Old 12-06-2017, 04:03 PM   #1
Cameron27
Drives: 2015 2SS
Reduced throttle output after redline shift?
Cameron27 is offline   Reply With Quote
Old 12-07-2017, 07:00 AM   #2
buck50
Drives: 2021 C8, 2022 Camaro 2SS
Sound like traction control may be kicking in. Next time try it with traction control turned off and see if it acts different.
Order 9/09/2021,2022 2SS, NPP, 56W whls, B04 stripe, AQJ seats, N26 strg. whl., SLN brace
3000 1/19/2022
3400 1/25/2022 TPW 1/31
3800 2/15/2022
4300 2/19/2022
4B00 3/04/2022
4000 3/8/2022
Delivered 3/9/2022
____________________________________
Order 6/01/2016 2017 2SS, NPP, 56R whls
3000 6/08/2016
3000 6/15/2016 TPW 7/18/2016
3400 7/7/2016
4200 7/25/2016
Delivered 7/28/2016
Sold May 2020
buck50 is offline   Reply With Quote
Old 12-07-2017, 08:20 AM   #3
keon718nyc
But it sounds kinds weird as no TC lights he states are coming on the dash so maybe something deeper more internal then just that
Old 12-07-2017, 12:08 PM   #4
lt4camaro
lt4camaro's Avatar
Drives: 2021 LT1 10 speed auto
I have the same issue with a manual trans, wind out 1st gear, speed shift to 2nd and I get a delay in throttle response. I do not hit the rev limiter, but I tried a few shorter shifts like at 6500 - 6700 rpm, same speed shift and sometimes chirp the tires. Cannot fiqure this out, I have had a c5, c6, c7 corvette, all manual's and they don't do that.
lt4camaro is offline   Reply With Quote
Old 12-09-2017, 12:10 AM   #5
MSMYYC
@maplefed
MSMYYC's Avatar
Drives: 16' MBM 2SS,
Torque management.. I have HEARD V6 8speed cars severely benefit from a trans tune.
@maplefed
MSMYYC is offline   Reply With Quote
Old 12-09-2017, 05:30 PM   #6
lt4camaro
lt4camaro's Avatar
TM on a manual car after performing a speed shift, what does it recognize? letting the clutch back out too fast on the completed shift? putting the gas back to the floor to fast after completing a speed shift?. Speed shift meaning lift, push the clutch in, shift, let the clutch out and back on the gas to the floor asap. Not talking about power shifts with the gas pinned to the floor.
Old 12-09-2017, 10:12 PM   #7
dpevans
Drives: 2024 Riverside Blue 2SS 1LE
I have a 2016 V6 and doing a rolling start with all seasons you're not going to spin the tires at 10mph. With traction control off it will chirp the tires but you will not smoke em. You don't say if you have a manual or automatic. If you have a manual the 2017 LT has No Lift Shift. read up on it. With traction control on you are forcing the electronic to override. You have to hold the traction control off for 10 seconds to turn off both TCS and stabilTrak. They will reduce engine power and apply braking to one side or the other. Hold for 10 seconds and the burn out symbol will light up under the tach. I have no problem hitting red line maintaining full power. I would guess if you have an auto the same applies. If you are doing a lot of rolling starts with WOT shifts I would suggest changing your rear end fluid.
dpevans is offline   Reply With Quote
Old 12-09-2017, 10:58 PM   #8
MSMYYC
@maplefed
MSMYYC's Avatar
They have an auto, going off them saying it shifts at redline. Based on what’s described it’s mot a diff issue.
@maplefed
Old 12-09-2017, 11:04 PM   #9
MSMYYC
@maplefed
MSMYYC's Avatar
It can be a bunch of things, it could also be not letting the clutch out soon enough, and getting on the gas too early. It’s all timing. Computer will also negate commanded torque requests if it deems necessary on stock tune, on V8 cars. I am sure the M6 V6 does this too, however I cannot confirm.
@maplefed
Old 12-10-2017, 12:03 AM   #10
jingaling
Drives: 2016 Camaro 1LT V6 MT
Don't hit redline in 1st... .. The car doesn't like it... Try shifting at around 6400 to second...in second gear I can't remember if I redline or not,but 1st gear will give you that hiccup
jingaling is offline   Reply With Quote
Old 12-10-2017, 09:12 AM   #11
dpevans
Go read the posts in dragstrip and launch discussions.
Old 12-10-2017, 06:24 PM   #12
lt4camaro
lt4camaro's Avatar
I agree that maybe the case, like I said I have short shifted 1-2 shift at 6500 and speed shift with a 2nd gear chirp instead of the delay if I shift too close to 7k. I will experiment more on my 2016 V6 Manual that I know doesn't have NLS. The car also only has trac control on or off, no matter how long you push the button down. Btw I like your hiccup reference, that's better than my "delay" explanation
Old 12-10-2017, 06:27 PM   #13
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
Almost seems as though you're describing no-lift-shift, at first...
Old 12-11-2017, 01:06 AM   #14
jingaling
Yeah, with the chirp to second the car keeps moving along strong...taking it further makes it hiccup. I have also tried holding the traction control and havent seen anything else happen. On or off are my only two options. I also feel there is no difference between sport mode vs tour (maaaaybe steering feel). Sport mode is really however fast my feet decide to hit the throttle, clutch and shift gears Haha. Snow mode does reduce the throttle feel, but steering stays pretty much the same.
