
Michelin PSS, which version (not size) to choose?
Looking at getting 295/35R20 and 315/35R20 but there are so many versions.
See attached images highlighting the major differences. 3 choices for the front and 2 choices for the rear. What are people buying from the available choices? Some of these figures don't make sense, like tread width being wider than section width. I've seen a couple threads talking about rubbing, not sure if it is related to these different tread widths. I'd like the K2 rears just because of the extra tread depth. |
07-11-2014, 04:51 PM | #2 |
Drives: 2013 Triple Black ZL1 Vert M6 ECF Join Date: Mar 2011
All I can tell you is I have the K1-105Y's on the front and I love them.
07-13-2014, 07:33 AM | #3 |
Drives: 2013 ZL1 A6 #7860 Join Date: Apr 2014
I would like to know too.
07-13-2014, 10:10 PM | #4 |
Going for Plaid
Drives: 2011 C6 Join Date: Jan 2010
Check this out. Looks like the Ferrari spec tires are built a bit differently than the non Ferrari spec tires:
http://f10.5post.com/forums/showthread.php?t=682188
2014 ZL1, manual trans, carbon hood insert, Rotofab, Pacesetter 1 7/8" headers, 1" drop BMR springs, stock pulleys, 91 octane tune, 545rwhp & 515rwtq
Serviced and modded by Cordes Performance. 2011 C6, 750rwhp, forged LS3, ported LSA heads, Vortech Ti-trim, 227/243 115+4 Lunati cam, ported LS3 intake, Alky Control methanol, Pfadt sways/shocks/trans mounts, Pfadt tri-y headers(Sold 6/28/14) |
07-13-2014, 10:13 PM | #5 | |
So Cal Race Team
Drives: 2013 Camaro Join Date: Mar 2010
07-13-2014, 10:28 PM | #6 |
Going for Plaid
Which versions do you use? K1 or K2 for the rear? 105Y or 101Y for the front?
07-14-2014, 11:17 AM | #7 |
Drives: 2014 CRT ZL1 Join Date: Jun 2013
Correction to my original post:
I wanted maximum width, so I went with: K1 (105Y) on the front - 0.4" wider than the 101Y. K2 on the back - 1½" wider than the K1 and greater tread depth. However, I do get the occasional rub in the front (& back) on stock wheels & suspension. Next time, I will go with the K1 (101Y) front and K1 rear. Last edited by 2014CamaroZL1; 08-04-2014 at 08:17 AM. |
07-14-2014, 01:48 PM | #8 |
COMPULSIVE CAMARO OWNER
Drives: 18 ZLE,14 2ssrs,96,73 RS LT,69&67 Join Date: Nov 2009
I have the k1 105ys front and the K2 rears. No problems other than the tire guys wihining as they are wide. Grip is light years ahead of the F1gen2s. Not even close. 1 autocross to date and they did well. Me not so much. Both Ferrari spec.
07-14-2014, 04:51 PM | #9 |
Looks like I'll be going K1 105Y for the front and K2 for the rear. I'll risk the potential rubbing issues. so far 2014CamaroZL1 is the only one I've seen that has had issues with it, and it doesn't sound to be too major.
07-14-2014, 05:05 PM | #10 | |
Drives: 2014 1SS 1LE Join Date: Jun 2014
Sounds like a good setup. Did you need to change the camber setup or you using the factory alignment. Notice any handling changes or understeer? |
07-15-2014, 07:56 PM | #11 |
Drives: 2013 ZL1 Convertible Join Date: Oct 2013
I just put these on although with 285's in the front. The rears are K2's the fronts don't have a K designation. No problems at all.
2013 ZL1 Auto Convertible - BRM
Best: 10.829@127.15 FI Interchiller, Roto-Fab CAI, Big Gulp & Res, 9.1/2.5 Pulleys, PB&S, DeatschWerks 1500cc, Fore triple pump, Pfadt LT's, RD HX, MT DR's New times to come with E85 2016 2SS Auto - Hyper Blue Metallic Roto-Fab CAI |
07-16-2014, 02:42 PM | #12 |
I have not changed the alignment specs from stock. Goodyears sucked but wore out flat so all is good.
07-16-2014, 02:46 PM | #13 |
HAMMER PILOT
Drives: 13 ZL1#182, 85 CJ7, 16 Silverado Join Date: Nov 2011
The tire guy told me the main difference was tread depth, the k2s have a little more tread.
"DO YOU WANT ME TO PUT THE HAMMER DOWN?"
08-04-2014, 08:17 AM | #14 |
My original post #7 corrected.
