08-03-2017, 10:03 AM | #1 |
Drives: 2018 Black ZL1 Join Date: Apr 2009
New ZL1 polishing
Hi Everyone - Picked up my 2018 ZL1 Monday, i wanted to clay, polish and seal with Adams polishes however the dealer service writer told me i had to wait at least 30 days to let the paint cure. Any thoughts? Is he correct? The Adams tech told me to do it now. Much appreciate everyones input.
08-03-2017, 10:10 AM | #2 |
Retired from Car mfrs....
The Adams tech is right, watch what that dealer idiot tells you in the future.
08-03-2017, 10:19 AM | #3 |
08-03-2017, 10:31 AM | #4 |
No Hope
Drives: 2017 ZL1 Black Coupe, 2017 Z06, Join Date: Mar 2017
Good to know is claying the car. I clay the front end and rocker panels at least every month or more. Clay bar will not harm the paint if used with soapy water and a clay bar will remove all the little contaminants that stick to the car. I tend to be compulsive when it comes to a clean car and instead of rubbing the crap out of the car to remove bits and pieces a clay bar will do it quickly without harm. Just make sure the car is wet and the clay bar is wet when using. Congrats on the new car, how about a few pictures?
08-03-2017, 10:52 AM | #5 |
雪の玉
Drives: '22 Z71 RST Silverado Join Date: Feb 2011
Nope...detail away, what you'll be using won't hurt it in the least bit.
08-03-2017, 11:04 AM | #6 |
Drives: 2016 Z06, 2017 ZL1 Join Date: Feb 2012
Times are changing. clay, polish and apply a ceramic coating. So much better
08-03-2017, 12:57 PM | #7 | |
08-03-2017, 01:01 PM | #8 |
Tip: try not to clay too much, use the baggie test to tell if you need it, but a couple times a year is best. Claying, microscopically, is pretty abrasive.
08-03-2017, 01:21 PM | #9 |
08-03-2017, 02:37 PM | #10 |
Drives: 2017 Mosaic Bk ZL1 M6 Join Date: Jul 2009
Good move. Dealer washed my '13 ZL1 vert I bought off the truck while my back was turned. Spent about 6 hours behind the Porter Cable with Adams stuff fixing that mess, including the hood insert. Bought my '17 off the showroom floor, so it needs to go a few rounds with the PC as well.
08-03-2017, 05:41 PM | #11 |
Drives: Hyper Blue ZL1 Join Date: Jul 2017
I would clay at as soon as you can and then go back with your polish of choice. I have had new vehicles come in that were just covered in contaminants. One F250 Ford had rail dust so bad it took 4 bars of clay to get it all out and it was shocking how cloudy the paint was before vs after.
08-03-2017, 05:50 PM | #12 | |
08-03-2017, 06:03 PM | #13 |
Look at the essence/reload posts in the cosmetic section, it really is a game changer for detailing....
Start here : http://www.camaro6.com/forums/showth...hlight=Essence
08-03-2017, 09:13 PM | #14 |
Drives: 2017 Camaro ZL1 Join Date: Nov 2006
By the time that car got to you, that paint had a good month or better to cure.
