Vararam
Old 03-19-2022, 11:40 AM   #1
SSVictor
Drives: 2010 Camaro 2SS
Car won’t crank after stall torque converter
2010 L99 Camaro I just got my car back from the shop after installing a 3000 stall torque converter and i started it a couple of times and it started perfectly. Then about a hour later I was just idling at a red light and I got a abs light with the service stability lights and a check engine light. The car wouldn’t shift gears it was stuck in first gear and I drove it home in first and then tried to crank it again and it wouldn’t crank but the abs light is gone and the traction control and check engine light is still there.
SSVictor is offline   Reply With Quote
abs, cam, check engine light, torque converter, transmisson
